Old 07-06-2006, 09:52 PM   #1
Profile:  1979 31' Sovereign
Baton Rouge , Louisiana
Images: 42
Sovereign Rebuild Check it out...
Guys,
I just posted a bunch of pics of my current project. Check them out and let me know what you think. There's lots of pics and stuff on insulation and floor repair. I would appreciate any comments and advice. Thanks.
-Don
cobra93 is offline   Reply With Quote
Old 07-06-2006, 10:04 PM   #2
Jim & Susan's Avatar
Profile:  1973 27' Overlander
McDonough , Georgia
Don, where did you post these pics?
Remember: If the enemy is in range, so are you.
www.nesa.org
Air No. 6427
Old 07-06-2006, 10:06 PM   #3
moderator
Janet's Avatar
Profile:  Eastern , Washington
Images: 65
Airstream Registry
They are the lastest photos here - in the 70's section and I'm liking the floor!
http://www.airforums.com/photo...p?c=504&userid=
77 Argosy Minuet, 6 metre | 77 Argosy 24, Rear door
AIR # 3181 | WBCCI # 5575
Bullies thrive where leadership fails
Janet is online now   Reply With Quote
Old 07-06-2006, 11:31 PM   #4
McDonough , Georgia
Don, Janet got my head on right, sorry. Looks good. Especially the floor. I really like the duct-tape-leak-stop-thing. Not too many folks actually have full appreciation of what C.A. is!
Keep us posted. We love the rebuilds.
www.nesa.org
Air No. 6427
Old 07-07-2006, 06:58 AM   #5
GA Airstreamer Air_005
ALANSD's Avatar
Profile:  North , Georgia
Send a message via Yahoo to ALANSD
My Sovereign project had the leak that rotted the floor beside the gaucho. In a small rain shower last week it wet the floor in the same spot.
After reading about the beltline leaks thru the belly pan area.(thanks Jim and Pizzachop) ...I taped the belt line over with masking tape layers....then last night we had a huge downpour for two hours or so. No leak....that nailed down the cause for me, and with a dried out floor I am repairing the rot and vulkem is going on the beltline and maybe under it if I decide to pull it off.e
I figure if tape stopped the leak then the vulkem will do the trick there.
Also there is a wall switch on a plate just ahead of this area, on the right facing out of the front....beside the gaucho. What does this control? Ours had tape over it.
Rallys twice a year..Lots of fun, food, and aluminum.
http://airstreampassion.blogspot.com/
My Music Ministry Site:
HTTP://ALANDAVIDSONGS.COM
Old 07-07-2006, 08:50 AM   #6
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 13
The wall switch is to turn off the converter so that the hum doesn't disturb sleepers on the gaucho. The switch is still shown on the wiring diagrams in my 2005, but they don't install the switch anymore.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2007 Silverado 2500HD Duramax/Allison LTZ
WBCCI Region 9 Webmaster, #9632
Old 07-07-2006, 10:25 AM   #7
ALANSD's Avatar
yep that's it....did not know until I plugged the shore power in.
Old 07-07-2006, 10:28 AM   #8
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Somewhere , Over the Rainbow
That's probably why the switch was taped over, to keep the converter from being inadvertantly turned off.
(No Longer at Inland RV)
Old 07-07-2006, 10:38 AM   #9
ALANSD's Avatar
so if its turned off while on shore power you have no inside power at all?
part two- where is the best place to grab 12v power so I can troubleshoot the tow light connector...from a 12 v socket inside I guess?
Old 07-07-2006, 01:58 PM   #10
Ron
herbigrf's Avatar
Profile:  1978 31' Sovereign
Battle Ground , Washington
upper windows
I have a 78 31' and my four upper windows are a mess inside. I see that you worked yours over. How did you do it?
Ron & Christie
1978 31 ft Soverign
herbigrf is offline   Reply With Quote
Old 07-07-2006, 02:48 PM   #11
McDonough , Georgia
Alan, with shore power on, turn on the Univolt. The Center Pin on mine is 12v hot with the Univolt on. The pic shows how I jumper from the center pin to the pin for the running lights to make them come on.
Name:	Running Lights jumpered.jpg
www.nesa.org
Air No. 6427
Old 07-07-2006, 03:02 PM   #12
ALANSD's Avatar
thanks I see that. I will try it and see what happens. I thought the power came from the tv.
-Have most folks removed the gaucho to install flooring?
I ordered the FX sheeting from Alsacorp I have been wanting for a long time. Got the aluminum stuff to use on my front walls. It should look great, and will brighten up the dingy yellowed area.
I scrubbed it all down to get it clean and will probably install this stuff next week.
www.alsacorp.com
"The metal layer is then backed by a strong acrylic-based adhesive, which both protects the metal further and allows the sheeting to be easily bonded to any surface, in a similar manner. Two different types of LEXAN® are used in creating FXSheeting. HP92H LEXAN® is used for creating Mirror versions, while 8A37V LEXAN® is used for creating Brushed versions. Both types of LEXAN® are 10 mil thick, but the 8A37V LEXAN® is made with a "brushed" texture so the Brushed versions of FXSheeting not only look like brushed metal, they also feel very similar.
Old 07-30-2006, 08:34 PM   #13
Images: 42
Janet, Thanks for the compliment. This is my first AirStream and I am loving it. My Father in Law has been a tremendous help on this so a lot of the credit goes to him. Thanks again.
-Don
Old 07-30-2006, 09:22 PM   #14
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
...vulkem is going on the beltline and maybe under it if I decide to pull it off. ... I figure if tape stopped the leak then the vulkem will do the trick there...
Be careful not to put two lines of Vulkem. One on the top is sufficient. Otherwise, you risk trapping water between the lines and who knows where it will go? If you want to Vulkem the skin joint, that's fine, just don't make an unnecessary trap under the belt.
MindsEyePhoto AirstreamDoctor PygmyKayaker
"It must be laid down as a primary position and basis of our system, that every citizen who enjoys the protection of a free government owes not only a proportion of his property, but even his personal service to the defense of it." - Washington
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
'78 Sovereign Awning Joan D'Andrea Awnings 6 01-03-2006 07:34 AM
85 Sovereign 25' j54mark 1985 Sovereign 7 10-30-2002 09:23 PM
Dump Valve Rebuild wagsrp Waste Systems, Tanks & Totes 2 10-12-2002 01:01 PM
Help with Ancient Sovereign patti 1956 Sovereign 2 06-06-2002 02:23 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
