Originally Posted by doglickfarms
..I am not understanding the part about the 2x4 ( about the width of the floor and securing it to what side?...
It's a "spreader" so that when you pick up the slipped side and put it back up on the outriggers, you don't push it in too far. The 2x4 is just a brace to maintain the proper width across the floor. You might use two or three, even.
Securing it to one side (the side that's still up on the frame) is just so that it doesn't fall down in the midst of all your lifting and pushing.
If your shell was able to fall off the frame, seems it must be disconnected. You could get 3 10' 2x4s and slide them under the C-channel, crosswise and let the 2x4s rest on the frame and the shell rest on the 2x4s. This way you could nail blocks to the 2x4s to maintain the shell width.
Zep
