Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Finally, the work on the frame begins! First thing on the list was to replace 2 badly rotted cross-members near the front. A local fabrication shop made the channel for me. A plasma torch and a buddys welding skills, and Im off.
Next up: the curved outriggers. Its a snap to make them. C-clamp them to one of the outriggers on the frame, and use it as a template for the plasma torch. Then grind it relatively smooth, and youre done.
Finally, I never did like the lack of support on the back corners, particularly where the toilet sits, so I fabbed up a few shorter outriggers, like those on the longer bodies, just to give it that little bit extra support. They are only 10 long, and do not have curved ends, like the longer 15 ones do. I doubt they will even touch the belly pan anyway. Whether it REALLY needs them or not is up in the air, but the cost of these parts was so ridiculously cheap, I figured, why not? I still have to grind the welds down on all the out-riggers.
I'm not totally done yet. Once the tanks come in, I can put the remaining cross-members in, and I still have some detail stuff to do on what's there, but it's probably half-way?
Man this weather just plain STINKS. My garage is slap full to the ceiling. I am needing to set up on the driveway for the next few steps and every time I start to get going the rain comes and I have to pack it in. If I could get a couple panels stripped and a few more wires pulled I would be doing good and could move several cabinets out of the garage and get some room to work where I don't have to worry about rain.
Looks like you are making great headway. PLEASE strap that shell down. As quick as these storm we are having are pooping up I would really hate to see that shell get blown off those saw horses.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
one step ahead of ya, '59. it doesn't look like much, but all 4 corners are ratcheted down to the saw horses. the width of the saw horses makes them incredibly stable (much more so than i originally thought). i kept them low, so the center of gravity would be a lot safer. it's so low, in fact, that it takes 2 guys to lift the saw horses to roll the frame in and out. i think it's maybe only 8" above the original level. i've also attached the saw horses with longitudinal beams for more stability. a few nites before she was off the frame, but sitting on 2X4 blocks, we had the tail end of that hurricane blast through. i bet i got up 10 times that nite.
where are you with your toaster?
I'm down to running my new running light wires. Couple coax lines. One or two more 12v Lines. Then the rest of the interior skins can go in once I get the rest of the god awful baby blue paint stripped off them LOL.
When the skins go in then I can transfer all the cabinets back into the coach to get my garage back and start rebuilding them one at a time.
Once the cabinets are out of the garage I have a little something to do before I do much more on the coach. I am going to remove a wall in the back of my Garage to open up the store room and give me another 4ft of floor space around the cars and full access to a work bench. Then 350-400 HP 68 400cid GTO motor need to find a home in my 1970 Pontiac LeMans Convertible. I'm having a bad case of Convertible withdrawals
Once the car is drivable it will let me pull it out of the garage to get more floor space for building the cabinets and setting up my table saw.
Too many projects LOL.
1959 22' Caravanner
Atlanta, GA
69 RS. i can't remember what weekend it is, actually, i haven't been yet this year. we'll have to tow our toasters up there when they're done. ha!
hehe I told My wife that when we went. She surprised me by actually haveing a real good time up there.
She wants a Chevelle.....BAD. She spent a bunch of time drooling over every 396SS there was and there was several. Even a Yanko was there. So she has her heart set of a Red 71 with SS stripes. I cant argue with that.
1959 22' Caravanner
Atlanta, GA
The tanks came in today. I opted to add a grey-water tank to the trailer, in addition to the stock black-water tank in the rear. I also took this opportunity to upgrade the size of the fresh water tank to 32 gallons, and plan on mounting it below the frame, just ahead of the axle. I must admit, the fresh water tank is going to hang a little lower than ! anticipated (4 inches below the frame), but i plan on raising the ride height of the trailer 2+ inches in the axle, so its really not too bad. I plan on having a nice stainless holding pan made at the fabrication shop to protect the tank from the road, with insulation for the winter months.
You wouldnt think I would get excited to see a septic tank, but I was. Its one step closer to the finished product! This weekend, I plan on working quite a bit at Davids hangar, in the hopes of getting the tank mounts figured out, and the welding done, so I can finally blast the frame clean of all the rust, and get it painted. Im still waiting on confirmation from the axle guy before thats ordered.
MORE welding and cutting. The old LP tank mounts are long gone, the new cross members are welded in for the fresh and grey water tanks, and the step area is significantly stronger than it was. All thats left to do at this point is to weld on some angle iron to remount the step, one additional piece for the rear to support the back floor, and then shes all ready to blast, prime and paint. Ive got to order the silver paint tomorrow so there are no delays.
Next step, running the rusty trailer up to Davids plant so i can sand blast it and have it painted. Im going gloss black on the whole thing, for now, at least. i may paint the tongue and bumper silver later, but for now, black is fine. Ive still got a LONG road ahead. Once the shell is back on the body, it looks like Ill be replacing all 8 of the lower panels. As it turns out, the corners are under the flat pieces, and all the flat pieces need to be replaced, so it would just be a matter of cutting and drilling the new aluminum to make it all new (up to the 4 foot mark, at least). The lower half should polish up nicely. I hope the top panels can match the shine. It seems the previous owner had sanded the entire trailer with 220 for some reason, so there are quite a few scratches to buff out. Well see. I also plan on using .040 Aluminum for the sides (and door), rather than .032. From what ive read, the thicker skin is more dent resistant, and makes a much smoother finish.
Shes back! Things are starting to get shiny now. Much more rewarding than the tear-down process, thats for sure. After finishing the welding, I took the rusty frame up to a friends plant with a sand blaster. Its amazing how much crap comes off the frame when you blast it. I found a few weak spots in the metal, as well. Ill have to address them during re-assembly.
Ive also gone ahead and ordered a complete axle set-up from Axis, with new springs, galvanized axle, all hangar hardware, and electric brakes. It should be here next week, though Ill probably not be ready for it until the following weekend, but you never know. if the weather holds this weekend, I might surprise myself. the only short term item I see that could hold me up is the wheel wells. The shop that was fabricating all the frame members for me is working on them for me, but the outer curve is proving to be a bit tricky. Ill be using them to fabricate some stainless sheets to cover the tanks from below. My fresh water tank will end up hanging below the frame about 4 inches, as will the grey water. Its not as smooth as the original set-up, but the size of the tanks is worth the bumps. 32 Gallons of fresh water, and 27 of grey. The black water size is still up in the air, as i am most likely going to mount it above the floor for simplicity.
I also picked up the elevator bolts today, and PLAN on installing the sub-floor and insulation this weekend. I still need to head up to Homey D and see what options i have there. Im assuming they have something thats moisture resistant. I had thought of using the foam panels, grooving them so they sit down in the frame a bit, and let the floor ride closer to the frame. Its going to be tricky to get the floor in without the wheel wells, so im planning on not attaching the sheet that goes between the wheels until the wells are back. I can cut it, though. As for the floor dimensions, my trailer did not have a floor in it when i got her from the wheel wells back, so i did my best to trace the curve off the detached rear corners. the front appears to be less tapered. I believe this is because the rear of the trailer slopes back. I think I read somewhere on the forums that the front corners are 22 radiuses.
PROGRESS!! Until the rain delay, at least. I got all the lumber, sealer and insulation material for the floor this morning, and got an early start on cutting the pieces out for the end caps. The Pickles interior is 88.5 wide X 181 long, so 4 pieces of ply should be plenty (got an extra, just in case). First step was laying out the C Channel to get the curves right. As it turns out, the corners are NOT the same, and in fact, arent even 22 radiuses (though close).
Next thing i did was paint the underside with outdoor sealer/stain (2 coats). I was told at the paint shop that this stuff is better than urethane, and will last considerably longer since its not exposed to UV light. Then, i measured the insulation, with a 3 inch overhang on all sides, cut it, wrapped it around the painted side of the floor panels, and tucked it under the C Channel before bolting that back down with new elevator bolts. I am optimistic that by using this rolled aluminum insulation material, wrapped around the edges, it will help block a MAJOR point of water intrusion into these trailers, the area at the belly pan, body panel seam. Nothings 100%, I know, but it certainly is better than what was there!
Now for the bad news, delays... The fabrication shop still hasnt touched my wheel wells yet, so I cant cut the 4th and final floor piece (as the wheel wells have tabs underneath the floor in those areas). I plan on mounting the front 2 pieces tomorrow, along with the tail section, and leave (2) 4 foot long spacer strips (out of scrap plywood) for the missing section between the wheels.
Also, one of the rear C Channels was pretty badly corroded. Dont be fooled into thinking aluminum is impervious to rot. The dis-similar metal thing is catastrophic, given time! Now for the hard decision, do I try to fabricate a replacement channel for the rear left, or patch this one up and move on? My biggest fear is if the new piece doesnt exactly match the curve, the trailer will look odd, and the shell may not fit properly. Time to seek some advice. :-) (see pic 4)
Hopefully, the weather will be nicer tomorrow, and I can get the floor in. Then its time to order some aluminum for the belly!
Great progress. Sure beats trying to fit new plywood with the shell on. If you have a metal fabrication shop just take them the piece and they will make it. Most are able to bend 120 inch lengths. Is the aluminum brittle. If it is replace it.
Looks like you wraped the floor with bubble foil. You will have to retighten the elevator bolts after givening them a few days to compress the bubbles.
Did you allow for the thickness of the foil when you cut the floor width? I see it's wrapped around the edges.
__________________ If everyone is always correct then nothing will ever change.....
