Old 08-18-2005, 09:03 PM   #1
NorCal Bambi's Avatar
Profile:  1963 16' Bambi
Yreka , California
Images: 21
Unhappy Floor Replacement 63 Bambi
We recently purchased a 1963 Bambi. All is in good condition except the floor... the Bambi is nearly gutted and we will soon be ready to replace floor. Any and all advice by someone who has done this before would be very welcome! Also interested in knowing the best way to "lift" the body off. Can it be suspended while working on flooring? What did you do that worked for you? Thanks for any and all help!
NorCal Bambi is offline   Reply With Quote
Old 08-18-2005, 09:31 PM   #2
greg176's Avatar
Profile:  1961 26' Overlander
Gabriola Island , British Columbia
Start by reading this thread:
http://www.airforums.com/forum...hlight=looming
Start by removing lower interior panels.
greg176 is offline   Reply With Quote
Old 08-18-2005, 09:32 PM   #3
greg176's Avatar
Oh and welcome to the forums and congrats on your new Bambi.
Old 08-18-2005, 10:46 PM   #4
Yreka , California
Images: 21
greg176
Thanks for the rapid reply. I'll post some pictures later.
Old 08-24-2005, 09:46 PM   #5
Yreka , California
Images: 21
Well we are well on our way toward replacing the floor on our 63 Bambi. The body is off and the floor is ready for removal. I have read discussion about blind rivits. I believe I have come up with an Idea as to why there are placed where you find them. I will include some diagrams and pictures later. For me they were a suprise. My idea may help the next person. Maybe someone else has written about why blind rivits appear where they do. If so I have not found the thread so far. Historical pictures are the clue. See pictures on The photo tap for my pictures NorCal Bambi.
Old 08-24-2005, 10:00 PM   #6
greg176's Avatar
In the thread in link above there is a photo of an Airstream chassis.They pop riveted the belly pan to the "U" channel to hold things in place before shell installed.Thats where some of the blind rivets show up when pulling shell off.There are also some in the frame bows to the "U" channel.
Old 08-24-2005, 10:40 PM   #7
Yreka , California
Images: 21
Here are the pictures I tryed to post in the last post
Old 08-25-2005, 11:37 AM   #8
Yreka , California
Images: 21
Thumbs up floor treatment
Well, I have read many threads on floor replacement and treatment of the wood to create a better lasting floor. So many people so many ideas! Is there any of these treatments that have lasted the test of time? I was thinking about epoxy and fiber glass covering. But now I not sure. I guess the bottom line is Wood is Wood. I'm off to Medford OR to look for elevator bolts today and shop for plywood. Wish me luck.
I'm working with PhotoShop and can't seem to get my pictures to the right file size.
Thanks for the input!!
NorCal Bambi
Old 08-25-2005, 03:48 PM   #9
Profile:  1973 31' Sovereign
Portland , Oregon
Alternative to wood...
There is an alternative to using plywood that, sofar, is working out well for me. Check out the following thread:
http://www.airforums.com/forum...ad.php?t=14620
Malcolm
malconium is offline   Reply With Quote
Old 08-25-2005, 05:54 PM   #10
greg176's Avatar
To get your photo on the forum in photoshop:
1/ Open image you want to send
2/Under image on top menu select image size.
3/Adjust image size to 640x480 pixels.
4/Under file menu select save as and save image to desktop as a jpeg a dialog will open up where you select size of jpeg image.Adjust slider till image is less than 100Kb.Then save.
5/Select reply in forum menu.Write message then click manage attachments.
6/Select browse then find your file.Then upload file.
7/After file is uploaded hit submit reply.
Most wood preservatives are made for exterior use and not safe for a closed environment like a trailer.Most of us have settled for using varathane to seal the wood and give it some resistance to moisture.It is important that the floor is able to breath and I think the varathane will work.Even an untreated floor woll last a long time if you don't let it sit wet.
Old 08-25-2005, 10:49 PM   #11
Yreka , California
Images: 21
Greg176, thanks for the info on the floor treatment. The thought that external materials as being unsafe is a good point. thanks.
Old 08-26-2005, 09:22 PM   #12
Yreka , California
Images: 21
Thumbs up Paper? anti-squeek? between channel and plywood
New question what is the paper like substance material that is between the aluminum channel and the plywood. I also found the material between all the cabinets and the floor, water tank, etc. Can you direct me what are the best kink of rivets and where to find them. Maybe in California. I am currently working on removing the channel, belly pans and old wood floor.
Old 08-26-2005, 10:14 PM   #13
greg176's Avatar
There was no paper in my trailer there.For solid rivets I used a 5/32" Diameter universal rivet.Do a google search for MS20470AD5 .
Old 08-27-2005, 09:19 AM   #14
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
CA Rivet Sources
Aircraft Spruce has them. They come coated in a gold color, which rubs off easily.
www.aircraftspruce.com
There are numerous other rivet suppliers. I also purchased some rivets from a place in Los Angeles, http://www.hansonrivet.com/
I prefer the ones that Aircraft Spruce carries.
Uwe
Pingbacks are On
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 27 07-27-2007 09:50 AM
1961 Bambi '16 (Serial #16TDSS1728) Andy R 1961 - 1963 Bambi 20 05-14-2007 12:28 PM
Newbie AS Bambi Owner! KY Girl Our Community 12 10-27-2002 09:06 PM
Interior lights - 61 Bambi 61BambiCanada Electrical - Systems, Generators, Batteries & Solar 0 06-07-2002 09:52 AM
Bambi II is a Caravel... VintageRV 1964 Bambi II 0 02-24-2002 07:55 PM
SEO by vBSEO 3.1.0
