Old 10-30-2010, 01:31 PM   #29
Trex's Avatar
1981 20' International
Shasta Lake City , California
Flooring over plywood
The Diamond plate would be under the cabinets and under the refrigerator and cabinets on the other side. I am thinking that I would cut the diamond plate in half, each section 24" wide and 8' long. Then I would cut out sections to go around the wheel well on the street side. The section under the refrigerator would be 24" wide by approx. 4' long. The front room and hallway will be some type of laminate that can survive future water leaks. Haven’t made a decision on the flooring as of today. If any of you Airstreamers out there have found a flooring product that works well for AS, please let me know…..
When I got my Airstream home, a month ago, it had an inch of dirt under the cabinets and refrigerator. Some of the areas under the cabinets had aluminum insulation glued to the plywood floor and on top of the wheel wells. When I pulled the insulation up, I found a mix of contact cement and dark black road grime. The idea behind having diamond plate under the cabinets is to make it easier to clean when needed, and a sold base to bolt down the new cabinets…. trex
Name:	trex and bunny.jpg
Trex and The Bunny @ bear creek clubhouse
Trex is offline   Reply With Quote
Old 10-30-2010, 04:47 PM   #30
Splitrock's Avatar
Sioux Falls , South Dakota
Nice picture. That you on the red shaker?
Gary
Old 10-30-2010, 04:56 PM   #31
Trex's Avatar
That's my baby....yep
Old 10-30-2010, 05:21 PM   #32
Splitrock's Avatar
Nice ride!
Old 10-30-2010, 06:07 PM   #33
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Did you drop your bellypan, trex? I think we would have taken mud in ours over what we did have - chewed insulation and tons of mouse droppings (and I mean tons)! Diamond plate would be an interesting bottom for your cabinets, clean but maybe a little noisy for stuff stored there? (I'm thinking pots and pans, etc.).
We're planning on using a cork floating floor when we get to that point in Little Girl. Others on the forums have said it's warm and durable. I've seen linoleum (the real stuff), and floating wood floors used too, along with the usual carpet. No carpet in OUR trailer - too hard to keep clean. We're not resorty kind of people.
We're also thinking cabinets made out of hickory. We love that wood - lots of interesting grain. We can get hickory plywood now at a lumberyard in MPLS, so we can keep the weight down enough.
We'll have to keep track of each other. You'll probably get ahead of us over the winter. Oh well.
Kay
Old 10-30-2010, 06:50 PM   #34
Trex's Avatar
No… I didn’t drop the bellypan. I replaced the front section of plywood and cleaned below before I dropped the new section in place. Also cleaned below small section of plywood I replaced in front of street side wheel well. It had a good inch of mud in the bellypan in that location. I have been looking at some of the other threads concerning flooring, but still not sure what we are going to purchase. I think within the next couple of weeks The Bunny and I will need to pick out flooring. Trex J
Old 10-30-2010, 08:12 PM   #35
Minno's Avatar
1972 31' Sovereign
Wow, you're way ahead of us in that regard. We aren't putting in flooring until after we get the cabinets in - too expensive to floor the whole thing for us. We would do the whole floor first if we were going to put in sheet vinyl or linoleum, but can't afford to do it with what we're putting in. Right now we're figuring out plumbing and planning on buying the tub for the bathroom.
Kay
Old 10-30-2010, 08:43 PM   #36
Trex's Avatar
I am retired....so the AS is my job, 8 hours a day last 20 days in a row. Today was the first day off. trex
Old 10-30-2010, 09:10 PM   #37
Minno's Avatar
1972 31' Sovereign
Ok, I'm officially jealous. Can't retire yet - still about 8 years to go if we're lucky and the economy doesn't tank again. Besides, can't work on the AS in the winter in this state - gets a little cool in the winter. (In Minnesota, we put winter jackets on when it gets "chilly", below zero). Oh well. Plan is to have her done by the time we retire anyway.
Kay
Old 10-30-2010, 10:19 PM   #38
Ottawa , ON
Kay
Kay,
You just gotta find a friendly farmer that will give you real good rent on the main floor of a barn which is kept warm by a nice big herd of cattle that's downstairs.
Old 10-31-2010, 07:27 AM   #39
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
As to flooring, we have used the non-glue vinyl wood grain flooring both in the house, where the dogs go in and out, and in the our first trailer. We got along very well with it. It was simple to put in. Easy to clean and stood up to wear and tear. And folks had to look twice to tell if it was wood. We got ours at Lowes.
Best Regards,
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 10-31-2010, 12:21 PM   #40
Trex's Avatar
Greetings Jeff & Cindy.... What kind of prep work did you do to your sub-floor, in-order to use the vinyl flooring? I sanded the bad spots and pulled staples out of the subfloor on Friday.
I am having a guy in Redding build new wheel wells out of aluminum sheet metal. I will use them to replace in “inter-shell” light colored plastic wheel wells. I was hoping to have them by Friday, but Mike skipped town for a long weekend. Hopefully he isn’t one of those businessmen who tell you they will get it done ASAP, and then take 2 months! I will find someone else, if he tries to pull that kind of B.S. trex :0
What to do about my rotten floor??? utahredrock Repairing/Replacing Floor &/or Frame 15 11-03-2011 12:38 PM
Frame rotten qc1500 Repairing/Replacing Floor &/or Frame 100 07-30-2011 05:01 AM
Rotten Wood adonh Interior Restoration Forum 7 11-21-2009 10:58 PM
What to do? Rotten floor cbl3030 Repairing/Replacing Floor &/or Frame 13 08-24-2006 12:25 PM
Rotten floor BurnBound Repairing/Replacing Floor &/or Frame 16 02-05-2006 08:03 PM
