Old 07-25-2012, 09:28 AM   #1
1975 31' Sovereign
Lecanto , Florida
Swap 75 sovereign shell to 00 excella frame
anyone know if it is possible to swap a 75 sovereign shell to a 2000 excella frame?
Silver_Flyer is offline   Reply With Quote
Old 07-25-2012, 12:24 PM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
2000 units are wide bodies. 75's are narrow bodies. The outriggers would not be the same. The 2000 frames are deeper and stronger, if you could get it to fit.
Old 07-27-2012, 07:35 AM   #3
Phoenix , Arizona
If you had the original frame as a pattern, you could have a new frame built to those measurements. I would use 6" structural channel rails with 3" structural channel crossmembers and outriggers. Angle iron could be welded onto the side of the 3" channel if you wanted something easier to attach to.
M2HB is offline   Reply With Quote
sovereign
