Old 05-11-2008, 07:40 PM   #85
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Humm.....
The large guage Blue wire (I think #10 guage) is actually the 12v positive wire and the White wire is the negative. IF we are talking about the blue and white wires that coming out of the hole in the wall and then connecting to the front of your rectifier. Just an FYI, the white wire in mine is always the ground.
I'm going to go out to the camper and take a few pictures and post them. It just so happens that I'm putting the walls back in at the moment and at the Univolt wiring bundle as we speak (so to speak).
www.nesa.org
Air No. 6427
Old 05-11-2008, 08:47 PM   #86
Got gandkids?
In this first pic, this is how the wiring bundle looks coming out of the wall below your bathtub. My walls are not all in and the bathtub isn't either, so it doesn't look like yours at the moment. Note the heavy guage Blue and White wires.
www.nesa.org
Air No. 6427
Old 05-11-2008, 08:50 PM   #87
Got gandkids?
The Blue and White wires then run over to your Univolt (or whatever you've replaced it with). Blue is normally the 12v positive, White is normally the 12v negative.
ID:	60326   Click image for larger version
www.nesa.org
Air No. 6427
Old 05-12-2008, 03:21 AM   #88
Lothlorian's Avatar
Loganville , Georgia
Jim:
The wiring I am refering to is the wiring in the new parrallax 3020 converter. I took a picture of the wiring of the old univolt before I pulled the converter out. I use that as my refrence when I will put it back together. I need to know the wiring to the new converter. I will call parrallax today.
I am stripping off the old weather stripping on the screen door and it does not want to come off. The old gasket came off without any problems. What did you use to get the old weather stripping off?
Work has slowed down on the trailer until I get out of school. I teach and this time of the year is really crazy. My energy level has not been there because the kids know the end is close and they have been bouncing off the walls. I teach seniors.
Brian
Lothlorian is offline   Reply With Quote
Old 05-18-2008, 06:11 PM   #89
Lothlorian's Avatar
Projects picking up
Today I was able to fix the converter and it works. I put new weather stripping and gaskets on all the doors. My wife cleaned the screen door and we put in a new mosquito slide on the screen door. I have all my electricity complete. Things are coming together nicely. I am about ready to order new axels and new tires. Once that is complete I will have the RV center put in the new pex pipe and hot water heater. I think I will be able to use it this summer.
Brian
Old 05-19-2008, 11:14 AM   #90
1973 31' Sovereign
Portland , Oregon
Images: 22
Brian
Congratulations! It is very nice to reach milestones and be able to move on to the next step.
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
Old 05-26-2008, 01:41 PM   #91
Lothlorian's Avatar
New accomplishments
I decided to resand and give already painted bathroom parts another coat. I was glad I did. It came out looking great. We used Lowes Porcelain white epoxy paint. I did all the sanding and steel wool and my wife did the painting.
I finished the plumbing for my black tank and all bathroom drain pipes. I started to put the trunk back together and it looks pretty easy. I have a Question about the bottom part of the trunk. This is the floor with the drain hole with a gasket. Do I use self setting screws and screw it down to the frame which holds the black tank? I know I will rivet it to the belly pan when I put that back together, but I am not sure about the 1/8" angle iron frame. There are holes that line up with the angle iron and holes farther out which will connect to the belly pan. What do you think I should do?
SIU Bound
Brian
ID:	61012   Click image for larger version
ID:	61014   Click image for larger version
Old 05-31-2008, 03:42 PM   #92
Lothlorian's Avatar
Plumbing pics
Check out this thread I posted on the plumbing page
http://www.airforums.com/forums/f443...tml#post569410
SIU Bound
Brian
Old 05-31-2008, 11:16 PM   #93
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
...I have a Question about the bottom part of the trunk. This is the floor with the drain hole with a gasket. Do I use self setting screws and screw it down to the frame which holds the black tank? I know I will rivet it to the belly pan when I put that back together, but I am not sure about the 1/8" angle iron frame. There are holes that line up with the angle iron and holes farther out which will connect to the belly pan. What do you think I should do?
Brian, half my Airstreams are riveted and half have substantial (like 1/4) screws. I think if the belly pan below the tank is continuous from other areas, use rivets. Airstream seemed to have favored screws in the angle iron--you ought to be able to tell from the hole size. If the holes are bigger than 3/16, which is the largest rivet size I have found on my models, then I would bet on screws.
Zep
Old 06-01-2008, 05:46 AM   #94
Lothlorian's Avatar
Zep:
I went with small sheet metal screws. What a nice feeling putting the whole back end back together. I am getting closer. What did you use on the top trunk hood? I think I am going with sheet metal screws.
SIU Bound
Brian
Old 06-01-2008, 10:30 AM   #95
1975 31' Sovereign
1977 23' Safari
...What did you use on the top trunk hood? I think I am going with sheet metal screws.
I used rivets. The one thing to watch out for is making sure the joint between the shell, as it comes down, and the horizontal sheet that the locker lid attaches to, is well sealed. If not, water runs forward on the horizontal sheet, soaking the underside of the flooring and is a prime source of rot. This is the worst joint in the whole design (speaking of 70's models here) regarding water seepage.
Zep
Old 06-02-2008, 04:24 AM   #96
Lothlorian's Avatar
Zep:
Should not be a problem because I have Nyloboard for a floor. The metal channel the floor sits in back has two coats of por 15. I still plan on giving every thing a good seal with Vulkem.
Brian
Old 06-03-2008, 03:24 PM   #97
Lothlorian's Avatar
She is Back together for towing
I have the new tires on, the belly pan up and covering the black tank. Everything is insulated, bananna rap is on, with break lights and turn signals working. I am not finished because I still have to finish the plumbing. I am not knowledgeable enough to finish the plumbing. I am going to tow it to an RV maintenance shop and have them hook up the plumbing. I also want them to set up the pipes so they can become winterized. Once I get it back then I will put the bathroom together and put in the laminate floor. I will be ready to use it with the knowledge some things still have to be done. I will need new fantastic fans, and I am not sure if the appliances will work. We can always use coolers. I know I need axels and they is something I am going to have to get done.
My wife has put in many of the new curtains. They rock.
SIU Bound'
Brian
Old 06-03-2008, 03:52 PM   #98
vhord's Avatar
Images: 96
Brian
Always good to get the ladies involved.
vhord is offline   Reply With Quote
A 1963 Overlander named Moonraker! reinergirl 1960 - 1964 Overlander 702 08-28-2017 11:36 AM
The Buddha Baby A Restoration wasagachris 1960 - 1964 Sovereign 136 06-30-2012 08:56 AM
Start capacitor for Armstrong 14 A/C pdwhitt Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-04-2011 03:01 PM
Catarina 1963 Airstream Overlander :: 1963 Airstream Overlander utee94 Airstream Registry Discussions 0 08-19-2011 08:31 AM
1966 Overlander Bob J. Mariano Sinks, Showers & Toilets 1 08-02-2011 09:28 PM
