Old 06-02-2013, 01:44 PM   #1
crabbey1's Avatar
1976 Argosy 22
Pasadena , California
Images: 33
Send a message via AIM to crabbey1 Send a message via Skype™ to crabbey1
Sub-Floor Removal: Bolts Under Door Frame
Hey guys! My sub-floor replacement is going well, but I ran into a small issue. On my 1976 Argosy 22', the second section back of flooring has 3 bolts that hold it into the frame under the door frame. I cannot see the top of the bolts, I can only see the nuts under the frame from the bottom.
If I cut the nuts off the bolts, will i be able to punch them up through and release the small section of flooring left in the trailer? If I do that, how can I replace them in the new flooring? Any other thoughts suggestions?
Note: This is a shell on floor replacement. Also, I am doing this all without taking the bell skin off. Thanks.
ID:	187204   Click image for larger version
ID:	187206   Click image for larger version
crabbey1 is offline   Reply With Quote
Old 06-02-2013, 02:00 PM   #2
cameront120's Avatar
1972 25' Tradewind
Do a search for 'elevator bolts' and you'll find all the information you could ever want. Good luck!
North Vancouver, BC
Old 06-02-2013, 03:07 PM   #3
1973 25' Tradewind
Beautiful , Oregon
Multi Tool by Fein
Will make your life much easier throughout your work
I never thought much about it. Thought it was a Toy for weekend warriors
(which is fine) but no it is an incredibly useful tool
Good Luck
Tony
Tony S is offline   Reply With Quote
Old 06-02-2013, 03:40 PM   #4
crabbey1's Avatar
1976 Argosy 22
Images: 33
Tony - I have been using a Dremel to cut the E-Bolts off. No biggie. I just wanted to make sure that these are ok to remove. Thanks for your help.
