Old 08-27-2010, 12:17 PM   #15
1965 26' Overlander
Sub-floor cut to size, sealed four times over on both sides and is ready to be screwed into place. Amazing what you can still accomplish when the heat index tops out at 110...
Name:	Airstream Sub Floor.jpg
Llano is offline   Reply With Quote
Old 08-27-2010, 12:24 PM   #16
1965 26' Overlander
And on a related matter, any suggestions on covering those wheel wells? Am considering building two light "boxes" to cover/protect each and to be hidden under the yet-to-be build kitchen and seating.
Old 08-27-2010, 06:54 PM   #17
Bauxter's Avatar
1973 31' Sovereign
Columbus , Ohio
Did you end up using the marine grade, or the CDX?
Bauxter is offline   Reply With Quote
Old 08-27-2010, 08:40 PM   #18
Just wondering, is there a reason you want to cover them? Is it aesthetic, or do you have something else in mind?
If you're going to build out the interior with furniture that is identical or close to the original configuration, then the wheel wells will be entirely hidden within the furniture anyway. If you have another interior plan in mind, one that exposes the wells, then I suppose covering them with something could be a good idea.
I just painted mine with rubberized underbody coating. They are hidden under the beds and cabinets anyway.
The subfloor looks great, please do keep us posted on your progress.
Old 08-28-2010, 05:23 AM   #19
1965 26' Overlander
Alas the budget did not allow for the marine. Maybe I should have sealed each side EIGHT times!
Old 08-28-2010, 07:15 AM   #20
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
One reason that comes to mind for covering the wheel wells is that it allows an area between the inner and out to install insulation.
SilverHoot is offline   Reply With Quote
Old 08-29-2010, 03:54 AM   #21
Bauxter's Avatar
1973 31' Sovereign
Columbus , Ohio
I am going to take the non-marine plywood approach, as well. I have been seeing BCX mentioned in several different forums, and may go that route. Marine sounds awesome, but when the better-half reminded me of budget realities, I decided to use an alternative....like you, I will be sealing, and re-sealing. I don't think that I would consider pressure treated, as I have never really liked that product.
Old 08-29-2010, 09:47 PM   #22
1965 26' Overlander
Pressure treated worried me because of the fumes. I've built one too many decks and know how nasty that stuff is.
I want to cover the wheel wells because I plan to incorporate them into the storage I'm building. I hadn't thought of insulation but that's a great idea. One frame built today and the other easily knocked out this week. Even found perfect salvaged lumber at a neighbor's kitchen remodel!
Old 08-31-2010, 08:04 AM   #23
1965 26' Overlander
Wheel well covers complete. Now, about those walls...
Name:	airstream wheel well covers.jpg
Old 08-31-2010, 09:40 AM   #24
1978 31' Excella 500
Tuttle , Oklahoma
Sub Floor
You should have no concerns with your floor.
If you do a little research you will find marine and exterior ply use the same glue. The difference is in the quality of the plies themselves.
In order for it to be "marine grade" it has to meet a higher standard for voids and patches on the veneer used to make the plywood and typically the exterior plies look nicer.
None of the differences matter for use as sub-floor and do not warrant the considerable cost difference IMHO.
1bbboomer is offline   Reply With Quote
Old 08-31-2010, 10:15 AM   #25
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
I found marine (supposed) quality plywood to be gorgeous to look at and work with - but when it came time to screw it down to the frame those eight void-free layers had as much body to them as wet paper towels - many screws buried themselves under the top ply before any real resistance was felt, I was unable to have all the fasteners draw down to anywhere near the same torque.
If I had it to do again I would look for a scaffold-grade OSHA registered plywood, and failing to find that or similar visit the real lumberyards & construction suppliers in this region and have them consult the 'books' to get the facts on composition trade-offs...
Pressure treated is corrosive and kills metal except fasteners designed for it.
Old 08-31-2010, 11:50 AM   #26
BWH-Utah's Avatar
1965 22' Safari
Salt Lake City , Utah
What did you use to "seal" the plywood with?
I have long been a fan of a 50/50 mixture of Cuprinol and Boiled Linseed Oil.
Seems like if you are going with the original glue down 1ft by 1ft floor tiles
the off-gassing of the glue would be as big a concern as the sealant/preservative.
Plus, once the tiles are glued down they will certainly minimize off-gassing migrating
into the trailer.
Any opinions on this approach?
BWH
BWH-Utah is offline   Reply With Quote
Old 08-31-2010, 02:22 PM   #27
Wabbiteer's Avatar
1972 29' Ambassador
Cuprinolgets its name from "Copper in Oil" - copper and aluminum, copper and steel do not mix. I agree your 50/50 mix is easy working and long lasting but has no place in a forever inhabited installation constructed of pre-aged and completely consumable metals...
Old 08-31-2010, 02:35 PM   #28
1965 26' Overlander
I painted thick coats of exterior polyurethane on both sides and the edges of the boards previous to installation. Off-gassing has been an issue but hopefully not an enduring one. At least it overpowers the previous funky smell...
Insulation between floor and belly pan. What to use? 68Glbtrotter Repairing/Replacing Floor &/or Frame 32 12-29-2013 04:15 PM
Belly pan off or on ? augier Belly Pans & Banana Wraps 6 08-08-2009 02:04 PM
cut the floor or drop the belly pan? LI Pets Repairing/Replacing Floor &/or Frame 12 09-27-2006 04:49 PM
where belly meets floor meets shell JrnymnJay Repairing/Replacing Floor &/or Frame 6 01-09-2006 12:05 PM
floor and belly replacement (shell off) cdmagda Repairing/Replacing Floor &/or Frame 10 11-13-2004 05:43 PM
