06-21-2009, 10:11 PM
Worldturners
1976 31' Sovereign
San Antonio
Those rounded corners
Does anyone have any good tips for tracing out the rounded floor corners when replacing the flooring? Both ends of our trailer are so rotted out that we may not get good tracings from the old floor.
Thank you so much.
06-21-2009, 10:23 PM
Salem
, Oregon
Hi, when remodeling my trailer's living room I used a piece of drywall and a hula hoop, but some one told me that they used heavy copper wire or maybe copper tubing. I like their idea better, but I was already done.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
06-21-2009, 10:50 PM
Corona
Thank you so much.
Yu can use the floor channel as a guide.
06-21-2009, 11:58 PM
Power to the People !
1972 31' Sovereign
SAN DIMAS
06-22-2009, 05:04 AM
Worldturners
1976 31' Sovereign
San Antonio
Thank You!
Wow, you go to bed and wake up, and such brilliant ideas pop up while you're sleeping. I think I like airforums. Why rack your own brain when others have already racked theirs?
Just kidding. But on a serious note, thank you for the great ideas guys. Mary, those pictures are soooo helpful. You guys are swell.
- Terry and Natasha
06-22-2009, 09:47 PM
1972 31' Sovereign
SAN DIMAS
06-23-2009, 09:06 AM
Worldturners
1976 31' Sovereign
San Antonio
Broken Link
Hi Mary,
Thank you for all the good links. I couldn't find this one though:
Originally Posted by Maryw164
It's broken or something. Could you tell me where to find it? Thank you again.
Natasha :-)
Terry & Natasha Turner
'76, 31' Sovereign International Land Yacht
Remodel Madness
06-23-2009, 11:10 AM
Here is the process I used on mine last weekend.
First pic is how I determined how big a piece I needed for a template. 2nd pic shows the curve takes up 22-3/4" width and 28" long. I actually cut my template piece longer than 28" to bring it all the way back to the center of the holes in the crossmember, and still tuck under the C channel a little bit. How much doesn't matter.
Pic 3 is my rough-cut template piece.
Pic 4 shows it laid in place, aligned with the center of the holes in the crossmember, and tucked under the C channel.
Pic 5 and 6 is my hand model traceing the inside edge of the C channel onto the template.
Pics 7 and 8 show how I aligned the back edge of the template with the back of the plywood flooring. The center of the holes in the crossmember are going to go through the center of the tongue on the plywood (7) and pic 8 shows how I aligned the template with the edge of the plywood. I determined beforehand that the width between my walls was 84-1/2". The C channel is 1-1/2" each side, so the total plywood length should be 87-1/2". I took 1/8" off this figure so it would have just a slight amount of play to get it into place. You can see where I started my cut at 87-3/8". The template has a line from the inside edge of the C channel traceing, which is aligned 1-1/2" in from the edge of the plywood at 85-7/8"
IN the next post I'll show how I copied the line from the template to the plywood.
Rich
06-23-2009, 01:03 PM
1972 31' Sovereign
SAN DIMAS
Try this one, work backwards?
Hi Mary,
Natasha :-)
I don't know why it won't work, so try this one:
http://www.airforums.com/forums/f36/...tml#post713000
It's the last post on that thread. You'll just have to go back and start on page 1 from there I guess.
Mary
06-24-2009, 11:14 AM
I tried to follow up on my last post yesterday, but it got "bumped " somehow. Time is not on my side at the moment. I will try to re-post this afternoon or evening with the rest of the process I did.
Thanks for the thanks!
Rich
