Old 09-16-2009, 08:16 PM   #1
Profile:  1964 22' Safari
enosburg , Vermont
Snow belt floor replacement
If you need a new floor, do'nt want to tie up the A S in summer and have no heated shop in winter, I stumbled onto this last fall. Pull it up on car ramps, crib up the ft a-frame and the tail frame. Jacks under both axle plates. Pull out the ramps and remove the axle. Lower the belly pan at the seams. Remove the waste tank. Get some common bails of hay or straw and "seal up" the whole parimiter of the trailer. I used an inexpensive radiant propane heater inside, with the temp in the teens it would warm up in 30 /40 min and could work with just a sweatshirt. Once you remove a section of floor you have access to the bottom. Use one end for work space while you replace the other. Kinda fun, workshop & project all in one.
putback is offline   Reply With Quote
Serpentine belt replacement tips and procedure 454 LY 30 DaveFL Mechanics Corner - Engines, Transmission & More... 9 06-02-2009 10:00 PM
sub floor replacement help Terry J Repairing/Replacing Floor &/or Frame 12 03-31-2009 09:30 PM
Floor replacement Dman Repairing/Replacing Floor &/or Frame 3 03-07-2008 03:35 AM
Floor replacement Over59 1958 - 1963 Overlander 5 09-12-2004 02:24 AM
Belt replacement on 454 Gas Classic AccessMaster Airstream Motorhome Forums 12 05-03-2003 01:31 AM
