Old 07-18-2004, 02:17 PM   #15
JeepinAudiophile's Avatar
1968 24' Tradewind
Fort Myers , Florida
Images: 66
Send a message via AIM to JeepinAudiophile Send a message via Yahoo to JeepinAudiophile
We are bracing it like seen in the photos to the ribs in 4 places, the 2x4's attacthed to them are level with the outer-skin panels in those places, we plan to lift up the shell, and place a pair of 2x8's in the rear and front just under the ends of the 2x4's. There are 2 2x6's that will be attatched along each cross brace setup, and attatched using screws. This should strengthen the center, allowing us to lift, and rest the entire shell by only the front and back. This is because these are the only places that we can have a board protrude all the way through the shell and out both sides. I'll take a few pictures of what we have so far so you can have an idea of what we are doing...should be up in a few minutes with pics.
Tow Rig: 2005 GMC Sierra Denali AWD, 6.0L HO- LOTS OF UPGRADES to help Towing (and Fun)
Trailer: 1968 Tradewind 24', Land Yacht trim (Shell-Off Rebuild and upgrades)
***Missing from my life***
WBCCI # 13657
++Take a look at my restoration photo album++
http://picasaweb.google.com/ChadsAirstream
JeepinAudiophile is offline   Reply With Quote
Old 07-18-2004, 02:35 PM   #16
1968 24' Tradewind
Images: 66
The 2x6's are just resting there, the 3 other x-braces are going to get the same vertical 2x4's the front did, we are going to do the rear one first, screw the 2x6 up, the put the center 2 2x4's up, assuring alignment, then screw it all together. We are going to cut holes in the floor to allow the rear 2 2x4's to drop below the level of the floor, to the same level as the enge of the skin. We will then jack it up with a crow bar, and stick a piece of wood under it to hold it above the floor. With this, the shell should be detatched from the frame. At that point, we will decide how we plan to lift the shell the rest of the way that it needs to be lifted to get it up on the saw horses we are building right now.
WBCCI # 13657
Old 07-20-2004, 07:30 PM   #17
1968 24' Tradewind
Images: 66
I have an update on the project in another thread... here's the link.
http://www.airforums.com/forum...ad.php?t=12318
WBCCI # 13657
Old 09-20-2004, 05:52 PM   #18
1968 24' Tradewind
Images: 66
Okay, here's a summary of what has been happening: The frame additions are mostly welded up, all pieces are atleast tack welded to the frame, awaiting a finishing bead! One tank frame is done with the tank sitting in it, held in place with clamps for a mock fitting. The second one (almost identical) is hopefully going to be welded up this weekend. I am sanding/grinding/pressure washing/wire-wheeling/strippiong the frame in preparation of a coat of POR-15. I am going to concentrate on the exposed ares this weekend to get them down to a surface that is smooth enough for my liking. things have been slow with the trailer because so many other things have been happening on the weekends with rallies, holidays, etc...
I hope to have pictures up on here in the next few days of the progress!
WBCCI # 13657
Old 09-20-2004, 06:27 PM   #19
1968 24' Tradewind
Images: 66
here's a start!!! This is the beginning of the welding process after we took off the original lower piece of metal and added a slightly taller piece to cover for the additional depth of the new tanks.
Here's a test fitting of the new 35 gallon tanks in the outer frame we made for the tanks, which will be concealed in a sheet metal box and insulated.
Here's the old tank with the new tank... 17 gallon vs. 35 gallon!!!
marking and cutting the galvanized sheetmetal for the tank enclosure...
Here's the metal all cut, folded and riveted and sitting inside the outer frame...
Mock up of the rear tank location... held in by clamps.
measuring and cutting the frame stiffeners that also extend the belly of the trailer to enclose the tanks...
Tank inside the tank enclosure, mocked up in the frame... notice the frame is tacked up all the way to the rear axle now...
More to come this week, these are all a few weeks old...
WBCCI # 13657
Old 09-21-2004, 10:09 PM   #20
1968 24' Tradewind
Images: 66
okay, i'm going to have to find a new host for the pictures... give me a few days
WBCCI # 13657
Old 09-22-2004, 09:47 AM   #21
Over59's Avatar
Putnam , Connecticut
Images: 37
What are the dimensions on that 35 gal tank?
Over59 is offline   Reply With Quote
Old 09-23-2004, 10:14 PM   #22
1968 24' Tradewind
Images: 66
Here's the dimensions...and the website...
http://www.tank-depot.com/id/85468/group/300/dept/69/
WBCCI # 13657
Old 09-23-2004, 10:15 PM   #23
1968 24' Tradewind
Images: 66
Sorry everyone, I have had absolutely no time to get on here and get the pictures up... i am hoping to get some up at the end of the weekend! Sorry, Chad
WBCCI # 13657
Old 11-23-2004, 10:19 PM   #24
1968 24' Tradewind
Images: 66
The sky is falling!!! Or maybe it's just the shell being lowered back onto the completed floor.... YAY, i really will try to get pictures up soon, also all the ones I had in the first portion of this have seemed to disappear...hmmm, picture hosting problems i see...
WBCCI # 13657
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 05:46 PM
HELP! Don't Make Me Pull The Shell Off! funchucky1 Repairing/Replacing Floor &/or Frame 32 04-25-2004 02:44 PM
shell removal... nevisstudio Ribs, Skins & Rivets 2 01-27-2004 11:08 AM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 10:21 AM
