Old 11-30-2006, 09:32 PM   #323
NorCal Bambi's Avatar
1963 16' Bambi
Yreka , California
Images: 21
There is a saying in the aviation world that refers to retractable gear aircraft.
"There are those who have, and there are those who will" Sorry about the door. I've been there and done that!
Don
NorCal Bambi is offline   Reply With Quote
Old 12-01-2006, 02:13 AM   #324
Addicted to Aluminum
A-Merry-Can's Avatar
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
oh, i wish they were mine! i'm just fortunate enough to have access to a shop.
there's always room for one more!
A-Merry-Can is offline   Reply With Quote
Old 12-03-2006, 06:31 AM   #325
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
We Have A Door!!!
... well, about half of one... i picked up where i left off on the door project, shearing and breaking metal panels to form the outside door of the silverpickle. i'm using .040 on everything, thinking it would make the door more sturdy. man, was i right! unbelievable difference. i don't know if it because the thicker metal, or the freshly rivetted panels, but there's hardly any deflection in the panels at all now. amazing!
here's a few pics of the before lunch work. test-fitting the exterior vertical pieces, and checking the curve against the trailer. notice the rolled lip on the door skins where the door in a door goes. very classy!
jp
Old 12-03-2006, 06:33 AM   #326
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
Door bottom...
after lunch i worked on forming the exterior lower portion of the door, 2 shears, 3 breaks and a little belt sander work, and she was ready to install. here'ss a few pieces more pics...
Old 12-03-2006, 06:37 AM   #327
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
...flip her over...
... satisfied with the fit of the 3 exterior lower panels, i decided to flip it over and start on the interior panels. this adds a TREMENDOUS amount of structure to the door. when i was drilling the holes for the new inner skins (also .040), i put a little pressure on the door frame to give it a little more curvature to it. i als employeed the same insulation methodology i've been using on the rest of the trailer...
Old 12-03-2006, 06:44 AM   #328
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
... test-fitting...
... finally with the 3 exterior lower pieces, and the 3 interior lower pieces installed, i test fit the door. ouala! the top and bottom edges suck in WAY better to the body than before i started on this endeavor.
Old 12-03-2006, 06:49 AM   #329
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
Before/After
here's a before and after comparisson... not only is the door sucked in, but it's incredibly more rigid as well. next on the agenda is the top pieces, eyebrow for the door in a door, and the second door. i might be able to get to all that before the next weekend, if not then. forming the edge on the top piece (exterior) has me scared. it's not a simple straight break, so that will have to be done, probably by hand. not looking forward to it... working .040 2024 is tough. it's about as unformable as aluminum gets (for this application, anyway).
time consuming, but well worth the effort!
jp
Old 12-03-2006, 09:43 AM   #330
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
looking really good....great we have had such terrific weather ( apologies to the mid west and others) so we are able to work outside. I hung out in my trailer last night, had some wine, some alone time with the guitar and the lp heater on 60...very nice.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 12-03-2006, 04:51 PM   #331
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
i'm so glad you didn't sell your trailer, man! HOPEFULLY, i'll be bringing the little guy to the april rally in hiawassee. it's too early to say for sure, but i think that's manageable.
jp
Old 12-03-2006, 05:41 PM   #332
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Hey JP, my trailer was hit by something in the door frame and main frame so I hear ya!
When I see you at Topsail I show you mine.
'77 Sovereign Intl 31' CB
Old 12-09-2006, 09:30 AM   #333
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
there's nothiing exact about these airstream door frames, that's for sure! but finally, i have all 4 outter pieces back together. i still need to rivet on the eyebrow, and put in the upper panel on the inside, but that's going to have to wait for a few days. it's freezing outside this morning!
anyway, on to the pics. the top piece is on, but still needs to have the decor edge formed in. the door handle is lubed up, and works like new! (that will need to be replated later... i can't WAIT to see THAT bill!) the holes for the door in a door latches are drilled, and teh old latches (both broken) are temporarily holding the door nice and snug. replacements are enroute from VTS, in my seemingly weekly shipment...
next up, reskinning the smaller door, and finishing the interior panels and gutter. then it's door seal time, and i'm done. i'm sorta torn on the door seal at this point. i have enough of the VintageTrailerSupply door seal to do both inner and outter, but in my test fit, the seal is so thick it makes it near impossible to close the door. has anyone else used this? does it settle down after a while? the seal was airtight, so that's a good thing! just don't want to strain every time i shut the door...
jp
Old 12-09-2006, 09:55 AM   #334
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Your progress looks great,Jordan. I have been following your posts, and am impressed! Freezing? What is it? Oh, yes, I remember - that nasty low temp condition that makes your fingers blue when trying to work around frozen metal..
I remember the weekly shipments from workin on my 63 Overlander. It will subside soon, after you pawn the cars, house, cat, and wife's bling...
jp
I still have to re-skin my inner main door, and the inner vent door. I was considering a thin maple veneer overlay, but I am not sure of the longevity of such a plan.
I had similar trouble with door seals. What worked best for me, was the compartment and window seal for a ealry 70's Airstream, it is a double lipped profile. This is what I bought: http://www.inlandrv.com/parts/005s-gasket.jpg part number is 45295
It is the only material that would allow me to close the doors. I used it on both outer and inner door, and it is flexible enough to make a double seal after a while when it has settled some. One seal on teh door frame, one on the door jamb.
I can't say that it would fit your application as well as it did on mine, but it's not very expensive, so buing a few feet to try wouldn't break the bank.
Good Luck!
Uwe
www.area63productions.com
Old 12-09-2006, 10:34 AM   #335
1963 16' Bambi
Yreka , California
Images: 21
JP, I have tried 3 diffetent types of seals. I had the same problem of the fit being to tight an putting strain on the door. I've seem Uwe's door seal and it worked great. I'm going do the same thing. Just waiting for warmer weather to start work again. Your trailer is looking great.
Don
Old 12-09-2006, 11:09 AM   #336
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
if it's good enough for Uwe, it's more than good enough for me! i'll order some monday. the Vintage Trailer Supply stuff is so much thicker around the bottom. you CAN compress it, but it's hard work. i also like the idea of a double seal.
jp
Need a step? jcanavera 2001 Safari 8 01-26-2003 11:05 AM
Handy hitch step Pahaska Our Community 0 06-26-2002 05:44 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 02:35 PM
