Old 04-01-2007, 04:06 PM   #379
Addicted to Aluminum
A-Merry-Can's Avatar
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
6" i.d. 10" o.d. this porthole was made for a wall 1 1/2" thick, so it fits perfect. because of the curve on the door, it's a little tricky to snug it up, without distorting the aluminum door too much. i have foam spacers in teh door, though, which helps hold its shape.
jp
8576 • • • • • • • •
there's always room for one more!
A-Merry-Can is offline   Reply With Quote
Old 04-02-2007, 12:51 PM   #380
Sugarfoot's Avatar
1958 22' Flying Cloud
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area , Tennessee
A Pickle with a Porthole
So the Silver Pickle has a porthole ~~ VERY cool.
JP, you did an awesome job with that. I approve.
Traveling With Elvis
life with a 1956 Sovereign of the Road
Sugarfoot is offline   Reply With Quote
Old 04-02-2007, 03:20 PM   #381
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
thanks! the Silver Porthole should be ready to set sail this year! (i hope).
jp
Old 04-24-2007, 05:52 AM   #382
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
Working on the end cap....
I started sealing the interior panels (birch), but before i start putting wood in the pickle, i thought it best to take care of the endcaps (leak wise). I'm working my way up, one panel at a time, polishing, and sealing... polishing, and sealing... polishing, and sealing...
also, i found a great way to clean up the vulkem that dried on the skin from last year. caulk remover from Ace. put it on, rub it in, let it sit for an hour, and pressure wash it off. works great!
jp
Old 04-24-2007, 01:25 PM   #383
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
more messy work...
2 1/2 more panels polished... 2 seams sealed....
Old 04-29-2007, 04:46 PM   #384
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
My A.D.D. must be kicking in again... either that, or it's too blasted hot to finish polishing the exterior... so... time to start talking BIRCH! First, i test fit the pieces, and clecoed them in place, trying to get all the ends to line up just right. I kinda lucked out with the 18 footer. the flat walls are exactly 8 feet. So i cut the birch panels 5' X 4' (down from 5'X5'... Baltic birch comes in funny sizes).
After test fitting both wall pieces, i marked the window from the outside, removed removed both panels, cut the window opening and switch/outlet holes, then finally put down a final coat or 2 of satin poly and let them dry for a couple of hours.
Old 04-29-2007, 04:49 PM   #385
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
I am doing something kinda cool for the joints. instead of lapping the wood, I'm butting it together, with a thin aluminum strip behind both sheets. this does 2 things, 1, it will prevent any future water from getting in between teh wood, where it's most vulnerable, and second, it allows me to rivet both sheets of birch to it, making a smooth surface for cabinets, etc. when it's all together, i plan on covering it up with a 1" piece of cherry.
jp
Old 04-29-2007, 04:51 PM   #386
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
here's the final side... for today anyway. i may try to do the other side tomorrow if i have time. i love it with the polished end caps! v. cool!
jp
Old 04-29-2007, 09:03 PM   #387
Sugarfoot's Avatar
1963 16' Bambi
JP, that's nice! The birch gives the interior such a warm feel.
Old 04-30-2007, 04:27 AM   #388
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
the pics don't do it justice. I'm going to try to get a few more panels at least test fitted in today. stay tuned! I'd love to be able to take the little guy camping this fall!
jp
Old 04-30-2007, 01:15 PM   #389
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
Second verse... same as da first!
i took an "Airstream Day" today. boss said it was alright. ha!
I'm about 85% through the curb side now. All that's left is finishing up the bottom of the panel that spans the door opening. It feels like about 100 degrees in that trailer right now, so I'm saving the finer strokes for when the sun goes down.
Old 04-30-2007, 01:26 PM   #390
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Looks awesome!
-Tim
theVAP - Airstream Podcast
Old 04-30-2007, 07:36 PM   #391
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
Cheers, Ambassador!
jp
Old 05-03-2007, 07:10 PM   #392
Wood
Yeah! This looks very familiar, I like the butted look - even without the cherry strips.
c
jcferguson is offline   Reply With Quote
Need a step? jcanavera 2001 Safari 8 01-26-2003 11:05 AM
Handy hitch step Pahaska Our Community 0 06-26-2002 05:44 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 02:35 PM
