Old 02-05-2016, 02:05 PM   #1
1977 31' Excella 500
Dallas , Texas
Source for the axle frame helpers...
I have the floor out on my 31' 77 Excella. What source do we have for those 'frame helpers'. Sorry, I don't know the proper terminology. Basically they look like they fit up along the existing frame, 'sistering in" to provide an extra layer of frame support. While I have not diagnosed a cracked frame, I would rather put them in while itís opened up than have to address it in a year or so.
Jack
Jack Moore is offline   Reply With Quote
Old 02-05-2016, 10:11 PM   #2
Dallas , Texas
I found a name. Possibly referred to as "Chasis frame rail reinforcing plate to be attached with bolts per Airstream Specification"
Old 02-05-2016, 10:19 PM   #3
Dallas , Texas
Found the below. Any insights?
If you really want to hear about the frame fix proposal you'll have to ask.,
Suggest before you do any fixing on your '77 that you get Airstream Bulletin Number 29 which is about fixing this problem. The main effort is installation of a frame rail reinforcing plate especially developed by airstream for this fix. It will require removing wheels and axles to install. Don't let any one with welding equipment say they can fix this problem by welding on some metal to the frame. Odds are it won't do the job. The bulletin tells you what to do and how. See if you can get it direct from Airstream and if not have a dealer request it for you.
The bulletin actually went out to dealers and authorized repair shops...
the Service Bulletin 29 from Airstream is applicable to /74 models. However, not every unit built with rear baths had a sag problem. Not sure why but might have a lot to do with how much it traveled and how often with a full grey water tanks located at rear. However, if you don't have a problem don't worry until you do. For a test grab the rear bumper and lift up. If the bumper moves and the trailer doesn't it is probabale you have the start of a problem.
There is a second problem with the '68 thru '72 models which was separation of trailer shell from the chassis. It looks like sag but is not as bad. For whatever reason the rear of the body of the trailer (shell) separates from the frame, probably due to rust of bolts, etc.. forming the connection. This can be fixed and Airstream Service Bulletin Number 1 gives the details of the fix...
Old 02-06-2016, 09:34 AM   #4
Dallas , Texas
Found something on Airstream Supply.
98 INCH TANDEM AXLE MOUNTING PLATE R.H. AIRSTREAM
Any experience with these?
Old 02-06-2016, 01:20 PM   #5
2006 30' Classic
1966 20' Globetrotter
Dover , Delaware
Here is a link to airstream service bulletin number 29.
http://odmrv.net/BentFrame/BentFrameBult.pdf
helwigc is offline   Reply With Quote
Old 02-06-2016, 02:28 PM   #6
That is an axle mounting plate, that you already have on each side of the trailer.
Post a photo or two of what your concerned issue is.
Then, many can jump in and help you.
Hehr window frame source, help! streamahead General Repair Forum 0 07-18-2013 07:28 AM
Rib & Frame source ?? thexporter Ribs, Skins & Rivets 4 09-11-2012 07:07 AM
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
frame replacement source cherring On The Road... 2 09-27-2003 05:25 PM
