Old 11-16-2015, 06:44 PM   #15
1976 31' Sovereign
Jacksonville , Florida
Hmm that sounds expensive.... I mean, there is a point of me rerun as far as money goes.
Andy Moreau is offline   Reply With Quote
Old 11-16-2015, 06:47 PM   #16
1976 31' Sovereign
I don't want to spend as much as a coach or even a new airstream would cost. I don't mind walking from this with 16-20k into it total, because I believe I can get that out of it so long as I do the major things right and take care of it for the time that I have it. Would you all agree?
Old 11-17-2015, 06:31 AM   #17
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
It's all up to you! I still like the idea of an aluminum frame. I would expect it to last much longer. Have your friend run a cost comparison steel VS aluminum.
Silverflames is offline   Reply With Quote
Old 11-17-2015, 07:45 AM   #18
2016 25' Flying Cloud
Holly Springs , Mississippi
Originally Posted by Andy Moreau View Post
I will bring this to my welders attention when he arrives. May as well do it right the first time!
Andy, often rust starts at the weld site. Have your welder spray all weldments, while they are still hot, with a good primer paint. This will help prevent the weld from pulling in moist air as it cools.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 11-17-2015, 08:41 AM   #19
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Steel to Aluminum frame
It will also cause a small flash fire.....
If I were making a new frame I would use 2" X 5" rectangular tube for the rails and for some of the cross members, the balance in 2" X 4" channel.
It would be steel, and barring a bad accident it would last many decades.
Brevi tempore!
Frame Steel Alloy? judflor Repairing/Replacing Floor &/or Frame 9 10-12-2016 08:56 PM
The quest for a new stainless steel frame boatdoc Repairing/Replacing Floor &/or Frame 64 11-28-2015 07:43 PM
Frame Steel thickness Muskie Repairing/Replacing Floor &/or Frame 3 04-01-2014 09:25 AM
Is there corrosion between the steel frame and aluminum floor in Minuets? timzog All Argosy Trailers 10 06-17-2012 02:52 PM
steel or stainles steel screws remcolent Ribs, Skins & Rivets 11 03-30-2004 06:54 AM
