Old 04-22-2014, 03:35 AM   #1
GaŽl's Avatar
1960 26' Overlander
In the North , FRANCE
Images: 8
Thickness of the sheet (2 measures availables ?)
Hi,
I have to replace 2 sheets on my Overlander but in France, it's relatively different about the measures, I can have it in an airplane supply.
The thickness is : 0.032" but I can have 0.0315" or 0.0394"
For you, what is the better ?
Thank you !
1960 Overlander
2002 Chevrolet Tahoe
GaŽl is offline   Reply With Quote
Old 04-22-2014, 05:28 AM   #2
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
If it is a lower sheet that will be wrapped under, I suggest the 0.0315. The other may be too stiff to wrapped under.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 04-22-2014, 05:31 AM   #3
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
You're within 5 ten thousandths (of an inch) of our 0.32 which is what most Airstreams are made of. Most of us don't own a good enough micrometer to tell the difference.
The second figure is within 6 ten thousandths of our 0.40 which is the next thicker grade of aluminum. You could tell the difference by looking at the trailer if you used that, but you would have to look very closely.
Important thing is to make sure it's alclad. You need that pure aluminum layer on the outside of the metal alloy for corrosion resistance and so you can get a really good shine when you polish it.
Old 04-22-2014, 05:32 AM   #4
65CV's Avatar
Western , Massachusetts
Gael,
Assuming that you are talking about internal sheets, I would go for the 0.0315 thickness. It's within the tolerances for the 5052 .032 sheets here in the US. See this chart.
John
65CV is offline   Reply With Quote
Old 04-22-2014, 08:44 AM   #5
GaŽl's Avatar
1960 26' Overlander
Images: 8
Hi Everyone,
Thank you for your replies and the document,
This afternoon, I've phoned to this seller (airplane specialist) :
http://http://commerce.ciel.com/ulmt...774_H111.aspx?
Now, I've a doubt in my mind between the seller and what you write...
Finally, the sheets are in 0.032" but I'm not sure if it's good...the ref 5755 H111 is (not) the same than 5052...
I continue my search with what you told me.
I don't want to make a mistake... !
1960 Overlander
Old 04-22-2014, 08:49 AM   #6
GaŽl's Avatar
1960 26' Overlander
Images: 8
It's for external sheets :
Here, the sheets were fixed taillights and licence plate :
And here :
1960 Overlander
Old 04-22-2014, 10:37 AM   #7
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
Gael,
This is the type of Aluminum you are looking for. You will want to be as close to 0.032" as possible and it must be ALCLAD or it will not look correct.
2024T3 ALCLAD ALUMINUM from Aircraft Spruce
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Old 04-22-2014, 12:14 PM   #8
Originally Posted by GaŽl View Post
Hi,
Thank you !
In later years, Airstream has switched the lower panels to .040.
Using a thicker panel than the original won't hurt anything.
Old 04-22-2014, 12:30 PM   #9
65CV's Avatar
I looked on your link and found the 2024T3, but there is no mention of Alclad. It may be an American trade name. Alclad is just a thin layer of pure aluminum that will shine like the rest of your trailer will after you polish it.
I don't understand why you are replacing the entire panel. Would you consider a small patch of Alclad instead? It's very frequently done in restorations.
Here's a link to one I did to cover the old oven vent. I did several more to cover old electrical inlet holes.
John
Old 04-22-2014, 02:09 PM   #10
GaŽl's Avatar
1960 26' Overlander
Images: 8
Hi Craig and John,
Sorry for my ignorance but the 2024T3 is the same than the 5052... ? I'll try to know if it's ALCLAD...
For the rear panel, it seems I have to replace all the panel because today, it have a little panel fixed on the original :
But for the lateral panel, the hinge (not sure for the word) of the door, it have already a handmade bad panel who fixed this hinge,
The inferior is good, you can see on the little photo,
If I fix a patch, is it rather solid for the support of the door?
Thank you for your advices,
1960 Overlander
Old 04-22-2014, 03:31 PM   #11
65CV's Avatar
GaŽl,
The 2024-T3 and 5052 Aluminum alloys are VERY different. The 2024-T3 is a much stronger alloy and is Heat Treated for strength (T3 is a code for the temper of the heat treating). It is far stronger and is used for structural components in Airstreams and airplanes.
The 5052 cannot be heat treated and is much softer -- about half the strength of the 2024-T3. You don't want to use it for a structural panel like the ones you may replace. The 2024-T3 contains copper, so it will corrode easily outdoors. Normally it has a coating to prevent the corrosion, so it is very possible that your supplier has some aluminum coating like Alclad.
If you cannot source the material, you can get small amounts from the States. If you just need small patches, I'll send you some (I assume you will pay postage).
For the patch on the rear of the trailer, you could drill the rivets on the old patch and replace it.
For the hinges, can you post pictures? Some here have put a support plate behind the hinge and riveted through the hinge, the skin and the rear support plate. It is hard to tell what's best for yours without pictures.
John
Old 04-23-2014, 04:34 AM   #12
GaŽl's Avatar
1960 26' Overlander
Images: 8
Oh Andy, sorry, I've haven't seen your message !
0.040"... ? I have to verify this... but it's only for later years ?
I send you tonight a picture from the hinges
Thank you
1960 Overlander
Old 04-23-2014, 12:40 PM   #13
GaŽl's Avatar
1960 26' Overlander
Images: 8
Here, the pictures :
The superior with old patch :
The superior without the old patch (aarrggnn) :
The inferior (good) :
1960 Overlander
Old 04-23-2014, 12:42 PM   #14
Thank you
No, no.
Airstream uses it in the later years, but you certainly can use it on older years as well.
Not a problem.
Aluminum sheet thickness/type crispyboy Ribs, Skins & Rivets 2 05-29-2007 01:58 PM
Propane Weights and Measures Gypsy George LP Gas, Piping, Tanks & Regulators 20 03-18-2007 04:10 AM
Help >> '04 22' CCD Mattress Thickness Xray 2002 - 2005 International 1 04-07-2004 11:44 AM
Holding tank thickness? Sneakinup Waste Systems, Tanks & Totes 4 11-10-2003 09:38 PM
Skin thickness Steve St. J Ribs, Skins & Rivets 1 09-23-2003 10:57 AM
