Old 01-23-2008, 08:40 AM   #505
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I have been kicking around using a helper fan or two also, so much so that I already have the fans. Using duckwork from a dryer vent is not such a good idea. the internal ribbing will cause turbulance and a high air flow resistence greatly reducing the cfm flow. I found this out the hard hard way when I was running duckwork for my woodshop dust collector system. Ductwork with a complety smooth interier with sweeping corners will give the best performance.Thin wall PVC or ABS will work quite well in this application, and can be wraped with insulation for less heat transfer. There is also flexable duckting used in the avaition industry called scat tubing that is smooth on the interior and used for this application. It is also spendy. I,m sure McMaster-Carr also has some neat ducting.
Old 01-23-2008, 08:45 AM   #506
Idiot Savant
1967 22' Safari
Auburn , Alabama
I don't think the size of the tube matters as long as its matched with an appropriate fan.
smaller tube+stroger fan= good pull.
I'm sure their is a zen like middle ground that would be ideal
- I am sorry that my train of thought is so hard to board
1988 C20 Suburban 454
1967 Safari 22' (like a fish)
"genius, talent, and luck have very little to do with success. The Successful all have one thing in common - persistance"
- Melon
Cursh is offline   Reply With Quote
Old 01-23-2008, 09:47 AM   #507
Aerowood's Avatar
Arvada , Colorado
The size of the tube does matter in referance to the amount of airflow across the evaperator. To little airflow across the evaperator will cause the coolent going thru the evaperator to not become fully vaporized, liquid coolent can enter the compresser causing it to "slug" shutting down the system or damaging the compresser.
Old 01-23-2008, 10:01 AM   #508
Idiot Savant
1967 22' Safari
Auburn , Alabama
I'm sorry - I think we are talking about slightly different things.
I was proposing an independent vent system to pipe the cold air on the floor up to the top of the camper.
[floor vent] ==> [tube upward] ==> [fan] ==> [head height vent]
I don't see where the evaperator fits in, but that being said I have zero experience with heating and air.
- Melon
Old 01-23-2008, 11:32 AM   #509
Aerowood's Avatar
Arvada , Colorado
Thats cool Cursh I see where you are going now. I was talking about ducting to route the conditioned air to anywhere in the trailer.
Old 01-23-2008, 06:42 PM   #510
1973 31' Sovereign
Portland , Oregon
Images: 22
How would the portable unit vent its heat to the outside? Are you visualizing something that has a connection to the outside? Do you have some web links to some units of the type you are thinking about?
I like the idea of the dryer vent duct. The flexible stuff can really compress down too. I would guess that almost any amount of additional air movement would be a big help. As a rough guess I would suggest that the maximum amount of duct size that seems sensible would be an amount whose cross section area was about the same as that of the AC unit. Of course the amount of air that the fan that goes with the duct moves would be variable too.
It is too bad that ceiling vent fans like the Fantastic models don't have a mode where it makes more sense to use them with the vent closed. If there were some way to get indoor air to the top side of the fan blades then it probably could do a pretty good job of pushing the air down into the living space without any ducting. Or better yet if we could figure out a way to get indoor air from the floor level ducted to above the fan blades that would be a great way to go.
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
Old 01-23-2008, 07:35 PM   #511
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Originally Posted by malconium
...I like the idea of the dryer vent duct. The flexible stuff can really compress down too. I would guess that almost any amount of additional air movement would be a big help. As a rough guess I would suggest that the maximum amount of duct size that seems sensible would be an amount whose cross section area was about the same as that of the AC unit. ...
Just be aware that there is considerable loss due to turbulence along the wall. You can almost imagine that the 1/2" next to the wall doesn't flow any air at all (as an approximation), so you can't squeeze the pipe down to 1" thick and think you're going to get much flow.
Zep
Old 01-23-2008, 09:01 PM   #512
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Nice job debating this issue, fellas. I have nothing to contribute of any substance, just interested in seeing the outcome.
www.nesa.org
Air No. 6427
Old 01-24-2008, 07:53 PM   #513
1973 31' Sovereign
Portland , Oregon
Images: 22
Fantastic fans on with the vent closed?
I have been thinking a bit more about the notion of turning on a Fantastic vent fan with the vent lid closed. Is there an interlock switch to prevent this? If I did turn on the fan with the vent closed just how much air movement might it cause even though it does not have air coming in on top of it? Could this cause enough air circulation to move the cold air at the floor up higher? What do you guys think? I have three Fantastic fans in my 31' and I would like to consider mounting an AC unit (or two?) down low. I do have an overhead one but I do not even know at this point if it is fully functional. I also don't like the looks of the pod on top although I did spend some time patching the shroud where it had cracked and repainting it.
Malcolm
Old 01-24-2008, 08:31 PM   #514
1975 31' Sovereign
1977 23' Safari
Malcolm,
1. The Fantastic fan has a cutout switch--won't run with the lid closed.
2. The fan is tightly shrouded. I doubt any air will move even if the fan would run with the lid down.
Now, if you wanted to make some side draft channels and mount the fan about 2" lower (I don't know how you'd do that, considering the lip around the fan body), you might be able to make some side inlets that would draw air from right adjacent the ceiling...but you'd bump your head.
I like the idea, though. Maybe some computer pancake fans (4 of them) could be rigged up in a way to do this, but you'd probably have to make some depressions in the ceiling and sacrifice some insulation.
Zep
Old 01-25-2008, 06:46 AM   #515
Idiot Savant
1967 22' Safari
Auburn , Alabama
I am going to preface this by saying that I am a little timid about posting this up, because I feel like Malcolm is crazy enough to do it . . .
Why not run vents from the shroud behind the exterior walls?
It seems like (from pictures) that you could run tubing in the walls back down to the floor (feel like this would get a more complete circulation
I mean - you would have to pull some walls . . .
just saying =P
might be one of the worst ideas I have had on this forum :shrug: just tossing it out there
- Melon
Old 01-25-2008, 07:51 AM   #516
Addicted to Aluminum
A-Merry-Can's Avatar
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
seeing my thread pop up every day is motivating me to get back on the project! hehe! Time to get some measurements for the bed and couch cushions, then start on the bathroom and plumbing...
JP
8576 • • • • • • • •
there's always room for one more!
A-Merry-Can is offline   Reply With Quote
Old 01-25-2008, 08:18 AM   #517
Idiot Savant
1967 22' Safari
Auburn , Alabama
Sorry - I can't figure out how to edit (I may have abused it or something so it was taken away?) but my last post wasn't exactly clear.
It looks like (in pictures) that there is enough clearance between the fan and the closed shroud that you could vent the fan into the interior walls (into a channel or duct) and have it dump at the floor.
I think that is a more cohesive thought.
thank you.
- Melon
Old 01-25-2008, 09:38 AM   #518
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
Shell-Off Floor Replacement?
JP
JP,
It is neat how threads wander, change and develop. You started with one Air Stream now have 3?, a boat and a baby or 2 if I remember correctly.
I admire your work.
How are you doing the air handling (HVAC) in your rigs?
R
"Talk is cheap, Airstreams are expensive," Wally Byam.
fastrob is offline   Reply With Quote
Need a step? jcanavera 2001 Safari 8 01-26-2003 11:05 AM
Handy hitch step Pahaska Our Community 0 06-26-2002 05:44 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 02:35 PM
