Old 09-25-2015, 07:50 AM   #43
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Termites ate everything. Including the floor. I refuse a shell off!
Name:	ImageUploadedByAirstream Forums1443188865.579688.jpg
No reason regarding the heater itself, but it I think it might have worked better for my floor plan, and then I think maybe not...
On second thought, where it is is best.
Brevi tempore!
Old 10-01-2015, 01:40 PM   #44
CraigFulton's Avatar
1962 22' Safari
Saint Petersburg , Florida
Images: 53
Send a message via ICQ to CraigFulton
You guys are hijacking my thread with the heater! haha
Made some progress on the now shell off. Belly pan comes off tonight.
http://youtu.be/avRIpHurdCc
CraigFulton is offline   Reply With Quote
Old 10-01-2015, 05:18 PM   #45
1959 24' Tradewind
Twin Falls , Idaho
Wow, you've been busy. You have a crew helping you
Regards,
Tony
Trons4u is offline   Reply With Quote
Old 10-01-2015, 07:03 PM   #46
1962 22' Safari
Images: 53
One guy helped me get the panels off. But I just removed the belly pan myself in 2 hours! Haha. So easy. Now I have to clean and paint the frame, weld in the new rear cross member, and lift this shell. My plans on the lift are to screw in 3 2x6 beans side to side with 2x4 coming off diagonally on each side. Then use a post Jack to lift it from the ceiling and then install a 4x4 post on each end screwed to the 2x6 supports. Install floor. Lower it back down. I can then sleep at night. Haha
It only took 3 hours to get that interior out. I think I'm going to pressure clean it all before I start.
Old 10-01-2015, 07:06 PM   #47
1962 22' Safari
Images: 53
Any recommendations on floor wood? The 5/8" marine ply is $97 a sheet from a lumber yard special order. Home Depot has 1/2 and 3/4 in stock for under $50. Or do I just use standard ply??
Old 10-01-2015, 07:31 PM   #48
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I would use the special order then I would epoxy treat it all before cutting a single piece then epoxy treat all cut edges.
Or is Marine synthetic board.
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-01-2015, 08:07 PM   #49
1962 22' Safari
Images: 53
Leaning towards the 3/4 and I'll epoxy the cut edges.
Old 10-01-2015, 08:25 PM   #50
1988 Argosy 32
Lomita , California
I think i would take trailer back and the sleze bag to court for a refund,it may be past that point.
Wolfe is offline   Reply With Quote
Old 10-01-2015, 08:48 PM   #51
1962 22' Safari
Images: 53
Haha. I was going to do all this work anyway. I like taking things apart and putting them back together. I didn't pay much for it anyway.
Old 10-01-2015, 08:54 PM   #52
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Check a sample.. Marine Applications
Channing
WBCCI# 30676
Old 10-01-2015, 08:55 PM   #53
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Oh... Inspect wiring while you are that deep.
Channing
WBCCI# 30676
Old 10-01-2015, 09:02 PM   #54
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Oh.. Checking for leaks!!! Termite may get water from the ground where you live, but wood can rot if repeatedly wet. This is common AS failure.
Some folks are also having foam "sprayed" on inside to help seal and better insulate. Hey, it does get warm in FL and the shell will beat nicely in the sun.
Channing
WBCCI# 30676
Old 10-01-2015, 09:33 PM   #55
1979 23' Safari
Wayland , New York
Id try to match the original thickness a close as possible, otherwise you may have trouble getting it under the chanel in the front where the frame is a fixed spot and the shell is fixed by the rivets in the hold down plate. Good plywood from HD or LWS is ok, I'd try to get at least A grade on one side since it'll be smoother for follow on flooring application.
Old 10-01-2015, 09:40 PM   #56
1962 22' Safari
Images: 53
Yep. I see now. It's gonna have to be 5/8". I just measured at the hold down plate. Thanks for that!!
Shell on shell off? Newbie Dustycowgirl Repairing/Replacing Floor &/or Frame 28 03-12-2015 12:12 PM
Termites in my Trailer acbolton Winterizing, Storage, Carports & Covers 4 06-09-2011 08:36 AM
Shell on? Shell off? Althea68 Repairing/Replacing Floor &/or Frame 55 04-01-2011 09:35 PM
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 05:46 PM
Termites Rob Repairing/Replacing Floor &/or Frame 7 10-25-2002 08:56 PM
