05-16-2011, 12:10 PM
1972 27' Overlander
Clarksburg
, Missouri
Sub floor type
Do I have to use marine grade plywood or can I just use something else?
05-16-2011, 12:16 PM
1954 25' Cruiser
Cruisin
, Wisconsin
Some people use marine grade, I lust used a good 7ply standard plywood about $27/sheet and treated the top, bottom and edges before installing. That is more then the factory did and mine lasted 50 years.
05-16-2011, 12:17 PM
1972 27' Overlander
Clarksburg
, Missouri
Did you use tongue and groove?
05-16-2011, 12:35 PM
1954 25' Cruiser
Cruisin
, Wisconsin
I did not but that would probably be better, I reinforced the seams underneath. I would reinforce the tongue and grove also if not on a cross member and glue the seams.
05-16-2011, 01:21 PM
1972 27' Overlander
Clarksburg
, Missouri
How did you reattach the plywood to the frame?
05-16-2011, 01:42 PM
Klatawa (to travel)
1965 24' Tradewind
Bremerton
We just completed a 1965 Tradewind, we used marine grade ply for two reasions; first it has a very smooth surface and if you plan on laying down any type to tile of lunoleum any uneveness will show. The second is marine ply has no pops or voids in the laminations which you can not see untill you step on a spot and it caves in. I am not saying that you can not use a good grade of plywood the choice is yours.
I used 1/4-20 carrage bolts to fasten the floor to the frame, not wure what they used in 75. I then glued and screwed a 1/4 inch plywood stip at each joint of the plywood. I think with this reply our attachment to a photo bucket shows the entire rebuild of our 1965 Tradewind and some the floor replacement.
Dave
Klatawa
(Dave & Debbie)
1965 24' Tradewind
2015 Chev Silverado HC
05-16-2011, 01:55 PM
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
Vintage Trailer supply sells self drilling and tapping screws that work well for attaching the plywood subfloor to the frame. They work blind ( where you can't reach below to use a screw and nut). On my trailer I found I had to bear down hard to pull them flush with the subfloor and in doing so some were stripping out their threads. To remedy this I pre-drilled a hole and using a countersink made a divit in the plywood for the head of the bolt. Thusly, when I installed the bolt I didn't have to bear down as hard and they tapped themselves and pulled the head nicely flush with the plywood. There are probably other types of screws that will work as well but if you have to order any stuff from VTS these screws are a good choice.
Good luck with your job.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
05-16-2011, 06:18 PM
1983 31' Excella
2005 30' Classic
1993 33' Land Yacht
Wellfleet
, Massachusetts
What thickness is the plywood ? 5/8 or 3/4
Don
05-16-2011, 06:47 PM
1958 22' Flying Cloud
Folsom
I used 5/8, but wish I would have used 3/4". 5/8 seems flimsy.
05-16-2011, 07:07 PM
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
I used 3/4" MGP. It was around $60 per sheet. I coated it with West System epoxy and Deftahne polyurethane floor finish. There are higher grades of MGP that use meranti veneers. They are generally above $100 per sheet. If you use a high quality exterior grade plywood and completely coat it with epoxy, you'll have a floor that will last and
last. I attached the new flooring with 1/4"-20 stainless steel elevator bolts from Fastenal. I used 1/4"-20 stainless steel hex head bolts through the C channel. I used the self drilling/tapping floor repair screws similar to what VTS sells with mediocre results to patch a few areas. They strip too easily.
Lance
05-17-2011, 12:08 AM
Tool Hoarder
West
Just picked up my MGP today. I went with the Aquatec Maranti 5/8. I toyed with the idea of 3/4 but the added weight was a concern. Also like Top I am useing West Systems Epoxy for the edges.
05-17-2011, 06:15 AM
1955 22' Safari
Great Lake State
I went with 3/4" AC plywood at $44.00 a sheet, a few small voids by the same water proof glue used in marine plywood, marine plywood to me is a waste of money, your not building a boat..........
toastie
05-17-2011, 06:26 AM
1955 22' Safari
Great Lake State
Try these, use a Forstner bit to countersink the head fully.
Floor Repair Bolts
toastie
05-17-2011, 07:00 AM
pottsboro
I used mdo 3/4" which is a exterior 7 or more ply that is coated on both sides. We use it for form boards for concrete walls and it last. I used it on the bed and sides of a flat bed trailer i have and that was ten years ago (no delamination and it sits out side in all weather conditions).
Used it on the floor replacement in the back end of our airstream no worries.
05-17-2011, 07:35 AM
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
I also used 3/4" ext. grade. If you need to slip it into a "C" channel it will help to use a router and shave off a bit from the edge down to about 5/8" so it will slip into the channel. I also took a roundover bit and gave the channel edge a roundover on both sides. I think it will make it go into the channel easier. Gives the floor a good stable feeling when you walk on it. I also chose to re-enforce the spans between frame rails with a strip of plywood screwed below. Makes a nice secure joint, reduced movement and floor squeaks as you walk on it. I didn't glue it but that would be a good thought.
Roger in NJ
TAC - NJ 18
