User Name
Password
Portal Register FAQ Members List Rally Calendar Chat Room Mark Forums Read
Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Click Here to Register!
- Monthly Newsletter
Old 06-30-2005, 05:52 PM
A-Merry-Can
Addicted to Aluminum
A-Merry-Can's Avatar
Profile:  1959 18' "Footer"
1962 19' Globetrotter
1964 24' Tradewind
Woodstock, Georgia
STEP-BY-STEP Shell-Off Floor Replacement
ok guys. first and foremost, i am NO EXPERT! in fact, this '59 traveller is my first trailer! my grandparents used to always take me out for the summer in theirs, and i knew i had to get one. i've always wanted to restore something cool, so here we go. i decided to do a complete shell-off frame up restoration. it's the only way, in my opinion, and if you saw my frame, you'd agree! i tell ya, i have learned more with a pry bar and a saw in my airstream than anything i've read so far. i know a lot of you guys have done the complete shell-off restoration, and i wanted to run my plan by you all for feedback to hopefully steer me clear of any uncharted dangers!
here's my plan (i've already made it through the first couple of steps, but i'll put them in anyway for others).
1) remove complete interior cabinets, furniture... down to the bare shell.
2) remove 4 pieces of bannana moulding
3) drill out rivets connecting the belly pan to the body & drop pan
4) remove sub-floor (mine was so rotten, it practically pulled out by hand)
5) after i removed the subfloor, i had to use a cut-off disk to remove all the rusted bolts that held the floor on. (this is where i am with my '59 at the moment)
6) cut off all bolts from the shell to the frame.
7) build temporary bracing for the shell, once it's lifted (i plan to use x-bracing both vertically and laterally, with additional support along the body line of each side).
8) drill out rivets holding wheel-wells to body shell, and remove wells.
9) lift shell (with several friends and a jack?) above the frame and set on temporary saw horses.
10) pull frame. weld in replacement cross-members and outriggers, if neded (mine needs 3 of each). i also plan on welding the nuts to the shell that hold the shell on, so i don't have to access them once i put the belly pan on. sandblast the frame, epoxy prime, and final coat with silver.
11) replace axle and suspension with new.
12) install grey and black-water tanks in the frame if they are below the floor (this is all guess. my trailer was completely gutted when i got it, so i'm not 100% certain how the plumbing went in.)
13) cut wood floors using old as patterns (if only i COULD!) i'm going to have to guestimate mine. i'm planning on making a pattern BEFORE i lift the shell to make sure the pattern is correct.
14) reinstall wheel wells and splash guards.
15) install weather-proof insulation over the top of the frame rails
16) install new floor with new elevator bolts (i want to find an alternative to plywood. i don't want this thing ever rotting again!)
17) install center belly-pan piece first, then the 4 corner pieces, moulded to the shape of the floor.
18) drop shell back on, and install bolts into the frame. also, install wood screws between frame bolts.
19) line everyghing up, seal and rivet-away.
now the fun parts begin! seriously, though, is there anything wrong with the order i have listed above? also, if anyone has any tips or what-not, i'd love to hear them! i'm planning on digging in saturday morning and HOPEFULLY getting the shell off, and the frame ready to weld.
thanks a million for any advice!
jordan
Get rid of these ads... register today, it's FREE
Old 06-30-2005, 06:39 PM
desi arnaz
desi arnaz's Avatar
Profile:
try trex for your floor..........take a 2x6 and split it down the center............2 for the price of one.i did this in my boat and have had no problems[3rd floor]
Old 06-30-2005, 08:26 PM
Ken J
Profile:  1958 26' Overlander
Tijeras, New Mexico
Jordan
I would/did use ACX plywood - epoxy the edges, paint the rest with water based Verathane.
Ken J.
1958 Overlander
Old 06-30-2005, 09:42 PM
Over59
Over59's Avatar
Profile:  1959 26' Overlander
1968 17' Caravel
I'm not seeing if you are removing the inside shell to remove the old fiberglass insulation. This is the source of much smell. Do it before you lift the shell and it will be lighter. Wear a mask, you don't want to be inhaling dried mice dirt when you take the interior walls off. I think this is essential when you are going to all the trouble to do a shell off.
I don't understand the bolt thing and weldnut or wood screws. You will need an attachment from the floor to the shell and belly pan. A 1.5 x 1.5 bent piece of sheet aluminum will work. This is attached to the floor / out rigger with elevator bolts. Between these I used full thread 1" deck screws, drilled 1/8" holes in the aluminum to start them.
Have you gotten past the hidden rivets? These attach the belly pan to the ribs up under the exterior shell. Nasty surpirse. The shell lifts easily if "all" the rivets are out. Vulkem may give some sticking between the well wheels and shell.
I don't think you ever had a grey tank and maybe not a black tank. Plan ahead. It you are replacing cross members then check tank depot for tanks that you could use by moving the position of the cross members a few inches. A lot cheaper than custom tanks. You could also use a single grey / black tank.
Do you have trim over the wheel well shell line. These have some hard to find rivets also. If something doesn't move with alittle force look for rivets. The old guys that put these together are sitting in the nursing home laughing their .. off thinking about blind rivets.
Save a template of the belly pan around the wheel well, how it comes up to the shell.
5/8 marine plywood is more than enough, just treat it like Ken. If you use another thickness then things start to not line up.
Good Luck.
PS. how many cross members do you need, I had some made up and didn't use then all.
If everyone is always correct then nothing will ever change.....
Old 07-01-2005, 07:09 AM
A-Merry-Can
1964 24' Tradewind
Woodstock, Georgia
Rivet great info so far!
wow, thanks for all the great info so far. i had planned on marine plywood as a back-up. i'll stick with that. what thickness is the wood? 3/4"?
also, thanks '59 for all the great tips. in fact, i have drilled out the rivets for the front belly pan, and it didn't drop. i assumed it was sealant of some kind. tell me more about these hidden rivets, and how the heck i can get to them! frustrating to say the least.
the welding the nut to the frame idea came to me when i tried to understand how these shells were attached. i assumed the belly-pan needed to go on before the body? (let me know if this is wrong). anyway, with the floor in it, as well as the belly pan, i didn't know how to attach the shell, other than to have the floor pre-drilled over the frame outriggers, and have the nut welded to the frame. then i wouldn't need access to the underside to tighten them. it could all be done from above. i'm not sure i understood where the aluminum piece would go that you mentioned?
then i looked at my trailer a little closer, and it SEEMS like when i take out all the rivets at the bottom of the shell, top of the belly pan, the channel that supports the base of the wall comes out. now this opens up another option for me. can i drop that channel, and fasten it to the sub-floor, and THEN drop the shell over the channel and rivet it back on?
good tip on removing all the interior. i just have the lower interior removed at this point. i am planning on replacing all the insulation for certain, but i left it all together thinking it would make the shell a bit stiffer when i remove it. lighter works for me, though.
speaking of lifting the shell, as i understand it, i attach my wooden braces directly to the internal ribs with screws. i had planned on supporting the footer of each side on another 2X4, but if that lower channel piece needs to come off, i guess i could lift the shell by the 2X4s. will the ribs be strong enough to support the entire weight of the shell with just wood-screws in the sides? how much should a totally stripped 15 foot shell weigh?
finally, i haven't started drilling out the wheel wells. that was on my list of stuff to do after work today.other than the 25 rivets i can see from the outside, are there others i shoudl watch out for? i'll attach a pic.
as for the cross-members, i had 2 made already, and 4 outriggers (still need to radius the ends). i think that will be enough, but something tells me when i sand-blast the frame, i'm going to find other sections of weakened metel that will need attention. always gotta plan for the worst.
thanks again for all the info! i don't know HOW i would figure all this stuff out on my own! ha!
jordan
Old 07-01-2005, 07:54 AM
fireflyinva
fireflyinva's Avatar
Profile:  1961 22' Safari
Vienna, Virginia
Jordan,
I wonder if you might reconsider taking the shell and the belly pan off--It seems that you only want to weld, and that can be done with the shell & belly pan on.
I have to admit, I'm a bit leery about pulling off the shell--it just seems to open up a whole new range of complication and possibilities for damage. Plus, I've noticed around here that there is a much higher likelihood that folks quit on a project with a shell-off instead of keeping it on. So, when we had to start structural repairs last spring, we decided to go the shell-on route (and we are doing many of the repairs you mention).
We've done quite a bit of welding of trailer frame members from the inside with no problem. You also don't have to take the shell off, even for the outriggers. Same for new tanks. Really, the only reason I can think of where you absolutely have to remove the shell is to remove and replace the trailer frame.
Regarding the belly pan, in our era of trailer, the attachments held both the bellypan, shell and floor on together in a rather complex clamshell arrangment. You can't attach any of these independent of the other two elements. I'm not sure about your planned sequence--it appears a bit out of whack for replacement (I'll have to work this through a bit more).
For belly pan issues, the preferred technique (again, for this era trailers only) seems to be to cut it out below the line of sight. But why cut it out, unless you plan to have something (like a tank) hang at lower clearance? And then, even if you do add in a tank, all you really should need to cut out is the affected location, not the whole thing.
BTW--you may want to consider cutting out the floor in sections, so you can still have a bit of a platform for working on the innards, then you can cut it off, section by section to replace the flooring.
I hope you don't mind my devil's advocate questions. There are folks here who have done lovely jobs with full shell-off efforts. But I think they would all admit that the job was huge--and all I wonder is, why bring on that extra effort if you don't need to (since the effort really doesn't seems to offer any meaningful advantage)?
Mary
Mary Dotson, WBCCI/WDCU #9026
Our Airstream reconstruction adventure continues! Read the details at Tales of the Toaster
Old 07-01-2005, 08:09 AM
greg176
greg176's Avatar
Profile:  1961 26' Overlander
Gabriola Island, British Columbia
The plywood is 5/8". The belly pan is held on with more rivets up underneath the lower panels.The belly pan was riveted to the lower "U" channel at the factory before the shell was installed.If you remove the inside lower panels first you will be able to see where those rivets are.
Old 07-01-2005, 08:14 AM
A-Merry-Can
1964 24' Tradewind
Woodstock, Georgia
i hear ya on this being a time consuming effort. it seems like every day i work on it, i add a few weeks to my estimate! :-D i foolishly thought i'd have the shell off, new floor and pan, and shell back on in 4 weeks. it still might happen, but we'll see.
the problem with my trailer is the guy i bought it from had already started cutting it apart, so i can't tell how a lot of things went together. when i got her, the rear floor rear belly pan, interior and all plumbing was out of it. the reason i want to do a full shell-off restorations is the amount of rot i keep finding. i'm kinda picky when it comes to rust. my plans once i get the frame out is to sand-blast it all, weld in new cross members, outriggers, and fix any other stuff that shows after the blasting, then epoxy-prime it (several times!), and coat it all with a nice thick silver coat. that should hold the rust at bay. i know it seems extreme, but i want to be able to enjoy this trailer forever!
i'm not saying the shell off/on is better or worse, but in order to put everything back as it originally was, it seems like the most complete solution? if nothing else, it's an interesting learning experience, to be sure. it seems like after going to all this trouble, lifting the shell completely wouldn't add too terribly much to the over-all job. especially considering it's a shortie. i knew shorter was better! ha! do you have any input on the installation order? i would love to hear feedback on attaching the floor, belly pan and shell together in one step.
i'll attach a pic of where i am at the moment. things will look a lot further along after this weekend. i am concerned about hidden rivets, though. i'd rather not remove too many external panels, unless totally necessary.
jordan
Old 07-01-2005, 08:18 AM
C Johnson
C Johnson's Avatar
Profile:  1965 17' Caravel
Portland, Oregon
Now your catching on !
Chris AIR # 7276 WBCCI # 7276
WBCCI Forum Save Wally Forum
Photos of Project 2k5
My Pictures
Old 07-01-2005, 08:29 AM
greg176
greg176's Avatar
If yuor trailer has the steel plate in the front the belly pan wraps up underneath the two rows of rivets on the front panel below the window.
Looks like great progress.Glad to see you are doing it right.Do you have your elevator bolts yet?If you are planning to install a grey water tank under floor now would be a good time to order one.That delayed my project about two weeks last year wile I waited for tank to arrive.
Old 07-01-2005, 08:32 AM
A-Merry-Can
1964 24' Tradewind
Woodstock, Georgia
ha, like i said, i learn more with a crow-bar and a saw than reading! i just checked out your project site. very cool! i take it you didn't remove the shell? did you mount the black water above the floor? i think that was original in that model. i want to try to mount mine below the floor, if it doesn't cause massive nightmares.
jordan
Old 07-01-2005, 08:42 AM
greg176
greg176's Avatar
There are several great posts on grey tank installation.I have posted a few pics of my install.Do a search for FRAME REPAIR. UWE made some amazing tanks do a search for his thread "a 63 for me".
Markdoane did a great installation here
http://www.airforums.com/forum...ght=full+monty
Old 07-01-2005, 09:24 AM
cynthia
Profile:
Stop! Wait!
No one adviced you to drink a BEER first. Good luck and have fun,chance are you will only do this once.
Old 07-01-2005, 10:16 AM
MarkR
MarkR's Avatar
Profile:  1951 21' Flying Cloud
1960 24' Tradewind
Folsom, California
Jordan,
I'm at the same point as you with lots of the same questions, like the "putting it back together sequence" - Kind of baffling to me. It seems like it would be easier if the bottom channel of the walls was attached to the body/skin so you could "drop" the body onto the deck and screw it down . . . but instead it looks like I'm going to have to carefully try and line up (blindly in my case because of a new belly pan) the original rivet holes. Just seems like if the channel was positively attached to the body it would be easier . . .
And in case you didn't find out yet, I found a thread somewhere along the way that estimated the body for my trailer 21' (18' body) weighed something between 400-500 lbs, which seemed high but now that I'm all "detached", it feels about right.
Thanks for you posts. Mark
Led Balloon in Drag
vB code is On
Pingbacks are On
Need a step? jcanavera 2001 Safari 8 01-26-2003 11:05 AM
Handy hitch step Pahaska Our Community 0 06-26-2002 05:44 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 02:35 PM
Powered by vBadvanced CMPS v2.1.0
Powered by vBulletin® Version 3.5.8
SEO by vBSEO 3.0.0
Airstream is a registered trademark of Airstream Inc. All rights reserved.
Airstream trademark used under license to Social Knowledge LLC.
Wikipedia about Airstream - Airstream Central - Airstream Photos
