Old 01-05-2016, 06:51 PM   #1
Sub floor
Is it true you have to remove the wall panels to access the plywood subfloor? I do not see any screws I would need access. Thinking I could cut down middle and rip out
paulmichie is offline   Reply With Quote
Old 01-05-2016, 07:02 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
An Airstream is a semi-monoqocue. The walls, floor and frame are all structural members. The floor is attached to the C channel and so are the walls to get to the C channel you have to remove lower inner skins. How much floor do you want to remove and what is the year and model of your Airstream?
Old 01-05-2016, 07:16 PM   #3
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
You will have to remove the inner skins to get to the bolts through the c-channel (at the tip of every outrigger). I also removed the wraps (outer skin below the belt line that wraps from the side down to the belly pan). I had to replace so many outriggers... But you need to anyways, to be able to hold the nut as you tighten the new c-channel bolts.
-Red, master of the belly pan...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 01-05-2016, 07:19 PM   #4
Panama Red's Avatar
Obrien , Florida
Also, be very careful "ripping down the middle". My waste tanks are very close to the plywood... But mine's a center bath. Not sure what you have.
-Red, reliving the rebuild...
Old 01-05-2016, 07:26 PM   #5
1970 sovereign
Old 01-05-2016, 07:27 PM   #6
Floor in bathroom, kitchen area, front window all rotted out
Old 01-05-2016, 07:45 PM   #7
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
I would say the floor is the C channel filler between the wall and the frame. You really won't get an increase in stiffness with such a thin layer of OSB or plywood with large screw down spacing. You need solid wood in that C channel.
You would need to decide how much frame and wood floor repair you need to do. Certainly a wood floor and or frame can be repaired without removing the skin. My 2 cents.
sgschwend is offline   Reply With Quote
Old 01-05-2016, 08:26 PM   #8
Panama Red's Avatar
Obrien , Florida
Sub floor
Paul, you're probably going to run into quite a bit of frame repair to go along with the floor repair. Dig up my thread, "Resurrecting Big Bertha" on here... I replaced the rear eight feet of floor, the front six feet of floor, and a lot of steel in my frame. The outer skins are attached to the c-channel, and the C-channel is held to the frame by the bolts at the end of each outrigger. If you're going to all the work to replace the floor, which will involve removing the kitchen and bathroom, pulling the inner skins is nothing. I completely removed my wraps, belly pan, and inner skins where I was replacing the floor.
Just check out my thread. Lots of pictures... Hope it helps.
-Red, been there, done that...
Old 01-06-2016, 08:32 PM   #9
Twinke58's Avatar
1958 26' Overlander
Kansas City , Missouri
Mine 24' Tradewind is having a complete floor replacement. It's the shell off the pan. We had to take the inter wall panels off to do this. But we numbered and marked all the panels and the wall so when we put it together we know where to them back.Click image for larger version
Name:	ImageUploadedByAirstream Forums1452137527.208648.jpg
Sent from my iPhone using Airstream Forum
Twinke58 is offline   Reply With Quote
Old 01-06-2016, 08:57 PM   #10
Manheim , Pennsylvania
Why do they use plywood anyway? Couldn't they use some sort of composite material that wouldn't rot?
Jukeboxfun is offline   Reply With Quote
Old 01-06-2016, 11:01 PM   #11
cameront120's Avatar
1972 25' Tradewind
That's the $1000 dollar question that the mother ship doesn't seem interested in addressing.
North Vancouver, BC
Old 01-07-2016, 10:06 AM   #12
Twinke58's Avatar
1958 26' Overlander
It's marine board.
Old 01-08-2016, 08:37 AM   #13
Panama Red's Avatar
Obrien , Florida
Originally Posted by Twinke58 View Post
It's marine board.
Does it have "Oorah!" Or "Semper Fi" stamped on it somewhere?
-Red, again with nothing to add...
Old 01-08-2016, 09:02 AM   #14
Lumatic's Avatar
1993 34' Excella
Images: 16
Newer Airstream flooring is OSB
Honeycomb Aluminum Panel As Sub Floor, the adventure... Rivka Repairing/Replacing Floor &/or Frame 37 12-25-2015 03:25 PM
sub floor replacement help Terry J Repairing/Replacing Floor &/or Frame 13 06-26-2010 09:50 AM
Sub Floor Replacement - Elevator Bolts dufferin Repairing/Replacing Floor &/or Frame 1 03-10-2010 12:46 PM
Sub floor 3/4 or 5/8? Installing Reflextix... Zstream General Interior Topics 7 11-12-2009 01:23 AM
More sub-floor questions 1959newbie Repairing/Replacing Floor &/or Frame 7 07-13-2006 03:52 PM
