Old 02-16-2014, 01:27 PM   #1
huntingdon , Pennsylvania
subfloor under door frame
can i remove the subfloor under the door frame by taking out the two big screws going down through bottom of the door frame?
or do you need to remove the whole door for this?
thanks
kokomoscalls is offline   Reply With Quote
Old 02-16-2014, 02:50 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
You should not need to remove the whole door. You will need to take out the 2 big screws. They hold the bottom of the door frame to the outriggers underneath. Try to remove the piece of plywood intact and use as a template to cut the new piece of plywood that will replace it. The plywood will need to be notched for the door frame or it won't fit. Voice of experience...
Chris
Minno is online now   Reply With Quote
Old 02-16-2014, 07:27 PM   #3
ok thanks alot i will try that...
also the rivets for the lower skin...there are a couple behinf the inside door frame ..can i just roll it back to the door to get to the bolts in the c channel?
