Old 10-27-2014, 09:05 PM   #1
1977 31' Sovereign
Walloon Lake , Michigan
Subfloor plywood and strength
I am quite new to the RV world and my first unit is a 77 Sovereign center bath unit. The subfloor is quite solid but it is only 1/2 inch plywood and not 5/8 or 3/4 as some people have reported on the forum. I like the idea of strength and have read several related topics on epoxy etc. Would epoxy alone like the west system substantially increase the strength if I were to treat the entire floor? Another idea is to epoxy the original 1/2 inch and overlay another 1/4 or 3/8s or even 1/2 inch plywood. A alternative would be to use real hardwood flooring (maybe 1/2 T&C instead of 3/4) and glue it down. It has carpet now and that's going to go. I am looking for thoughts and ideas. Thankyou.
wallooner is offline   Reply With Quote
Old 10-27-2014, 09:24 PM   #2
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
This is the crux of every decision an RV owner has to make, trailers or motorhomes, but especially trailers.
How much weight can I add, and where? In the case of trailers, where you put weight will and can affect tow ability, fuel economy and stability.
Your floor was never intented to be as strong as the floor in your home. It was meant to be light but strong enough floor to meet the needs of users. Adding epoxy to the floor on one side only will not add any strength at all. If anything it will add instability to the floor by encapsulating any moisture that enters the floor and possibly cause the floor to warp and heave as one side will expand and contract at a different rate than the other.
If you wish to put another flooring substrate on top I would consider a laminate or engineered hardwood flooring with cork backer as solid wood expands and contracts far too much for RV's. You couldn't glue down a hardwood floor anyway as it would eventually break the glue bond and start heaving. I wouldn't glue the flooring down as it would be easier to replace or repair if it's floating. I used a Torly's Everest Maple engineered flooring myself with 4 1/2 wide boards by 60+" and 36" long. You can even get boards 6 1/2" wide by 72+" long which would add strength. I however have a Classic motorhome so towing doesn't concern me, but weight did.
Just remember to try and think RV, not what you would do in your home. Two very different animals.
Cheers
Tony
What type of plywood is best to use for the subfloor? solarstream Floor Finishes 16 06-22-2016 09:49 AM
marine plywood vs plywood vs osb bweldon Repairing/Replacing Floor &/or Frame 35 07-13-2015 07:29 AM
Help choosing subfloor plywood and protection method AtlasCoffee Repairing/Replacing Floor &/or Frame 30 06-16-2013 02:54 PM
Man-made subfloor? No Plywood please.... Zstream Repairing/Replacing Floor &/or Frame 25 08-17-2008 04:15 PM
Subfloor - Replacing Rotted Plywood traveller_nc Repairing/Replacing Floor &/or Frame 11 06-14-2007 11:00 PM
