Old 01-31-2011, 06:43 PM   #15
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Carriage bolts
Originally Posted by tvanwave View Post
Why cant plain old carraige bolts be used? Im redoing the back of a 1991 34' and the nuts are in the c-chanel and heads inside belly pan, wraps, and otherwise out of sight.
Tvan,
I think you can sure use carriage bolts in the C channel. I'm just going with the hex bolts in the C channel because they come in stainless and Fastenal stocks them on the shelf.
Lance
Top is offline   Reply With Quote
Old 01-31-2011, 08:07 PM   #16
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
You could use carriage bolts, however I use regular hex bolts with washers on both sides inside the "C" channels. I use elevator bolts through the floor where floor covering will be put on top.
Colin
Colin H is offline   Reply With Quote
Old 01-31-2011, 08:50 PM   #17
1968 20' Globetrotter
Kelowna , British Columbia
Look!! stainless elevator bolts! Elevator bolts at Bolt Depot
Just found this tonight.
BTW I found no need to drill the elevator bolts into my spruce ply flor. About 10 % spun, but I could grip the bolt below the nut with vice grips and continue tightening until the head pulled belw the flor surface.
Canlib is offline   Reply With Quote
Old 11-30-2011, 07:20 AM   #18
1981 31' Excella II
New Market , Alabama
I know this is an old thread but on my 81 the elevator bolts were screwed in from the top and the frame members were threaded. So you have to have some sort of head to be able to drive the screw down. I was able to find slot head elevator bolts from Mcmaster.com but the slotted heads were a pain to drive in without the bit slipping off. The phillips head bolts that AS used would have been better.
McMaster-Carr
Perry
elevator bolts
Correct size wheel for '75 Overlander 27' Denbear Wheels, Hubs & Bearings 5 11-01-2011 03:27 PM
Snap Size '65 Tradewind? P&A Upholstery, Blinds, Walls & Interior Finishes 2 07-16-2011 03:27 PM
POLL: AC BTUs, Trailer Size, and Climate Shiloh Furnaces, Heaters, Fireplaces & Air Conditioning 19 05-14-2011 10:51 AM
Tires and tire size KyMoonshine Tires 5 03-08-2011 04:28 PM
waterlines size qc1500 Fresh Water Systems 8 01-11-2011 06:04 PM
