Old 07-27-2015, 02:40 PM   #1
ASTailgate's Avatar
1981 28' Airstream 280
Subfloor question
I recently purchased a1989 excella 1000-34ft trailer. Does this trailer have the issue of leaking water through the rear bumper and require the l shaped aluminum fix?
ASTailgate is offline   Reply With Quote
Old 07-27-2015, 07:23 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
You might be able to poke the subfloor by reaching up through the rear bumper storage compartment. Your trailer and mine have OSB subfloor material, not the best for wet conditions. Our trailers are not known for water intrusion at the joint between the rear of the shell and subfloor like the 70s or mid 2000s. Check to see if your subfloor is getting soft back there. You might be able to gain access to the rear subfloor under the beds or furniture at the rear of the trailer. Again, check for a soft floor.
BUT, the rear joint does get a lot of water pressure during a rain storm. You might consider removing the trim piece at the rear, and caulking the rear seam to help avoid water intrusion.
David
Subfloor replacement Question dartagnan Repairing/Replacing Floor &/or Frame 13 01-04-2014 08:52 AM
Streamline Subfloor Question. maggieevans Vintage Kin 1 05-18-2013 12:29 AM
Caravel subfloor replacement self tapping screw question knishiya Repairing/Replacing Floor &/or Frame 4 02-23-2013 05:05 PM
Finally starting the project!! Subfloor question.. 61safari Repairing/Replacing Floor &/or Frame 18 11-21-2011 08:34 PM
