Old 03-30-2003, 11:56 AM   #1
Angry Termite damage
I have a 67 27' overlander that has termite damage bad in the bathroom. I thought I would be able to patch in new plywood, But it looks like I have to go under the tub a little bit to get the support I need. I have the skin off the bottom, Which was shot, and the pan that was there is bad too. I'm going to take the holding tank out to have better access to the floor. Is there anything anyone can help me with, in reference to pulling the tank, and where to get some thin aluminum to replace the pan? Thanks for any help Skip Grandi
slowhand74 is offline   Reply With Quote
Old 03-30-2003, 05:31 PM   #2
Here is a supplier for aluminum:
http://www.yardstore.com/aluminum.htm
I know nothing about these people. I believe I got this link from these forums somewhere.
Mark
Old 03-30-2003, 06:21 PM   #3
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Should be able to find the aluminum local. Just pick up the local yellow pages or online yellow pages and look for "metal Supliers".
I think it was Phil/Sue that checked the thickness and said it was a odd thickness. I think but go and look and be sure, that they found it was .028 for the belly. It's proably in the interrior restoration section. There were doing a floor repair and had to drop the pan. It was within the last 30 days I think.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
brake-magnet damage Tin Hut Brakes & Brake Controllers 1 10-21-2003 09:12 PM
Extensive Damage JeffH Repairing/Replacing Floor &/or Frame 4 09-22-2003 07:58 PM
Frame Damage (Rust under water Tank klanke Repairing/Replacing Floor &/or Frame 3 04-06-2003 09:34 AM
Exterior Damage BRH Ribs, Skins & Rivets 1 12-07-2002 09:32 AM
ultra violet damage bhsl8 Tires 10 11-10-2002 04:03 PM
