Old 07-21-2019, 08:00 AM   #281
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
Originally Posted by Dingo Girl View Post
Attachment 346305
The 2 latch assemblies are the same.
I put the old one back in and the latch handle snapped down flat. There was no front to back or side to side slop but there was some up & down slop.
I put the new assembly back in & zero slop when the ball is locked in. But the rod still sticks up like in the picture.
I'm stumped.
Since the original parts still work and appear to be in good condition what are you not going to use them? Sometimes replacement parts don't work properly. There does appear to be minor differences between them that could present issues.
I wire brushed my originals and reused them rather than replacing them. Last thing I want is for my hitch to have issues when traveling or trying to travel.
Steve
1958 California Built 18' #18-4092
https://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 07-21-2019, 10:49 AM   #282
Dingo Girl's Avatar
1967 17' Caravel
Oak Creek , Colorado
I'll be using the old one. The new is not safe.
Dingo Girl is offline   Reply With Quote
Old 07-22-2019, 10:03 AM   #283
1958 18' "Footer"
Since we agree these parts may not be safe I suggest you contact Vintage Trailer, notify them and ask for a refund at the least. It is good to have replacement parts but only if they work properly
Steve
Old 07-22-2019, 10:13 AM   #284
Dingo Girl's Avatar
1967 17' Caravel
I talked to vintage trailer awhile ago. They no longer carry the part. Marvel quit making it.
The part was purchased & installed a few years ago. Never got to try it til this summer.
Since it opened and closed the way it should when installed, i never dreamed it wouldn't fit the ball properly.
Old 07-30-2019, 06:47 PM   #285
Blucolt's Avatar
Ormond Beach , Florida
Subfloor
We are repairing a section of subfloor rot in the front of our '74 Sovereign. We spoke with a custom RV guy who recommended Durock between the subfloor and flooring, to keep the subfloor dry. Has anyone used this? I have heard of it for houses but I'd worry about weight (around 2lb. per sq ft).
Blucolt is offline   Reply With Quote
Old 07-31-2019, 03:35 AM   #286
Dingo Girl's Avatar
1967 17' Caravel
Never heard of it. 2# a square foot is alot of unnecessary weight.
I used 5/8 ACX plywood then coated it with penetrating epoxy. Especially the edges.
I took a scrap of it and tossed it outside under the eve of my barn. No rot or damage 5 years later.
Old 07-31-2019, 07:21 AM   #287
1966 22' Safari
Fredericksburg , Texas
Got to be some misinformation here. The Durock 3x5 is about 1/2” thick cement board. You can’t put that between the subfloor and flooring. The RV guy may have meant Durock shower membrane. That’s waterproof and is .012” thick. Don’t know. Good luck
Bubba L is offline   Reply With Quote
Old 07-31-2019, 05:57 PM   #288
2007 22' International CCD
Also consider that anything waterproof also traps water where you may not want it to sit and soak.
Today is the day! DJCJ 76 AIR Member Introductions 12 07-20-2010 12:18 PM
RV Story in USA Today--Today SteSpot On The Road... 0 05-18-2009 02:14 PM
Today's today, You know what that means? codybear Off Topic Forum 20 11-08-2006 11:31 PM
South Today's the day for generator questions Minnie's Mate Boondocking 15 11-01-2006 06:11 AM
today's the day! bradk Our Community 31 04-21-2006 08:28 PM
