Old 04-14-2006, 07:50 PM   #1
trevisgardne
trevisgardne's Avatar
Profile:  1973 31' Sovereign
Maryville , Tennessee
Solid Vinyl Tile (SVT) Adhesive Glue ?
I have finally found and purchased some solid vinyl tiles (18"x18" SVT) --not vinyl composition tiles (VCT)-- at a local salvage store. I had originally priced same through a flooring dealer. The dealer price was $1180 for 118 sf. The salvage price was $78 for 150 sf. I just didn't get the exact color I wanted.
The flooring is by a company called "MetroFlor". The have lots of info on the net, but a I can't find a local source for adhesive. Does anyone have a recommend on an adhesive to use. I am ripping up the old self adhesive tiles (won't stay down). I will be down to raw plywood.
1. What kind of adhesive or glue should I use.
2. Should I prime, preserve or paint the plywood when I have everything up?
thanx,
Trevis Gardner
trevisgardne is offline   Reply With Quote
Old 04-14-2006, 08:41 PM   #2
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Trevis,
You should prime the floor with a specific bare wood primer for tile installation AFTER you fill in the gaps and rute and seams. The vinyl tile will show ALL of that eventually. I'm sure that Henry's Adhesives makes a specific glue for your tile. Home Depot carries their stuff.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
lewster is online now   Reply With Quote
Old 04-14-2006, 10:04 PM   #3
scottanlily
Profile:  1960 24' Tradewind
santa barbara , California
hello ,
Home depot has floor adhesives for most if not all types of floors .I recommend sheet flooring adhesive .Also they will have the proper trowl for applying it evenly ,they work great.
Scott
scottanlily is offline   Reply With Quote
Tile or single piece vinyl? Andy R Floor Finishes 36 05-10-2003 06:56 PM
Tambour Glue? 74Sovereign Cabinets, Counter Tops & Furnishings 10 10-04-2002 03:05 PM
dried adhesive removal, again Rog0525 Cleaning, Stripping & Polishing 8 08-18-2002 01:29 AM
Grades of vinyl... Andy R Floor Finishes 2 05-31-2002 11:47 AM
Painting interior vinyl werty5926 Upholstery, Blinds, Walls & Interior Finishes 5 04-12-2002 06:22 PM
