i bought this air nibbler on eBay for $40-ish. it makes duping panels a snap! literally. all i've been doing is take the old panels off, lay the new 2024 face down on some saw horses, flatten any dents in the old crap, and clamp it face down to the back of teh new stuff. the nibbler has a built in guide that can follow the original panel. before you know it, you're done! it's so good, it actually duplicated the sloppy 1959 cutting on some panels.
if you're replacing skin, GET THIS TOOL!
jp
I got mine at www.harborfreight.com, works great as well. Needs frequent lubrication, like all air tools, but was a steal. Bought my air shears there, too. Those work great for straight cuts with clean edges.
FIrst up when the package gets here, reseal the endcaps! then shell FINALLY be water-tight, and i can <gulp> start polishing those ends to see if they match. please-o-please-o-please!
jp
Jordan,
Don't worry, the shine will be so dazzling, that you, or anyone else for that matter, won't even notice the very very slight difference in color from the old panel to the new panel.
I did some polishing on my new panel where it meets the old panels, and can barely tell the difference. It seems that the difference in color and shine after polishing is much greater in existing panels, especially the curved segments against the straight sections. But, here again, it is difficult to distinguish, because of the different angles the light hits them.
I like all those floorplans. I think the bed in back in plans one and three is nice - especially if you ever have friends over - they will see a dinette or couch first instead of your bed. Otherwise, all of them use the space quite well.
What about that wet bath? How are you planning on making the shower pan? What are the dimensions you have figured?
i'm not 100% certain on the size yet. i'm going to use uwe's idea on laying it out first. i'll let you know what i find out. i'll be having the whole pan and tank fabricated out of stainless steel from a local shop. i'm planning on starting on the bath first and working everything else around that... probably december.
when i removed the rear inner caps this weekend, i started early in the morning, and noticed that the inner skin was completely covered with condensation (see pic). it's apparently been happening for a while. the aluminum is actually water-spotted on both caps from it. it was enough water to keep the inside of the wall moist, and probably even look like a leak, once things are back together.
has anyone ever done anything to prevent the condensation build-up? i was considering coating the inside of the top panels with undercoating once everything else is sealed, so act as a mild deterrant. i'm particularly concerned with any inner-wall moisture, as i'll be applying a wood laminate to the inner skins, and do NOT want water stains to start showing up down the road pun intended .
forgot to post the final pics of sunday's endeavor. i'm down to the LAST cleco on the curb-side. everything's trimmed and ready to seal and rivet. the 2 pieces of 2024 hanging down will wrap up under the belly and blend in nicely. i finished off the wheel well openings on the street side as well. all that's left on them is the stiffening bar behind them, and the trim pieces.
those wheels GOTTA GO! the better the pickle looks, the worse those wheels do! ha! maybe i'll save that for last, too. get the kid a new pair of sneakers before i send her off to school.
That sounds like a good idea. Any idea how you will handle the door and walls? I have been puzzling over how to make something that is more or less removable in case of tank or plumbing problems - but still gets the water only where it should go. If you have any thoughts about these things, post em'!
jp
The picture of condensation really shows what must be a longtime airstream problem. Two metal layers, sealed, with no ventalation, does not sound like a good idea. When I took the inner skins off of my Bambi I noticed a lot of oxidation in the aluminum and the elevatior bolts were very rusty. I imagine everybody has found the same thing. I had been thinking about what they do today when they redo a roof on a house. They install vents at the top of the roof and in the bottom so air can circulate for the purpose of removing moisture. Water vapor escaping from a house has always been a problem with exterior paint and wood rot,etc. I have not come up with what I would consider a good solution as of yet. But have had some thoughts. Most to date are too much work. Here goes on one thought. Each section between ribs in the shell should have ventelation. Two or three sections could be joined as a unit by drilling a 1" hole in the bottom and top of the ribs. Next there are small round vents with screened openings that are available for machine and electronic use. One or two of these could be mounted in holes in the "C" channel and through the plywood floor. This would allow fresh air to enter in the bottom of the wall sections. The top of the sections could be joined by tubing (1" in diameter) with hole in it for the air moving up between the sections. The air would be collected in this tube and exit into holes in the ribs around the top vent window. Then if the top vent window was left open a crack, this should allow a circulation of air between the walls. I was thinking of this method because I don't like the idea of putting any new holes for tubing to exit the top of the roof. That would just be asking for another leak. I am open to anyones ideas on a modification of this idea. Probably just getting carried away!!! If anyone is interested in such a maybe crazy idea, I might do a drawing.
carlos has some good input on the condensation issues. it's not nearly as bad on panels once they are insulated. i'm going to add drain holes in the bottom of the channel, so nothing pools up. are you planning on going the foil insulation route? i definitely am.
search for "foil bubble insulation methods" (thanks again to carlos for that info, as well!) clean, light, and NO ITCHY HANDS! i'm putting the 1/2" spacers on the outside, so my wires can be run inside the insulation for access.
i notched the ribs to get them in line with the door frame, and replaced the horizontal braces with new ones made from left over 040 scraps. when the door flew open in transit in a previous life, it bent the heck out of those horizontal pieces, deflecting the side panel a good bit, and making the door not close properly. with everything straight, it's almost right on teh money. the door frame still needs attention, as it cracked in 2 at the latch. more on that after the last 2 skin panels are replaced.
