Old 03-07-2016, 02:29 PM   #1
Culpeper , Virginia
So I just dropped 3k on an airstream...
Hi Everybody!
I've been lurking all your posts on these forums for three years. Probably made a username forever ago but I tried logging in and it worked. Kudos to me.
I wanted to share some pictures (not the best) of the 78 (I think) Sovereign I just purchased from a guy 30 minutes from me in Virginia. BTW, does anyone on this forum live near Culpeper, Fredericksburg, or Manassas?
So, my plan is to gut this puppy. After that, step 1 is to determine whether or not the rust on the bottom is ok enough or do I need a major investment. I probably should have grabbed someone else to come and look at it, but I'm confident I can fix any of this at my shop at work.
I have one limited picture of the rust and corrosion. What do you think, should I grind and buff this with an angle grinder? Do I need to do some additional welding?
ID:	258326   Click image for larger version
markjitsu is offline   Reply With Quote
Old 03-07-2016, 02:51 PM   #2
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Welcome to the madness. Looks like you did good. Enjoy
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 03-07-2016, 03:00 PM   #3
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
Looks very clean - good price!
Bottom flange on cross member is eaten away - grind and weld reinforcing piece. Grind all other areas of rust and protect from further corrosion.
The horizontal part of the flange takes most of the downward force, so flange is not critical - but corrosion should be stopped!
Good luck and welcome to Airstreaming!
Silver Hawk is offline   Reply With Quote
Old 03-07-2016, 03:00 PM   #4
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
I like it any pictures of the skin? Love that part of va. Yes you have a major investment and start reading the shell off because of what you can see she will be needing a lot of love and it will be more elbow grease than money if you are willing to work and learn! Bright side you will know every bit of your airstream and you are close to one of the best airstream doctors in on the east coast! Frank is good and not that expensive! Again welcome and enjoy!
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 03-07-2016, 04:47 PM   #5
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
At 3K you probably couldn't go wrong - especially if the shell is decent and half of the windows haven't been replaced by plexi.
The frame has obviously been painted (possibly to cover up the extent of the rust) but I too noticed that one crosspiece where the bottom had rusted out. There's also been some floor replacement too based on the screws showing through. And of course inside you have the replacement A/C only house refrigerator. But the P.O. did leave the belly pan off - so while you're missing all of the insulation, you're also missing all of the mess and can see the state of the frame and floor.
If you'd paid $10K it would have been a sad story, but for $3K your "project" trailer is well priced. Exterior pictures too please.
Paula
Old 03-08-2016, 06:43 AM   #6
Culpeper , Virginia
Thanks everyone for the replies. I'll take some better photos today now that I have it parked outside the house and it's a nice day. I feel a lot better knowing I didn't get ripped huge. I'l start demo today. I want to get a feel for the ins and outs of this AS. I'll start with the partitions, cabinets, beds, etc. Then I'll leave the paneling and take up the floor if possible. Otherwise, the bottom portion of paneling and the floor is coming up. Pics of the structure to follow.
Old 03-08-2016, 07:11 AM   #7
Mixter's Avatar
1976 27' Overlander
I might suggest you go camping for a while first.... That is, so long as its usable. It looks like fresh POR15 on the frame, and fresh paint inside, so it doesnt look like a stinky old trailer. I did notice that the belly pan seems to be missing, or at least parts of it. That may mean the previous owner either was proactive, or was beginning to fix some deeper problem.... BUT as long as it works- go out and use it.
I say that because I was going to just "clean up" mine when I got it on October 22, 2012..... I STILL have never actually used the thing.... I'm getting close to using it as a tent this year (I think)... but I'm pretty convinced a shell off renovation is a 5 year project if you work and have a family.
So I"m just sayin.... if you can get some use out of it, go do it before you get in this deep project and you're up to your ears in a "OMG this is a HUGE project" moment.
Have fun!
Micky
Mixter is offline   Reply With Quote
Old 03-08-2016, 07:55 AM   #8
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Looks like there is some loosely attached spliced wood underneath. Be sure to check those areas out real good. Looks good though.
Matt
rugjenkins is offline   Reply With Quote
Old 03-08-2016, 08:24 AM   #9
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
You have some cancer to the frame that should be welded. Also a poor repair of water damage. It looks like the PO tried to make the frame members look pretty with some paint which is just a bandaid. Given the obvious problems in the front of the trailer I have a strong suspicion that the rest of the frame and especially the rear will have more serious problems. Rear end separation is a strong possibility. No sense in redoing the interior without first taking care of the frame issues. It would also make sense to replace the axles at this point if they are the original axles.
Old 03-08-2016, 11:02 AM   #10
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
Three Rivers , California
Yeah, camp in it a little before you get carried away forever.
I've had mine a year and it's a year away from the road. I couldn't use it as it was too stanky.
twolanehwy is offline   Reply With Quote
Old 03-08-2016, 11:12 AM   #11
rugjenkins's Avatar
1975 Argosy 28
Yep, camp in it first. That way you can remember why you bought it in the first place after you open your can of worms. I bought mine 7 years ago and it just now to the point I can use it as a aluminum tent. (As a side note: I bought another one 3 years later just to camp in- it had more issues to fix than the first. I ended up buying a popup and building that from the ground up first which proved to be wise- now I have mojo to finish the first one) 😎
Matt
Old 03-08-2016, 11:16 AM   #12
Mixter's Avatar
1976 27' Overlander
Ok you win. Just made me feel better.
Old 03-08-2016, 03:49 PM   #13
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
It appears to be in pretty darn good shape for a $3,000 trailer.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-08-2016, 07:54 PM   #14
1968 26' Overlander
Manheim , Pennsylvania
I vote Camp in it too! At least through late spring and early summer while while the weather is nice. Does the AC and heat work? Looks like your fridge is an AC only fridge, so you'll need to have hook ups (or a bag of ice). It looks like it is in great interior shape and clean. Go have some fun in it as long as it is deemed road worthy! Had mine not been so smelly and nasty from a PO, I would have definitely slept in it at least once before I busted out the rivet remover! Awesome find. Good luck!
SonOfAnder
'68 Overlander
https://www.airforums.com/forums/f44/...te-145553.html
SonOfAnder is offline   Reply With Quote
Old 03-09-2016, 12:20 AM   #15
1973 31' Sovereign
Middletown , California
It looks like there must have been water trapped in there to rust the frame member that badly! Was there a spare tire mount under there also? The damage isn't all that bad right there and could be fixed a couple of different ways. Is there more rust in other places on the frame? If it's roadworthy I'd use it for a few years and think long and hard before gutting the trailer.
ijustlee is offline   Reply With Quote
Old 03-09-2016, 06:24 AM   #16
gYpsydreamin's Avatar
1975 31' Sovereign
Waldorf , Maryland
Markjitsu, I'm about an hour from Fredericksburg. My trailer has the exact same layout as yours and mine is (mostly) gutted now. She's a very slow work in progress but I love every step of the way!
gYpsydreamin is offline   Reply With Quote
Old 03-09-2016, 09:33 AM   #17
Culpeper , Virginia
Totally not camping in this thing. I haven't decided on what truck I want to pull it. 97 Ford Diesel with International in it?
I have about an hour on lunch every day to continue working on this. Pictures of the exterior (as requested) will be up following this post.
The Cancer on the frame. As soon as I can pull the floor up in it, I can get to that. The goal is to have a shell with an open floor so everything is exposed to the best of my ability. Then my first task if going to be taking a million pictures and sharing them with you all to get your feedback on how I should first tackle the repairs and or upgrades.
I also wanted to know, I did a search on here for "removing interior rivets". I've never done it before. Do I just drill into the rivet until it pops? A lot of the cabinetry and paneling are all held in by rivets, some screws here and there. Any quick advice or a decent link to a thread. I would think the search function would automatically link me to the phrase I was looking for. Sorting through 47 pages isn't fun. Will keep looking though.
-M
Old 03-09-2016, 09:51 AM   #18
Mixter's Avatar
1976 27' Overlander
An hour on lunch every day isnt enough for what you just described- especially if you're asking how to remove the rivets..... If you are ripping out the entire floor, you might as well be pulling the shell so you can fix the frame.
Not to discourage you, but this is a BiG job you should seriously think about before you go tearing that apart. Yours actually looks usable from your pics.
The red flag just went up when you asked how to remove a rivet, which is about as basic as this job will be. Gutting everything including the floor will open up MANY MANY more issues you likely have not thought about.
You can google your search topic by adding "airforums.com" to your search. i.e. "subfloor airforums.com", or "gantry airforums.com", or "shell off airforums.com"
Old 03-09-2016, 11:33 AM   #19
1962 28' Ambassador
Mesa , Arizona
A 1/8 drill bit good quality, several, and some pliers to unstick the parts that wont come out. Try not to widen the holes to much.
You are correct about sifting thru pages but it's part of it
As Mixter said,
"Airforums drilling out rivets"
"Drilling rivets Airforums.com"
Check out some full Monty threads here and the VAP on utube for great videos.
Hittenstiehl
Old 03-09-2016, 01:07 PM   #20
Culpeper , Virginia
Eh, I got this.
Not worried. I know how to take a rivet out, I'm just super cautious about this process and I will have a need to verify what I'm doing up front for a little bit in the beginning.
Dropped my lease, bought an Airstream. Cody Madison Member Introductions 28 07-25-2014 09:38 AM
Logged in....dropped off pyanke Forum Admin, News and Member Account Info 9 03-03-2004 08:54 AM
My Suzuki Samurai dropped into gear while being towed williamhenshall General Motorhome Topics 16 04-07-2003 09:30 AM
