Old 09-07-2007, 06:29 AM   #463
Addicted to Aluminum
A-Merry-Can's Avatar
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
last nite pics
I took some more pics last night after the sun went down...
ID:	44557   Click image for larger version
there's always room for one more!
A-Merry-Can is offline   Reply With Quote
Old 09-09-2007, 09:03 AM   #464
urbanfood's Avatar
1956 22' Flying Cloud
Venice , California
great work as always.
where did you get the doors? i bought the marinco 30A and the 110 and cable look like that. did you buy the doors separately and just cover the 110 outlet and cable?
david
*by asking the above question,
i verify that i have already used
the search feature to the best of my ability...
urbanfood is offline   Reply With Quote
Old 09-09-2007, 04:49 PM   #465
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
i actually bought a second tv/phone marinco plug, and made the 110 outlet mount from a sheet of aluminum, cut round to fit in the marinco mount, and a surface panel mount outlet from McMaster. I used a fly cutter to maker the holes exactly the size I needed. I wish I had taken pics of the whole process. The outlet was actually one of my cooler custom mods!
If you look just to the side of the outlet, you can see one of the rivets I used to mount the panel outlet to the aluminum sheet.
jp
Old 09-09-2007, 06:44 PM   #466
Ken J's Avatar
Durango , Colorado
Images: 14
How did you cut the hole for those units - you mention a fly cutter - is that what you used - if so what is a fly cutter?
Ken J
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 09-09-2007, 06:59 PM   #467
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
the piece, when finished looked like a perfect "o". a fly cutter is for cutting metal. It's got a drill bit as a pilot hole, and a small cutting knife that can be adjusted along an arm that extends perpendicular to the bit. THe adjustability makes it perfect for making specific hole sizes. The blade is tapered on one side to ease the cutting, so when it cuts teh metal, it puts a taper in the metal, so it's important to get the steps right when cutting it from a piece of aluminum. Here's my step-by-step.
1) measure the inside diameter of the surface mount plug
2) set the fly cutter up for the diameter of the plug cutout, with the taper to the INSIDE (DO NOT cut the outside diameter first, or you will have no metal to hold on to)
3) either reverse the fly cutter head so the taper's on the outside, adjust for the outter diameter and cut again OR have the outter sircle scored in the metal prior to making any cuts, make rough cuts and finish with a bench sander. NOTE: if you use the fly cutter for BOTH cuts, you MUST keep the piece attached to your drill press so it stays lined up). I chose to just finish the outside circle on the bench sander because it seemed easier, and the circular patches I did on my 62 Globe Trotter project turned out pretty nice!
Hope that helps!
jp
Old 09-09-2007, 07:24 PM   #468
Ken J's Avatar
Durango , Colorado
Images: 14
I think you lost me - can't you just make one cut for the diameter of the plug? When you say taper, I assume it cuts at an angle so there is a very slight taper in the alum when cut?
Last time I cut a hole I used a hole cutter thats actually for wood - lots of teeth - I figured if I messed up the cutter I would just throw it away, as it turns out it made a nice hole the aluminum - I always wondered how they made those nice round holes and I had assumed a special cutter like you are describing, except I'm not really clear on it.
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 09-09-2007, 08:15 PM   #469
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
you can use a hole saw for the inner hole, too. That would probably be easier, but I would definitely recommend rinishing the edges of the outter circle with the bench sander. It gave me great results on the 3 round patches, and porch lite surround ring on my Globe Trotter.
jp
Old 09-09-2007, 08:20 PM   #470
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Ken, if you're using the hole cutter I'm thinking of--they type you use to cut a hole in a door for dead bolt, for example, you can buy the some hole cutters for use on metal. They front door in on our house is metal, so when I installed the dead bolt I had to buy one. The teeth look more like a hack saw that the large, open teeth found on the hole saw used on wood.
www.nesa.org
Air No. 6427
Old 09-10-2007, 06:13 AM   #471
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
and now for something COOL....
Here's where I am so far with the AC installation. I bought a tiny Samsung 8K BTU unit at Lowes for $150 on clearance. It's supposed to be good for a 12X15 room. The price was right, the size was perfect, so here we go....
First, I disassembled the AC unit from the case and drip pan, then i drilled 2 holes (one on each side...curb and street) so that the condensation would drain out, rather than over the pan. Finally I added 2 brass nozzle fittings so i can attach 2 hoses.
Why did I drill 2 lines? Well, it's always more difficult to thet the side to side level right, than it is to get the front to back (because of the jack), and in the event that I'm slightly off-level, I wanted as much of the condensation to drain as possible.
Here's a pic of the underside of the unit with the fittings attached:
Old 09-10-2007, 06:16 AM   #472
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
next, I drilled (2) 2" holes in the floor, and sealed the edges with Poly. Once the unit was lined up, I cut the opening in the side wall to let the hot exhaust out...
Old 09-10-2007, 06:18 AM   #473
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
The 2 drain lines run through the floor and straight out the belly pan, through grommeted holes. I thought about making a "Y" connector so I'd only need 1 hole, but it's the belly. Who looks at that?
ID:	44931   Click image for larger version
Old 09-10-2007, 06:21 AM   #474
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
Next, I built 2 wooden brackets to suspend the AC unit 3/4" off the floor. I did this for 2 reasons, First so I could easily check for leaks, and second, I didn't want the condensation pan to sit directly on the floor filled with cold water. I figured that would only accellerate mold and floor rot in that area... sometime down the road. Here's a pic of the brackets...
Old 09-10-2007, 06:24 AM   #475
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
Next, I built the shroud to isolate the intake air for cooling the unit from the interior of the trailer. This shroud fits snugly to the curved sides of the trailer, and extends about 2/3 the length of the unit (from wall to front). When I did my measurements on this piece, I forgot to add the 3/4" for the riser brackets, so I'll need to trim it down before I can install it with the AC unit.
Old 09-10-2007, 06:31 AM   #476
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
I removed the shroud for now, and installed the unit to tripple check that everything lined up correctly, hooked up the drain lines, and test ran it. She cools great! We didn't let it run long enough for the condensation to run out, but I had test run it for an hour the day before, and everything drained as it should.
The next steps for me here are:
Cut down the shroud so it fits snugly to the top of the unit
seal the exhaust to the trailer sides
Install tie-down straps to the unit
order and install the louvered door on the outside
cut intake vents in the floor (for the unit cooling air)
see if I can make an extension cable for the unit control, so I can install it on the face of the front couch.
oh, and then CHILL OUT! haha! Ducting will come later, when I address the kitchen cabinets.
ta ta for now!
jp
ID:	44935   Click image for larger version
Need a step? jcanavera 2001 Safari 8 01-26-2003 11:05 AM
Handy hitch step Pahaska Our Community 0 06-26-2002 05:44 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 02:35 PM
