Old 07-05-2015, 12:08 PM   #1
Stanwood , Washington
Squeaky floor
The floor in my 2005 25' Safari squeaks just forward and to the refrigerator side of the stove end cabinet. I think it is over the holding tank. Don't know if this means something bad or if it just is a poor design. I can look at the plywood flooring by removing the cover under the stove and it looks like it has never been wet and looks solid. Anyone else had this issue and if so, can anything be done to stop the squeak? Thanks!
dfschultz is offline   Reply With Quote
Old 07-05-2015, 12:49 PM   #2
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
Dave, this is common but irritating. It's often solved by tightening or loosening screws that fasten the cabinetry and vinyl trim. I just quit worrying. It comes and goes (humidity?), and sometimes I adjust things, but mostly, I ignore it.
Old 07-05-2015, 01:40 PM   #3
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
Yup, my experience too. It's just seams moving against each other and will change depending on how level your unit is, or the weather. As Drathaar has discovered, it's best just to live with it.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 07-05-2015, 01:54 PM   #4
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
We have creaky floor disease in the bedroom of our 27FB - on the street side, just inside the bedroom forward of the shower. We've ignored it, as our moisture tester indicates no leaks in the area. The noise itself comes and goes when we walk there.
Rocinante is our 2014 International Signature 27FB
Rocinante is online now   Reply With Quote
Squeaky bathroom floor oceanair Floor Finishes 0 06-20-2009 09:35 AM
Squeaky Floor straya General Repair Forum 5 03-04-2009 12:16 AM
Which squeaky wheel should get the oil first. Aluminati General Repair Forum 11 10-17-2007 06:48 PM
squeaky floor clintn 2005 and newer - Bambi all models 2 04-18-2007 10:17 PM
Squeaky axles - are Henschens quieter? AlbertF Axles 5 11-17-2006 02:09 PM
