Old 05-20-2010, 09:15 AM   #1
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Sub Floor
I need to order the sub floor for the Bathroom in my 71 Overlander. What size or Marine Grade plywood do I nee to order? Is 3/4 my best bet or do I need to order something else. No one has the stuff in stock so I want to get it right the first time.
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 05-20-2010, 12:13 PM   #2
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Can I use CDX plywood - What is everyone's recommendation. Marine 3/4 is $80.00 a sheet and I will have to wait until it comes in. CDX i can get right away. But, what do I need to do to the CDX for proper water sealing? Help
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
Old 05-20-2010, 12:23 PM   #3
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I used 3/4" marine grade plywood in the rear bathroom of my '72 Sovereign. I figure if it's good for boats, it's good for my Airstream.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 05-20-2010, 12:35 PM   #4
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
And just to argue the point we used BCX 3/4" plywood in our '72 Sovereign, and sealed the edges of each sheet before installing it. In my opinion, both will work just fine. But if you're at all concerned with water issues down the road, and since you only need one sheet, you might as well get the marine grade if the cost is ok for you.
Chris
Old 05-20-2010, 01:05 PM   #5
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
For a bathroom area (especially!), I would only use marine grade. Do you really want to do this again later? I think not...spend the 80-bucks, it's worth it!
This may help you better understand the differences in the types of plywood:
Plywood Grades
In addition, the different letters indicate the number & size of knots & voids that are allowed:
More on Plywood Grades
Shari
Old 05-20-2010, 01:35 PM   #6
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Thanks - It is a hour drive to get the Marine grade - just did not know if it was worth ordering and driving a hour to get it.
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
New Floor Airdaddy Floor Finishes 11 07-10-2009 06:54 AM
My new floor The Flintstones Floor Finishes 16 09-01-2007 08:03 PM
Need a new floor jlester Repairing/Replacing Floor &/or Frame 15 01-11-2005 08:04 PM
New Floor - Before, during and after TroutStream Floor Finishes 10 07-23-2004 06:26 PM
