Old 01-29-2012, 07:29 PM   #1
Anchorage , Alaska
Source for C channel?
Just released the shell of a 1963 Bambi. My current focus is checking the frame and replacing the axel, but looking ahead to re-mating the shell to the new floor.
I can fiddle around to see if I can bend the short "legs" of the C, and I can check around locally for a fab shop with a bake bender, but wondering if there is somebody that produces and mails strips of C channel? Can strips be nested to make this practical without distorting the channel?
Aktundra is offline   Reply With Quote
Old 01-29-2012, 09:30 PM   #2
1958 26' Overlander
Lander , Wyoming
I bought some that worked for me through Mcmaster-carr but looking in their online current listing I don't believe they carry it any more, The legs were 1/16 thick which gave more strength than the original. Try Brunner Enterprises. They have a # C21226 that looks like it might work. Its 1/16 thick and 1.5" inner diameter with 3/4 legs. The external diameter is 1 5/8 so a little wider than original (maybe by a 1/16th) Of course this only is the straight sections if you need the curves you'll have to fabricate them obviously. As for nesting the junctions I believe I used some flat aluminum 1.5 in across to sister them. Hope this might help. Ed
n2batr is offline   Reply With Quote
Old 01-29-2012, 09:46 PM   #3
Anchorage , Alaska
Thanks for the leads.
My comment on nesting, was just for purposes of shipping economically.
I may just sandwich the material between some plywood, and try bending up a bunch of my own.
F channel source. BB 55 Bubble General Interior Topics 2 12-27-2011 09:22 PM
C Channel 1976 Sovereign gronlampa Repairing/Replacing Floor &/or Frame 20 08-28-2011 09:49 AM
C channel bolts? Phrunes Repairing/Replacing Floor &/or Frame 11 06-12-2011 09:14 PM
Tempro/Vulkem under c channel? beckybillrae Repairing/Replacing Floor &/or Frame 2 05-23-2011 05:43 AM
Floor channel size when installing 3/4" plywood? surfpod Repairing/Replacing Floor &/or Frame 8 05-03-2011 12:25 PM
