Old 07-24-2015, 12:15 PM   #41
Wow that looks great. I didn't realize until just now that you'd sold your Overlander and had a new project. Suffice to say, I'm subscribed. Good luck!
Old 07-24-2015, 08:16 PM   #42
truckasaurus's Avatar
1960 33' Custom
Athens , Georgia
yup, sold but still local. The new owners are putting a ton of miles on the Overlander and should be down in Texas next month and then Florida before coming back home . I on the other hand will be spending the next couple of years or so getting this bad boy travel ready.
This week I had an OCD defining moment as I was Bondo'ing any defects under the floor, before base coat, before top coat and before rubberized undercoating.
I also picked up some C channel I'd had bent up; I paid a few dollars to get it all made up in 8' lengths.
Lastly I'd tracked down 5052 H32 in .032' 5' x 10' too but when I went to pick it up it became all too clear that ham fisted delivery muppets had ruined my plan. I'm now torn between a belly pan skinned in 4' x 10' sheets or going to .050" in 5' x 10's which is apparently more muppet resistant. I'm thinking smaller sheets right now for ease of dropping sections but thought I'd mull it over.
ID:	243837   Click image for larger version
truckasaurus is offline   Reply With Quote
Old 07-25-2015, 06:43 AM   #43
I like the idea of smaller sheets. Airstreams were originally all sealed up and made self-contained for people that just wanted them to work from day 1. But you're a tinkerer and will probably want to get in there at various points for various reasons.
I still haven't ever put in the bellypan back on mine, and I like having access to all of the underneath.
Old 07-25-2015, 07:32 AM   #44
Central , Mississippi
I've done a couple of new bellypans with 4 x 10 sheets. I do the center by using the sheets sideways, 4' wide, just like the plywood is lay'd out on the top. I stop each piece at the frame rail. Then the 10' length is used to make the rolled edges. This way if I ding up a side piece, it's a single part to replace and not a complete belly section.
This also makes it easier to do plumbing work since the center sections can be installed with cleco's, waiting for the final riveting until the very end of the project.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 07-25-2015, 07:47 AM   #45
1960 33' Custom
Athens , Georgia
Awesome, that's exactly what I have in mind. The narrow sheets are only $49 too which is very appealing.
Old 07-26-2015, 09:45 PM   #46
1960 33' Custom
Athens , Georgia
ready
New C channel ready to be cut and formed into curves. I'm thinking of making a bucket saw with a jigsaw to speed things up a bit as I don't have a bandsaw. I'm also considering cutting the slits from the outer leg towards the inner leg rather than inside out; if that makes any sense.
I had a few free minutes so I test drilled a hole in spare steel box tube to fit a floorboard screw. Good job I tried one out, I ordered and paid for 1/4 screws and got 5/16" fasteners. Still, now I know it's all good. Torx T40 here I come.
Old 08-03-2015, 07:58 PM   #47
1960 33' Custom
Athens , Georgia
up and running
Floor on! 200 x layout fastener, pilot, drill steel, countersink MDO, drill MDO, apply sealant and wet install self tapping screws. I finished up on the floor by sealing it up a bit with rubberized undercoat.
Today I slotted the C channel and gave it all a prime coat ready to install next.
It's starting to look pretty decent so on went the locks.
ID:	244503   Click image for larger version
ID:	244505   Click image for larger version
Old 08-04-2015, 11:07 AM   #48
nice work
Old 08-30-2015, 03:17 PM   #49
1960 33' Custom
Athens , Georgia
I little bit of cardboard for mocking up the aft kerb side belly pan, not too tricky considering it's a 6" height rather than the original 4".
I'm going to drop the shell onto the c channel for a test fit before going all out on the BP.
Also mystery shot of the day is my newly shortened bow and the off cut to be relocated forward one bow....
ID:	246805   Click image for larger version
Old 09-13-2015, 07:45 AM   #50
1960 33' Custom
Athens , Georgia
Touch down
Time to get the shell on. We got the gantries together and lifted the shell, this time with ladders for the bracing, nice and light yet rigid.
Backing through a narrow gate to position the frame between gantries was fun...
It all went pretty well and with the thickness of the belly pan next time should be spot on.
I like the look of the new axle location 2 feet aft of original but have yet to get a tongue weight.
Ready for a giant tarp :-)
ID:	247970   Click image for larger version
ID:	247972   Click image for larger version
Old 09-13-2015, 10:09 AM   #51
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Looking good
Old 03-05-2016, 01:39 PM   #52
1960 33' Custom
Athens , Georgia
it's nearly spring
I guess it's not really spring but it's starting to feel closer; so I thought I'd start stocking up on supplies. (I always seem to leave buying some parts too late and they're back ordered or obsolete, I was really surprised to see clearance lights disappear off the face of the planet). A large box arrived from VTS with all the window gaskets, some polishing supplies to prep end cap segments for dent removal on my English wheel and a $15 lock cylinder. Not the worst way to drop $800 Canadian but it was the lock cylinder that proved the most rewarding.
I found a locksmith willing to undertake the Bargman L77 work and for $100 he straightened it all out and fitted the VTS lock cylinder plus 2 extra keys. Now I have a slick lock and gave it a quick polish with Autosol after removing the latex paint.
I'm getting ready to order glass for all the windows and have settled on 3MM tempered, but keep flip flopping between clear and a light grey tint. Tint makes sense to keep heat out but just doesn't seem to look right on the vintage trailers.
ID:	258201   Click image for larger version
Old 05-08-2016, 04:10 PM   #53
1960 33' Custom
Athens , Georgia
A step back then forward
I switched out most of the C channel that I'd installed for a heavier duty version made from 5052 H32 .050". The skinny stuff was just flexing too much with the belly pan attached to even have a hope of lowering the shell down. Trying to see the silver lining of a step back I ordered much more than I need for the C channel so that I can use it to stiffen the walls and roof too :-)
I made up 6 hold down brackets from 3/16" and 1/8" steel and POR'd them for install with 5/16" Bolts.
Lastly I had a go at the rear belly pan, It's quite time consuming being a new 6 inch frame but I like how it looks in it's current un trimmed state. I'm going to cut the side skins wheel well cut outs to the style of an Ohio trailer rather than Cali so I need a bit extra sheet to play with.
Pics of both sides, still in protective plastic.
ID:	262156   Click image for larger version
Old 05-11-2016, 08:22 PM   #54
I'm glad to know that you were able to recreate the corners with a 6" frame. I'm headed that way on a future project. Good looking work!
Old 05-12-2016, 07:18 AM   #55
Tbeck11931's Avatar
1990 34' Limited
Conroe , Arkansas
Looking great please keep us posted.
I really enjoy the pictures.
Tbeck11931 is offline   Reply With Quote
Old 05-15-2016, 05:28 PM   #56
1960 33' Custom
Athens , Georgia
Belly Pan corners DIY guide
I just thought this might help someone out.....
I used scrap art paper and made a template on the trailer itself, I taped it to the frame and used a bunch of clamps to secure it to the C channel.
When it looks decent, remove and use to template the sheet metal
ID:	262582   Click image for larger version
ID:	262585   Click image for larger version
Old 05-15-2016, 05:36 PM   #57
1960 33' Custom
Athens , Georgia
stage 2
Next I used whatever was lying around to locate the aluminum where I wanted it on the frame rails and pinned it down with one 1/8" cleco in each outrigger.
Now just roll the sides up to the channel and secure then pull the remaining metal tight and temporarily secure to the channel.
I've left the plastic protection on and a bit of masking tape but I think after a trim it's going to look great.
I was worried that it just wouldn't work well on a deep frame but the front was a cake walk compared to the rear.
Next weekend I'll pop the side sections on and maybe a trim piece at the front and rear then it'll be time for the removable centre sections to be made up.
ID:	262590   Click image for larger version
ID:	262592   Click image for larger version
Old 05-15-2016, 08:55 PM   #58
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Wow, that looks really nice!
Rocinante is our 2014 International Signature 27FB
Old 05-16-2016, 06:05 PM   #59
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
I think you can quit your day job now
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 05-28-2016, 08:31 PM   #60
1960 33' Custom
Athens , Georgia
Slow progress
I got the oversize front hold down in place and final installed the aft belly pan curved sections. It went pretty well and sits really flat with 3M tape and 3/16" pop rivets.
I'm questioning whether I want to fabricate the aft centre section that wraps up from the belly to shell. As my chassis has a 6" x 2" tube crossmember there adding aluminum belly pan skin is really doing nothing but potentially trapping moisture. I whipped up a filler strip instead to see how it would function. Ultimately I thing the floor is well protected at that point but I can always revisit the pan there when I replace the outside body sections.
Pic of 142 linear feet of .032" T3 2024 Alclad boxed up. That's all the exterior save the compound segments. My trailer has multiple sheets joined together as it's quite long but I'm switching it out for longer sheets, 22', for a smoother leak free look.
ID:	263402   Click image for larger version
ID:	263404   Click image for larger version
1960, atomic, frame, new chassis, rebuild, shell off, skin, sovereign, vintage
1973 Silver Sovereign 31! AIRSTREAM. LOW RESERVE S1973 Silver Sovereign 31! AIRSTREAM eBay Watch Airstreams on eBay 0 09-22-2011 11:20 AM
'76 Sovereign Floor Replacement-2 gronlampa Repairing/Replacing Floor &/or Frame 0 07-24-2011 08:58 PM
