Old 07-16-2004, 05:40 PM   #1
JeepinAudiophile's Avatar
1968 24' Tradewind
Fort Myers , Florida
Images: 66
Send a message via AIM to JeepinAudiophile Send a message via Yahoo to JeepinAudiophile
Supporting shell to remove frame from below?
All the information i am reading seems to be different from what i need for my trailer. I have a 1968 Tradewind, the side skin panels continue below the u channel that attatches the shell to the frame, and is then pulled underneath and riveted to the frame on the bottom. Is it alright to only support the 24' trailer on the ends? I know i need to do some bracing, i asked in other posts but was not answered. I have all the bolts from the wheel wells-forward cut off, and am about to start on the rear. The weekends are the only time that my father is availabe to help on the trailer for any amount of useful time, so i need to have some information asap. If anyone has information on this style of shell-off restoration please help me out.
Tow Rig: 2005 GMC Sierra Denali AWD, 6.0L HO- LOTS OF UPGRADES to help Towing (and Fun)
Trailer: 1968 Tradewind 24', Land Yacht trim (Shell-Off Rebuild and upgrades)
***Missing from my life***
WBCCI # 13657
++Take a look at my restoration photo album++
http://picasaweb.google.com/ChadsAirstream
JeepinAudiophile is offline   Reply With Quote
Old 07-16-2004, 07:24 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
The skin panles usually do not continue, but rather stop just before the belly wrap.
Did you remove the lower rub rail yet?
Is there not a horizontal rivet line at the bottom of the skin?
I think you need to be more specific on what you're trying to do.
Basically, if you're planning a shell off restoration, then you might follow the threads on this.
Can you take some pictures of the areas in question??
I don't thin ksupporting a 24' shell end to end only is a good thing. The shell is a very flimsy and wobbly affair once the c-channel and floor is no longer attached to it.
Uwe
www.area63productions.com
Old 07-16-2004, 11:30 PM   #3
JohnG's Avatar
I would have to agree with Uwe on this. Please post some pictures and be more descriptive of what it is that you are trying to do.
Just adding my 2 worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 07-17-2004, 10:45 AM   #4
1968 24' Tradewind
Images: 66
Yes, i have removed the rub strip, i am working on getting photos up in the next few minutes. I did not want to support it from both ends, it seems like i am going to have to build an inner structure out of plywood that i can rest the trailer on.
WBCCI # 13657
Old 07-17-2004, 10:52 AM   #5
1968 24' Tradewind
Images: 66
See my predicament?
WBCCI # 13657
Old 07-17-2004, 10:52 AM   #6
JohnG's Avatar
I don't understand, why do you need to pull the shell off?
Are you replacing the frame itself?
John G
Old 07-17-2004, 10:55 AM   #7
1968 24' Tradewind
Images: 66
The panel continues 7.5" below the bottom of the channel that is attatched to the floor. (That is without measuring the extra piece of aluminum that is riveted to the end of that piece.)
WBCCI # 13657
Old 07-17-2004, 10:57 AM   #8
1968 24' Tradewind
Images: 66
I am going to sand-blast, and re-paint the frame. It also needs some welding repairs up front, and I assume the back under the bathroom needs major repairs.
WBCCI # 13657
Old 07-17-2004, 04:52 PM   #9
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
I'd still say you shold folow the threads on the frame-off repairs. There are currently 3 or 4 of us doing this, myself included.
The outer shell must be at some point attached to the c-channel, I would assume.
In your case, if the outer shell also forms the beginning of teh belly pan, then you just lift the shell a bit higher to clear things, or remove the axles and slowly drop the frame down low.
You will have to create a cradle of sorts to support the shell, and then lift it up to where it clears the frame. I would use 3 cross sections, wide than the frame, and support them to the ground. Now you can drive the frame right out from under the shell.
Of course, there are tons of rivets to remove, and many little hangups, including the interior lower skin sections.
Best of luck!
Uwe
Old 07-17-2004, 04:53 PM   #10
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
You know, I was going to do the same, but after cleaning the frame with a wire brush attachment for a small grinder, decided to POR15 it instead.
I've done some checking into the stuff, and it's perfect for rusty frames etc.
Uwe
Old 07-17-2004, 06:27 PM   #11
1968 24' Tradewind
Images: 66
I was confused because all the threads seemed to be using a different approach than i have to, since i seem to have an uncommon setup. I have come up with a way to lift and support the shell, but it took a little bit of planning. It's still not completely planned, but it's a start. We have slightly raised the front of the shell, and supported it for testing our ideas. i'll edit this, and post some pictures in a few minutes after i take a few more, and put them on the site.
WBCCI # 13657
Old 07-18-2004, 01:48 PM   #12
1968 24' Tradewind
Images: 66
No takers? I figured i'd bump it up to the top by posting, hoping to get some more info... Well, i guess it'll be useful to someone later on that runs into the same problems that i have.
WBCCI # 13657
Old 07-18-2004, 02:52 PM   #13
LOST , Hawaii
The one weak area when I lifted my shell was near the door. I lifted from the top and when I set it down it had a tendency to spread within a few feet of the door. I pulled it in using ratcheting tie downs.
John
74Argosy24MH is offline   Reply With Quote
Old 07-18-2004, 02:53 PM   #14
JohnG's Avatar
Well you have an interesting project to say the least.
You could weld the frame in places where it is not too close to the aluminum without removing the shell. You would just have to take a little precaution so the welding sparks are not able to hit the skin anywhere as they will burn right into it and maybe even through it.
The pieces of wood that you are using to keep the integrity of the unit the same look ok in the photos, but how are you lifting and supporting the shell?
John G
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 06:46 PM
HELP! Don't Make Me Pull The Shell Off! funchucky1 Repairing/Replacing Floor &/or Frame 32 04-25-2004 03:44 PM
shell removal... nevisstudio Ribs, Skins & Rivets 2 01-27-2004 12:08 PM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 11:21 AM
