Old 10-05-2014, 12:04 AM   #1
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
Step by step shell on, front floor replacement '69 Safari
Well we finally got motivated to do the soft front floor in the '69 safari by the fact yet another trailer followed us home. I figured posting pics along the way will help someone else out that may want to do the same but is to afraid to try.
Here's her exterior
thesignlady is offline   Reply With Quote
Old 10-05-2014, 12:05 AM   #2
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
and the obvious reason she needs a new floor
Old 10-05-2014, 12:10 AM   #3
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Start by taking pictures of everything you will be removing
Old 10-05-2014, 12:23 AM   #4
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Get ready to remove the lower panels
And since you need to remove the curtain rails before you can remove the panels you may as well wash the hardware. I soaked the curtains sliding eye carriers in a solution of bleach and oxy clean diluted with water. I left them in the solution over night. Since of bunch were very brittle due to the age of them some had already broken in years past or broke during my curtain removal process. I found replacement ones online at outofdoorsmart.com I also ordered some new I rod curtain carriers as some were rusty lookingClick image for larger version
Old 10-05-2014, 12:26 AM   #5
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
ID:	223636As you can see in the last pic I also chiseled off the ugly yellowed weathered covers that were around my window lever handles. I am getting replacement ones made at my neighbourhood plastics shop.
Old 10-05-2014, 12:31 AM   #6
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Guess what they had 8 by 8 boards...
I chiseled up the tiles looking for the seams to take the front out and there isn't one till past the door. They would have had to use full 8' by 8' pieces back in the day. Click image for larger version
Old 10-05-2014, 12:34 AM   #7
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
But that's OK because I also learned that if you pull up floor tiles looking for seams you might not find what you are looking for...you may find more rot instead Click image for larger version
Old 10-05-2014, 12:58 AM   #8
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Sorry we got so excited by how happy we were to find all the rot we forgot to take pictures of the removal of the wall panels. We did not use any special tools for this part, it was just a whole lot of rivet removal using a bit just large enough to drill out the center of the rivet heads. We had a couple that just spun and spun that Mike got out the dremel and ground the heads off of. On one scary occasion I went straight through the rivet head as far as then drill bit would go. After a panicked rush outside to make sure I didn't drill out of the exterior wall I wrapped masking tape several times around the drill bit about an inch up to make a depth gauge, this way when I drill to hard I didn't have to have heart failure, Sadly I did drill to far a couple more times so I will have to put slightly larger rivets in those holes when we re-apply the wall. I purchased the 1/8th" almond colored rivets from vintage trailer supply for about 6 bucks for a hundred. It will save me a huge amount of time not having to paint all the rivet heads. (it would drive me batty to have silver ones showing on the ivory walls)
We had to pull out the refrigerator in our girl as the first floor seam lands midway under it in our trailer. At that point we also realized that the lower wall panel on the galley side goes the full length of the trailer...
We decided that as the floor in the center area of the trailer is in great shape and the PO had already done the rear bath floor that we would just use the dremel to cut the panel in behind the refer. When the time comes to put it back together we will back it up with a two inch panel of aluminum and grommet it back together
Old 10-05-2014, 01:26 AM   #9
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Here is the method we are planning to use for removing our floor
Floor Replacement - Vintage Airstream
The next step for us was setting the circular saw blade to 3/4 of an inch and cutting up the middle of the trailer, we cut it off center on purpose though as I was concerned that if we removed the entire floor before putting the new half in that the weight of the trailer shell may come down and clamshell itself to the frame. We made the decision of which side to remove first based on the side that had the most solid wood got to stay in longest. By leaving the one side in I ensured that I had a spacer so I wasn't fighting gravity when it was time to slide the new halves of the floor in.
Well we cut though it and assumed that given the soft state of her floor we would be able to just rip up the board and that is would crumble around where all the elevator bolts are, wrong...Got out the circular saw and made some more cuts this time from the center line to the curbside, We made about four more cuts. Using a large pry bar we were able to pull up just one rotten panel, sadly the elevator bolts were doing their job well and holding here together.Attachment 223641
Old 10-05-2014, 02:03 AM   #10
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
sorry this should have gone before my previous post
For those that don't know Steel and Aluminum don't like each other. They can have a galvanic reaction, so to avoid the metallurgic reaction airstreams were designed kind of like a sandwich. The steel frame below, the plywood floor that covers the entire frame and the aluminium shell that fits to the plywood floor pretty snuggly...
Right on top of the plywood there is a C channel that runs the perimeter of your trailer, it is called a C but it sits on your floor like a U.
The side of the U facing the exterior wall is buck riveted to your exterior shell, those rivets are within your lower belt line. To do this kind of shell on flooring job you do not need to do anything with them, leave them be.
You will just remove the stuff that faces the bottom of the U and of course the inside wall of the U is where the lowest row of your interior walls rivets are placed. Once the interior walls have been removed and you have exposed your C channel you will see that you have a bunch of philips screws to easily remove but there are bolts coming upwards and all of them bent... Those are the elevator bolts. The factory bends all of the bolts so that the nuts on them cannot wiggle themselves of with the vibration of travel. You will find that your elevator bolts are installed pointing downwards in the plywood floor area. So it means at this point you will need to drop the portion of belly pan to be able to access those. It a good time to get your trailer to a nice level area because you'll be here for a bit.Click image for larger version
Old 10-05-2014, 02:09 AM   #11
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
What the heck does an elevator bolt look like and where do you buy them?Click image for larger version
We searched all the usual big box stores and they did not carry them. We found these at Fastenal
Old 10-05-2014, 09:12 AM   #12
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
good morning
as I slept I realized I left out the part about the wing window frame removal. Unfortunately to get to all of the rivets that hold all the bottom wall panels on, the wing window plastic surrounds have to come out as a bunch of the wall rivet are under the plastic .
Old 10-05-2014, 09:30 AM   #13
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Drill out the rivets holding it in place and if needed use a utility knife to cut it away from the inside. Our windows has a thick bead of vulcum around the rivets that were holding the frame in a few places. This plastic is old and will likely be brittle take your time and wiggle it out gradually.
If your are already damaged, or damaged during the removal process replacement wing window shrouds can be purchased from Inland RV for about $150 ea The replacement parts are fiberglass. Mine survived the removal so I will restore the plastic ones.
Once we had them out we hosed them off and chucked them in the tub with a a 1/2 cup of pine sol to de-grease them.
After soaking them for a day rinse them off and give them a good scrub down with a Mr. Clean magic eraser and soap. Leave them to dry in a safe place where they won't get damaged
After they were dry I took them outside and gave them a couple coats of krylon fusion spray paint for plastics. Look for my restoring a 70's dometic fridge interior for more info on how to paint and do paint bond-ability tests if you are not using the krylon fusion
Name:	69 Safari Sealing 152.jpg
Old 10-05-2014, 09:42 AM   #14
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
If you have any other windows within you lower wall panel you will need to remove their shrouds to. Undo all the rivets on the other edge and then you will need to drill out two of the rivets in the top of the oval to be able to slightly contort the frames to get them out of the hole in the wall panel
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
'67 Front window screen frame replacement SlvrSt8Steve Windows & Screens 10 11-30-2014 10:32 PM
Front frame crossmember replacement Darrengj 1966 - 1968 Safari 6 04-22-2014 12:16 PM
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 794 04-29-2013 07:49 PM
new curtains for the 67 Safari... with a step by step picture guide customgrind Upholstery, Blinds, Walls & Interior Finishes 3 08-08-2010 09:23 PM
