Old 12-09-2009, 04:12 PM   #1
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Send a message via Skype™ to WILDRTEXAS
The ONLY floor rot I have found. Anyone have a quick fix idea?
Its along the frame in the back along the silly bumper compartment.
REALLY, REALLY....really dont wont to get into another large project. HELP
He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion...
Taylor 1/20/96 - 11/28/08
WILDRTEXAS is offline   Reply With Quote
Old 12-09-2009, 05:38 PM   #2
87MH's Avatar
1978 31' Sovereign
Images: 292
The ONLY floor rot I have found...NOT
REALLY, REALLY....really dont wont to get into another large project...
Dude -
Hate to burst your bubble here, but you can rest assured you WILL find more bad plywood hidden behind the pipe and shell...particularly where the plywood goes into (or under) the 'C' channel....
By thankfull that it IS plywood and not OSB or some other type of "manufactured" board - most of the floor would be mush by now if it were not plywood.
Since it IS relatively close to the shell, it should be repairable with a minimum of disassembly.
Pull the interior panels in the area of the damage, and strip back the belly pan in the same area...you should be able to cut out the bad spot and tie in a good splice from the underside.
Luck.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 12-09-2009, 06:17 PM   #3
TankerIP's Avatar
2002 22' International
2019 25' Flying Cloud
Have you checked interior?
I also agree that you need to really check the seal along the bumper edge. Someone else here said the bumper is just a water magnet. My bumper leak turned out to be quite significant and required days of labor to fix. I assume you've seen the several posts here about bumper leaks and the problems they can cause. They go back for years.
Good luck.
http://www.airforums.com/forums/f396...eak-56099.html
http://www.airforums.com/forums/f456...one-58195.html
http://www.airforums.com/forums/f456...ybe-56674.html
TankerIP is offline   Reply With Quote
Old 12-09-2009, 06:50 PM   #4
2004 25' Safari
1971 27' Overlander
Jourdanton , Texas
The advice Dennis gave you is much the same as a friend gave me this afternoon while we we examining the 71 Overland that I acquired,but have not started to work on.
You have a distinct advantage. You have the bathroom out. I have to work my way back to get it out.
pienjim is offline   Reply With Quote
Old 12-09-2009, 07:07 PM   #5
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Yes, The bathroom was removed to replace the copper w/ pex and rework the bathroom. HATE that I found it..Its haunting me.. I knew in my heart Id need to address the problem...I just wanted on wih the fun stuff and quit woking on the not so fun stuff. Its getting old FAST with the not so fun stuff... Are you going to replace your floor. Is it alot of rot ?
Old 12-09-2009, 07:22 PM   #6
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Along the very rear edge of the trunk you should have a panel riveted in place - about 4 feet long and 5 inches or so tall. You may want to drill the rivets out of that and pull it - should be 5 or 6 holding it. Inside (pull the insulation that will likely be damp) you will be able to see the C channel and under that a steel channel it bolts thru. That steel channel is welded to the top of the frame. Your going to need to see the condition of that channel to decide how big this job is actually going to be.
You can also open the bumper lid and feel up under the edge - you should feel the U shape and get a rough idea of how badly it's rusted. Not sure on a 70 - does the bumper tray open on the bottom for the hose/electrical to exit? That's another way to get an eye on it laying on your back. I'll keep my fingers crossed for you girl...
Old 12-12-2009, 11:02 AM   #7
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Originally Posted by 87MH View Post
Dude -
Luck.
Dennis, Do you think I could slide 1 new piece of plywood from the rear exterior over the bumper box? Thanks
Old 12-15-2009, 10:01 AM   #8
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
The Texas Cavarly arrived...LisaP and her wonderful husband Gary came over to look at the floor. The floor rot had been weighing heavly on my mind. I just didnt want to Bandaid the problem. I knew the problem would be NO MORE the moment asked for a saw. He worked so quickly and got the problem to a managable project for me.
LisaP and Gary...THANKS SO MUCH FOR SPENDING YOUR SUNDAY ON MY PROBLEM...Yall have me up and running again..I can now see the light.
MERRY CHRISTMAS!
Old 03-18-2010, 06:30 AM   #9
1972 31' Sovereign
Dallas , Texas
Hello Wildrtexas! We just bought a 72 Sovereign and have high hopes for it. We where wondering if you ever had some free time, maybe you could come over and take a look at it. We are new to this and could use an expert on how too's and tips. This is a wonderful site, and can't wait to meet other owners. Let's roll!
RS2311 is offline   Reply With Quote
Suburban NT 30M Furnace quick fix Chuckles Furnaces, Heaters, Fireplaces & Air Conditioning 2 03-16-2013 04:21 AM
Silicone ok for quick fix? BeckyAnt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 23 10-19-2009 08:54 PM
Quick Wing Window Fix Zeppelinium Windows & Screens 16 08-04-2009 03:36 AM
Floor Rot mmeburges1 Repairing/Replacing Floor &/or Frame 3 01-10-2004 06:21 PM
Marker lights--quick fix tip. Sneakinup Lights - Interior & Exterior 1 12-01-2003 02:42 PM
