Old 03-04-2004, 09:11 AM   #1
1962 19' Globetrotter
2001 31' Excella
The dreaded rear end sag/separation
I don't want to open a can of worms here, but just curious if the dreaded rear end sag is more predominant in certain years and length trailers??
I don't seem to hear much about smaller unit models...
Craig is offline   Reply With Quote
Old 03-04-2004, 09:46 AM   #2
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Search feature
Good question.
The issue has been addressed many times and there are many opinions on the issue here on the forum. Simply use search feature and you will spend hours reading about it.
Smily
smily is offline   Reply With Quote
Old 04-22-2004, 10:35 PM   #3
upallnight's Avatar
I have read quite alot about the separation / sag issue and it seems that pulling the belly pan seems to be the excepted practice for replacing the flooring and bolts in the bottom channel of the wall, what I was wondering is if anybody has ever tried using threaded insert rivets without pulling the belly pan? The only problem I can foresee is mapping out the location of the bolt holes in the new floor, but with a good tape measure it shouldn't be that hard, certainly easier than pulling the belly pan.
Leonard
upallnight is offline   Reply With Quote
Old 04-23-2004, 05:39 AM   #4
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Pulling the belly pan off an Airstream is not difficult. Actually is one of the easier things to do in a flooring repair project.
Uwe
www.area63productions.com
Old 04-23-2004, 06:32 AM   #5
LOST , Hawaii
You will still have to pull the belly pan to get the old bolts out unless you cut the heads off, that is slow. Nutserts are OK of something has to be removed but will be a lot of extra work (and expensive) for a one time fastener. Dropping the belly pan also gives you a chance to look at the condition of the frame and insulation.
John
74Argosy24MH is offline   Reply With Quote
Old 04-23-2004, 06:52 AM   #6
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Craig,
From what I understand, it was a 70s thing, but just to make sure, I'd get a second opinion on that as I've never owned a 70s Airstream...just read a bunch from this forum and the folks that seem to have the issue are mostly in the 70s.
Eric
