Old 03-29-2016, 11:55 AM   #1
To Gulls
To Gulls's Avatar
2007 25' Safari FB SE
Pensacola , Florida
Soft Spot Reveal Rotten Wood - Now What?
We had the leak that was coming from under the door repaired and now we have to fix the floor. I peeled back the vinyl this morning and dug out some of the rotten wood and I've got quite a 'hole'. Neither one of us are 'handy'. I sincerely appreciate whatever experience / advice you may have. We want to do this on a budget because eventually we want to replace the entire vinyl floor. H E L P!
We are in Pensacola, Florida - if anyone is in the area and can lend a hand, we'd be willing to pay you . THANK YOU ALL!
To Gulls
Tami & Brenda - Pensacola, FL
2007 25FB Safari Special Edition LS
2008 White Toyota Tundra 5.7L V8
"There is no present like the time."
To Gulls is offline   Reply With Quote
Old 03-29-2016, 12:20 PM   #2
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
That's a common problem area that can be patched fairly easily (cut out the bad and splice in new). Of the course the main problem needs to addressed to - the leak. There are lots of airstreamers in your neck of the woods who can probably help.
Matt
rugjenkins is offline   Reply With Quote
Old 04-03-2016, 09:28 AM   #3
1972 31' Sovereign
Sanford , North Carolina
Just starting renovation
I just bought a gutted 31' Sovereign '71 model. Subfloor has the same rotted problems at door and in rear bath area. With so much to do I would like suggestions as what to do first. Prepare wall and paint, fix the subfloor and or replace all water tanks. Thanks beforehand for your help.
btyler48 is offline   Reply With Quote
Old 04-03-2016, 03:32 PM   #4
rugjenkins's Avatar
1975 Argosy 28
The floor repair may need the interior skins removed. Sprucing things up is good but not falling thru the floor is best😳😄
Matt
Old 04-03-2016, 03:42 PM   #5
1986 31' Sovereign
Miami , Florida
Any decent carpenter can replace the rotten section. It seems to be away from the wall, which is good.
Foley Airstream over in Gulfport has a pretty good reputation if you would prefer to use a dealer.
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 04-04-2016, 10:55 AM   #6
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
Bandera , Texas
Looks like you have done much of the hard part. Having had a similar issue, though our leak was from the sink area, replace with marine grade plywood.
banderabob is offline   Reply With Quote
Old 04-04-2016, 11:55 AM   #7
1969 27' Overlander
Sun Lakes , Arizona
If you've fixed the leak I'd recommend figuring out where the frame supports are in relation to the hole. Then cut away the bad wood, take an extra 1/4 to 1/2 inch from the perpendicular side and cut to the midpoint of the frame support. Cut a new piece to fit the hole drill and secure with fasteners at least two on each frame support. You can then lay a bead of clear bath caulk over the entire perimeter to seal it, relay the flooring.
Again don't do anything until you've found and corrected the leak.
Good luck
Redleger is offline   Reply With Quote
Old 04-04-2016, 12:15 PM   #8
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Mike
Try "Countryman RV and Marine repair" in Foley, Alabama. They have excellent techs, their rate are fair, and they're honest people. They have worked with my last 3 Airstreams whenever I find something I can't do myself...
They're located about 15 miles west of Pensacola...
Good luck!
Larry C
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 04-05-2016, 01:30 PM   #9
texastex
Texastex's Avatar
1984 34' Excella
GARLAND , Texas
I had a similar problem on my 1984 Excel or airstream floor in the bath area also a small spot in the living area. Some people call it the $40 fix. I treat the wood that is not totally rotten, with a mixture of hundred percent antifreeze 2 parts, liquefied borax one part and liquefied boric acid one part, this will kill the wood rot and any mold our bugs within it if any. I placed in the sprayer and liberally spread sprayed affected areas allow a couple of days to dry. Then use a scab supply wood and penetrative epoxy to seal the area. Then I use floor leveling to help with flooring bumps. I used vinyl Allure planks around the toilet.
This work great for me and it's a cheap repair if it works for you like it did me.
Texastex is offline   Reply With Quote
Soft spot on floor '06 Safari FB RichHog Repairing/Replacing Floor &/or Frame 12 11-25-2013 08:35 AM
Soft spot under floor in front of 2008 Safari 23' Rhrezo General Interior Topics 1 09-07-2013 11:38 PM
Monster House (Trailer) Show/reveal party Jan 22!! SilverSurfer Airstream "In the News" 12 05-03-2005 02:06 AM
How do I diagnose the soft spot, and what are the repair options? Narnian Repairing/Replacing Floor &/or Frame 12 09-01-2003 02:41 PM
soft spot repair stellablu Repairing/Replacing Floor &/or Frame 2 08-08-2003 03:18 PM
