Old 04-12-2014, 11:44 AM   #1
WBCCI 8562
Jim in Pima's Avatar
1975 31' Sovereign
Pelzer , South Carolina
Strange frame break on my Airstream, HELP
On a extended trip the rear of our 31 foot started to sag, badly, the closet
door would not close, the floor was POPPING when walked on.
Now we are settled, started looking for the problem, my guess from
internal sloping was behind the battery compartment, so after much
effort removing it found it was not bad, forward towards the wheels was a mess. The fender well must have leaked for years and all the frame extenders
were rusted off at the bottom, a inch of dirt lay in the bed. So digging
through it, I got up next to the rear wheel only to see a 1/4 crack in the frame, at some point heavy steel plate was bolted on the frame behind the
wheels, then another chunk of steel was welded aft of that, the crack is in
that steel, looks like it was a old repair gone bad.
I do not weld, or know a welder. So what next????? Anyone deal with this.
We are up in years and cannot afford a frame off repair.
Thanks for any help
PS a resident of south carolina now
Jim in Pima Az, enjoying our 1975 31 ft Airstream Sovereign
Jim in Pima is offline   Reply With Quote
Old 04-12-2014, 11:51 AM   #2
1986 31' Sovereign
Miami , Florida
You are describing classic rear frame separation or sag. It is not all that rare, unfortunately, especially on longer 70's trailers.
Do an advanced search for frame separation and you will find many posts describing the symptoms and the cure.
Sorry,
Mike
Old 04-12-2014, 11:54 AM   #3
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Thanks for any help
Listen to the latest episode of The Vintage Airstream Podcast | Vintage Trailer Restoration
Colin
Colin H is offline   Reply With Quote
Spring Break, TRIP,.. Need help Again. THEPILL On The Road... 18 02-06-2011 11:14 AM
How EASY to break into Airstream? TOO EASY Foiled Again Doors & Locks 20 04-19-2010 11:14 AM
Airstream break-up, keeping the dream alive LucyPepper Tow Vehicles 59 08-09-2009 07:01 AM
Strange noise?? Univolt?? Brakes?? rroessler General Repair Forum 2 06-22-2002 04:41 PM
