12-13-2006, 02:30 PM
#341
1975 27' Overlander
LAS VEGAS
, Nevada
Floor Replacement Underway
Hi Jordon - thanks for posting this helpful step by step. I am in the process of replacing the floor on my 75 Overlander. What type of ply wood did you use and/or do you know what is recommended for the floor?
Thanks much,
Toni Mac
12-13-2006, 03:05 PM
#342
1973 31' Sovereign
Portland
, Oregon
Originally Posted by ankornuta
The slide show is impressive! At the very least this looks like it would be a great product for stripping off clear coat and other gunk on the outside. I wonder what is does to old silicon sealer? That would be great if it just happens to be able to strip if off too.
Malcolm
12-13-2006, 03:54 PM
#343
Addicted to Aluminum
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
There are lots of clear coats out there, but they usually end up peeling when exposed to the weather. However, on the inside of a trailer, I think they would last much longer... hmm... I kind of want to leave my interior aluminum bare... it looks nice!
no clear coats for me! i'm hoping i can get it pretty decent with nuvite and rouge, then just spray it with motorcycle polish or whatever to give it a thin sheen. it is looking better every day! i tell ya, though... HARD work! i had to sand the last bits of the panels with 220, then used my buffing wheel to cut it back, and shine her up... final buffing (for now) was a regular orbital buffer. i'm planning on doing the random orbital thing before i get to installing the wood around it... if santa's good to me, that is! ha!
jp
there's always room for one more!
12-13-2006, 03:56 PM
#344
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
Thanks much,
Toni Mac
i can't remember exactly, i think it was CDX? something like that... seal both sides with Polueurathane. i wish i had done that. i just did the bottom. DON'T use pressure treated wood. there's something in it that corrodes aluminum... plus it weighs twice as much.
good luck!
jp
12-13-2006, 03:57 PM
#345
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
Pics of tonight's endeavor...
i'm so close i can taste it! i tell ya... it REALLY strains the back doing the top bits! ug... who's stupid idea was this to polish the end caps? oh yeah....
... mine ...
jp
12-13-2006, 05:09 PM
#346
1966 26' Overlander
Woodstock
, Georgia
that stripper looks great. I used the Removall, which is enviro friendly also, it worked very well on the clearcoat. I don't know if it would remove paint quite as well. I want to strip our older Chevy Truck, and that stuff might do the job well. Have to see if Benjamin Moore carries it here. How much is it, I did not see pricing on the site?
12-18-2006, 02:17 PM
#347
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
interior polishing coming along nicely!
well, finally got the initial polish done on the rear end cap. i'm going to follow up with NuVite next, then Wenol, and i'm calling that one DONE! i also installed the first of the roof sections in teh rear, and started installing the new recessed lighting. it looks awesome! i can't wait to see it all together with the maple panel walls, as soon as i can get to it, that is! here's a few pics...
12-18-2006, 02:37 PM
#348
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
Inner Door Re-skin...
i finally got around to finishing the inner door this afternoon. a few days ago, i formed the outter skin at a friends with a 50" shear and a break. it looks exactly like the original... except no dents, and all new aluminum! no new techniques here... just the same ol same ol... line up the formed metal skin, 4 clecos on each corner... test fit... drill the rest of the holes and cleco-mania!
i disassembled it after all the holes were drilled, so i could buck in all the rivets on the hinges. the only bucked rivets on my original door were on the edge, with pop rivets on the rest. i'm guessing (if that was original) it was quicker than assembling the door with clecos, disassembling, bucking in the hinge, then reassembling the inner frame, and buttoning it up.... but, it really looks wierd to have half one kind of rivet, and half another on the hinge, so it was worth the effort.
then i test fitted it again, so i could locate the retainer tab for the bargman latch, disassembled the whole lot and bucked that tab in as well. re-cleco-ed, re-rivetted, and rehung the door. looks great!
the next steps on this door is i'm going to have to replace the top piece, since i put that one in a little askew. perhaps this week, if i get a free moment or 2 also left to do on the list is sealing the door, and installing the 2 remaining pieces of interior panel (top and bottom). one thing i have learned about these doors, in rebuilding this one is the interior top and bottom pieces are very critical to getting a good even close around the edges. the side pieces hold it really tight to the curve of the trailer, but the bottom and top pieces affect the way the door twists. originally, i put the one on the bottom without checking the fit, and lo and behold, the door was slightly twisted. i removed the lower panel, and the door closes fine. i'll post pics later of this fix, after i get the outter top piece replaced.
i love working on the skins on these things, but i HATE doing things twice... HOW MANY TIMES do i have to say the ol saying... "MEASURE TWICE CUT ONCE, STUPID!!!!"... i'm learning....
ha!
jp
12-18-2006, 02:55 PM
#349
Silver Mist
Riverhead
, New York
That's really sweet, I love that hinge
12-18-2006, 03:05 PM
#350
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
thanks man. sure looks better than it used to!
jp
12-18-2006, 03:12 PM
#351
Vintage Alum. Enthusiast
1959 24' Tradewind
Phoenix
Man - oh - man!! That is awesome. Nice work.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
12-18-2006, 03:14 PM
#352
2006 19' Safari
Suisun City
Whew Wee!!
Great workmanship! I love seeing what talented people are on this forum and what amazing things they can do. Makes me wish I were more of a "handy man" myself and had some of all of your cool toys (er, tools)!
Nice job. Can't wait to see the final AFTER photos!
Roscinante
Jerry and Avis
2006 Safari Bambi 19'
2005 Toyota Tacoma PU
"Mi Casa Es Su Casa!"
WBCCI #6716
AIR #17388
12-18-2006, 03:28 PM
#353
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
FF
thanks mate! i was looking at your hinges on your december photo contest. it looks like yours has half bucked and half pop-rivets like mine did. what do ya know. that might have been original? also, i have the same pull handle, but i replaced it with a cleaner one off eBay.
http://www.airforums.com/forum...0&d=1165987225
jp
ps. i moved my ID tags from the left to the right side so i could admire em with the door open. did ya notice?
12-18-2006, 07:13 PM
#354
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
you and me both, man!
jp
12-20-2006, 01:26 PM
#355
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
Interior lights.... continued!
i got the rest of the dome lights and panels in. could use a touch-up polish, i guess. i'm really looking forward to getting the wood panels in next.
jp
12-20-2006, 01:27 PM
#356
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
couldn't resist...
... test polishing the new door panel...
12-20-2006, 05:51 PM
#357
Remember, Safety Third
Catfish Corners
, Georgia
JP, please forgive me if you've already told me or postedv this, but what lights did you decide to go with?
12-26-2006, 06:04 PM
#359
1953 21' Flying Cloud
Carson
, New Mexico
jp,
Just beautiful - love the work you're doing - feeling jealous and inspired - I look forward to watching your progress.
thanks
theresa
12-26-2006, 06:17 PM
#360
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
i don't know how inspiring it is, when you look at the starting date of this thread! ha! but it is rewarding, that's for sure.
jp
