Old 03-10-2016, 07:04 PM   #29
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Interesting. A few years ago I was at the Tampa Super Show and visited a new Serenity model. When I walked around the bed, the floor popped and I grabbed the wall. Another looker commented as the sound was like popping metal. It was as if the edge of the plywood was sitting on top of a ridge or something. It popped back up when I walked away.
This kind of thing is a manufacturing flaw that could really happen to any year or model. My '06 seems very solid; however, there are some crooked cuts I note with particular trim pieces. Also, there are others who have stated that '06 years were known to be missing sealant around the rear bumper. Not mine but just sayin. I believe the flaws we find are more unit unique than general issue. I have tried myself to find general model issues without success. The one thing I have heard is water leaks around the rear bumper AND leaking pano windows.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 03-11-2016, 10:46 PM   #30
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Careful guys... The Go er me t may buy AS, then who would we gripe to. ?? Sorry should have posted this on the "argue" thread...
Peace and Blessings..
Channing
WBCCI# 30676
Old 03-12-2016, 04:38 AM   #31
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Okay I am going to post this fix again, though I am starting to think I am wasting my time doing this, because you all seem to want to punish Airstream and your dealer for this, and ignore what I say, rather than fix the problem for about $5.
Ahem...
The squeak is probably caused by the vinyl trim along the edge of the floor rubbing against the aluminum interior wall. The squeak can be eliminated by simply spraying some silicone dry lube along the top edge of the vinyl trim. If it still squeaks slightly, you can loosen the screws holding the trim in place, and you may need to move the trim all of about 1/32" away from the wall.
You're welcome.
Old 03-12-2016, 07:11 AM   #32
Plasma800's Avatar
houston , Texas
I'm going to try that
Ahem...
You're welcome.
'15 27fb Signature
'12 Chevy 2500HD Gasser
Plasma800 is offline   Reply With Quote
Old 10-08-2016, 11:00 AM   #33
2016 25' International
Gaffney , South Carolina
2016 25' IS here, same issue. Most of the sound seems to be coming from that vinyl trim. Does seem to be a bit of flex between bed corner and shower corner though. Add to the punch list.
DT57 is offline   Reply With Quote
Old 10-08-2016, 11:54 AM   #34
2015 25' FB Flying Cloud
Eugene , Oregon
Ahem...
You're welcome.
Yes, you, and Robert Cross, and someone else a while back in this thread hit the vinyl trim with the silicone (kinda like hitting the nail on its head ).
The squeaking is an annoying but easy fix as you said! We had the same issue and our Airstream dealership knew what it was right away (developed in our trailer after 15 months or so). I wish all fixes were so easy!
Meeks is offline   Reply With Quote
Old 10-09-2016, 04:23 AM   #35
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Did the OP try this too? If so - any results?
Floor Problems - Water under wood floor Ramblinboy Repairing/Replacing Floor &/or Frame 2 05-19-2012 09:58 AM
Floor Newbie - Tile floor DanielB Floor Finishes 15 06-15-2011 07:14 PM
What to do - Above floor Tank or Below floor tank ??? fatwgn Sinks, Showers & Toilets 8 09-06-2009 02:50 PM
Squeaking Drums? rambn Brakes & Brake Controllers 11 05-22-2007 01:57 PM
