Old 03-09-2016, 01:37 PM   #1
2006 19' Safari SE
Hayes , Virginia
Tile adhestive
I am taking up 12" square tile off of the floor and I am wondering if anyone knows a good way to get the adhesive up once the tile is removed. The new floor will not require anything to stick down, they lock together. Thanks, Tom
mocus is offline   Reply With Quote
Old 03-09-2016, 01:53 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Heat gun and putty knife. What kind of new floor are you putting down?
Old 03-09-2016, 01:57 PM   #3
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
Mine was so dried up that I just had to scrape it.
But I wanted to give you a "heads up" on the "Locking" type and not using an adhesive. I tried this with a Luxury Vinyl Floating Flooring that I purchased from Lumber Liquidators (the stuff was junk!). The 1st time that the flooring came apart I removed pieces and put it back together using an adhesive, that repair did not come apart and the 2nd time that it came apart I made the same repair. The 3rd time that it came apart, all in different areas, I took it all out.
I have seen others that have experienced this separation with their Vinyl, Bamboo & Cork Flooring when attending Vintage Trailer Rallies so my problem was not unique.
I found a product the Lowes has an exclusive on called Smart Core;
http://www.lowes.com/Search=smart+co...tt=smart+core#!
I talked with the manufacturer about my installation and he recommended that I glue it down. I used Liquid Nails Polyurethane Adhesive in a pattern similar to what was recommended to install an epoxy countertop by putting daubs down from the tube to allow the assembly to expand and contract. I also used a water based flooring glue to adhere the seams.
I did this last year when it was still in the 80s & 90s and it has since been down into the teens over this winter with no signs of movement.
Good Luck!
Steve
1958 California Built 18' #18-4092
http://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 03-09-2016, 08:02 PM   #4
2006 19' Safari SE
Hayes , Virginia
I have tile up but need to take the adhesive up. I had new plywood floor installed (rot), in the front 19'er, and am taking rest of tile up. I was shopping in Lowe's for tile and the salesman said he had a great deal (yea rite), of 6 boxes, 7 tiles each, 26.5X13" that had been special ordered and customer refused them. They were marked down to $73 and he said if I would take he would sell all for $32. The tile were a few hundred bucks originally and I could not pass it up (I would tile my driveway at that price. Like I said, tile are up but floor is so sticky, it needs to come up...I need something to clean floor. I will peruse website you provided. Thank you both very much. Manufacturer web site www.ivcgroup ( that's it), and box says "Luxury Vinyl Tiles." That's it
Old 03-10-2016, 07:24 AM   #5
2006 19' Safari SE
Hayes , Virginia
For some reason, when working on trailer, I come up with these hairbrain ideas. I am going to "try" placing one tile at a time on the floor, tracing around with pencil, lifting tile and putting adhesive around the drawn line. I believe this would help seal cracks and after tiling is complete, hold in place. It's in the 70's in Virginia making it a good day to start. This way would make for an easier removal of tile if Need be and less mess. I will go to Lowe's and see what I can find. Thanks to ya.
Old 03-10-2016, 08:10 AM   #6
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
You might want to "skin" your floor with thin luan or plywood to cover the sticky before you lay your tile. We have a floating cork floor from Lumber Liquidators and have had no problems with it, down to minus 25 degrees and plus 100 degrees. Can't beat your deal, though!
Kay
Old 03-11-2016, 07:01 AM   #7
2006 19' Safari SE
Hayes , Virginia
What a great idea. I so happen to have some left over from my bathroom floor. That will save a bunch of work. Will giv'er a try. Thanks
9x9 floor tile flyski Repairing/Replacing Floor &/or Frame 4 10-22-2003 01:45 PM
New Linoleum tile Bryanhu Upholstery, Blinds, Walls & Interior Finishes 6 09-29-2003 03:35 AM
Tile or single piece vinyl? Andy R Floor Finishes 36 05-10-2003 06:56 PM
Tile Floor billhabing Repairing/Replacing Floor &/or Frame 10 04-19-2003 12:08 PM
Bathroom tile ALANSD Floor Finishes 2 03-06-2003 11:12 PM
