User Name
Password
Portal Register FAQ Members List Rally Calendar Chat Room Mark Forums Read
Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Click Here to Register!
- Monthly Newsletter
Old 02-20-2008, 05:02 PM
  #29
SIU Bound
Profile:  1973 27' Overlander
Loganville, Georgia
box and frame to hold it finished
I finshed the black tank box. I por-15 the outside and the inside of the box. I had some bed liner spray and used it on the inside. I had my friend make the frame out of 1/8 inch angle iron. Everything has been done to the orginal specifications.
Check out the pic
SIU Bound
Brian
Name:	box finished 1.JPG
Old 02-20-2008, 05:19 PM
  #30
Jim & Susan
Jim & Susan's Avatar
McDonough, Georgia
Lookin' good. Great friends you've got there.
Any significantly advanced technology is indistinguishable from magic. Arthur C. Clarke, C.B.E. (1918-2008)
www.nesa.org
Air No. 6427
Get rid of these ads... register today, it's FREE
Old 02-20-2008, 05:28 PM
  #31
SIU Bound
Loganville, Georgia
Jim:
This man who built the 1/8 inch frame to hold the box is brilliant. He teaches welding and does a great job. He is going to come over to do some welding on the disintegrated part of the rail and put the box frame in. Once he does that I am ready to put the floor in. I bought the Nyloboard Monday and it looks great. I think it will work really well. I ordered my black tank through the airstream dealer in Jonesboro and I am waiting for it to come in. I ordereded about one month ago. I will call them tomorrow. I also want them to put a new dump valve and senors on the tank for me.
SIU Bound
Brian
Old 02-20-2008, 06:26 PM
  #32
rmpray
rmpray's Avatar
Profile:  1973 31' Sovereign
Bertram, Texas
You are cruising right along! I like the bed-liner idea, and of course the floor material. You are planning on making this rig reach 73 again
Catmando
"There’s not much in life we can’t over-analyze”
Old 03-02-2008, 03:40 PM
  #33
SIU Bound
Loganville, Georgia
Floor Template
I took measurements for the new floor and made a template from foam board. I made it just a little bit bigger then what I need because I figure it is easier to shave off extra then to mess up the Nyloboard. I will definitely re-measure before I make cuts. Check out the pics
Welding is suppose to take place next week to install the new frame to hold the black tank box.
Brian
ID:	55399  Click image for larger version
Old 03-02-2008, 05:46 PM
  #34
balrgn
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County, New Hampshire
Looking good, man, you have a ton done! Our 73 did not requre that much attention....
'74 Overlander (Rear Bed)
'73 Overlander (Looking for a new home)
'77 20' Argosy MH (For Sale)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281 w)
www.balrgn.com
www.balrgn.com/Airstream.htm
Old 03-02-2008, 07:35 PM
  #35
fotochop
fotochop's Avatar
Profile:  1969 23' Safari
New Orleans, Louisiana
Before you permanently weld the tank frame in make sure your's didn't have four little tabs welded to the main frame that the two angle iron supports actually BOLTED to, first. The purpose of this was so that the black tank can be DROPPED out the bottom of the trailer (for service/maintenance) without much trouble. Well, a lot less trouble than cutting a welded frame out would be, ya? You'd just take out four bolts/nuts and the two angle iron tank supports would drop out after bellypan removal. just a heads up\
fotochop
Rick Olivier
New Orleans
http://www.rickolivier.com
Old 03-02-2008, 07:38 PM
  #36
Jim & Susan
McDonough, Georgia
Boy, does that look familiar. I did the same thing, but used luan instead of the foam. Just happened to have a bunch of that available at the time.
Now that the weather is finally warming up, you should make make some good progress. Keep us up to date.
On Edit: Mine is just as Rick describes it. A couple of the bolts are a real pain to get out of there.
www.nesa.org
Air No. 6427
Old 03-10-2008, 04:46 PM
  #37
vhord
vhord's Avatar
Profile:  1970 27' Overlander
Crosby, Texas
fotochop
Rick,
My A/S (1970) has the bolted in supports that you mentioned. However, if the old supports had not rusted completely away the bolts were so rusted that it would have been imposible to remove them. Do you have any ideas on how to prevent this the next time? Should I use SS bolts? I am having to build a new tank box like Brian did and want to make the whole setup right.
Vernon
Crosby, TX
Old 03-10-2008, 07:14 PM
  #38
fotochop
fotochop's Avatar
maybe a metallurgist here can weigh in on the SS vs. galvanized bolt debate? I'm just putting galv in mine with self-locking nuts (have a plastic bushing inside the nut threads) and POR-15 on just about everything. a real trailer-ist will probably be dropping the belly pan once a decade anyway just to keep life interesting... The POR will really slow down rust to where it should not be a problem. If you compare the before/after images in my '69 Safari Bath Repair thread you'll see what I mean. It's amazing stuff. So much better than OEM paint. If your supports are shot you'll have to weld new ones anyway, just be sure you POR 'em after..
Rick Olivier
New Orleans
Old 03-10-2008, 07:47 PM
  #39
vhord
vhord's Avatar
Crosby, Texas
Thanks Rick for the reply. HD galvanized bolts with POR-15 on the metal sounds like a good solution.
Old 03-11-2008, 04:58 AM
  #40
SIU Bound
Loganville, Georgia
I have had small brackets made for the back end of the frame for support. I guess it is what they call dog ears. They will support that small area that does not sit on the frame. I have seen several pictures in past threads which show where airstreamers have installed them. My welder told me that he needed bare metal to do the welds for those bracket supports. So I had to remove the por-15 to expose some metal for the welding to take place. Oh boy is that paint protectant tuff. It took me the use of a grinder to remove the paint. The wire brush on the grinder would not remove it. Once the brackets are installed I will put more Por-15 on.
I plan on using galvanized bolts with nylon lock nots on holding tank box frame. I am not worried about them rusting. I figure I am in my mid 50's and by the time they rust I will probably be dead and gone to the airstream campgrounds in the sky.
SIU Bound
Brian
Old 03-21-2008, 03:40 PM
  #41
SIU Bound
Loganville, Georgia
Welding of the frame, the new brackets that hold the black tank box installed, the new little frame brackets to prevent end separation are in place, Por-15 coated on metal, and the new black tank arrived yesterday. Now it is time to start to putting it back together. I will take pictures tomorrow.
I decided to take the old belly pan and patch it. After I priced aluminum I decided I needed to save money somewhere. I took old roof flashing, sealant, and rivets and patched it up. It should work fine. Nobody is going to be looking underneath anyway. Wow metals have gone up 600% in the last couple of years.
SIU Bound
Brian
Old 03-21-2008, 06:35 PM
  #42
Jim & Susan
McDonough, Georgia
Originally Posted by SIU Bound
.......I decided to take the old belly pan and patch it. After I priced aluminum I decided I needed to save money somewhere. I took old roof flashing, sealant, and rivets and patched it up. It should work fine. Nobody is going to be looking underneath anyway. Wow metals have gone up 600% in the last couple of years.
SIU Bound
Brian
That's exactly what I did and used the same logic as you. Nobody's gonna notice down there.
www.nesa.org
Air No. 6427
vB code is On
Pingbacks are On
New Restoration Project, '72 Overlander surferstyler 1972 Overlander 135 03-24-2008 10:19 AM
1958 Overlander Restoration Ken J 1958 - 1963 Overlander 125 08-21-2007 07:18 AM
DIY Network Overlander Restoration Series lubbockgolf Airstream "In the News" 12 07-29-2007 06:04 PM
1972 Overlander Shell-off Restoration Derek D Repairing/Replacing Floor &/or Frame 11 10-19-2006 07:51 AM
Start of restoration '77 Argosy 20ft barbwire All Argosy Trailers 18 08-15-2004 06:42 PM
Powered by vBadvanced CMPS v2.1.0
Powered by vBulletin® Version 3.5.8
SEO by vBSEO 3.0.0
Airstream is a registered trademark of Airstream Inc. All rights reserved.
Airstream trademark used under license to Social Knowledge LLC.
Wikipedia about Airstream - Airstream Central - Airstream Photos
