Old 04-01-2014, 07:11 PM   #15
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
1956 22' Flying Cloud
Rutherford Co. , North Carolina
There is no way to determine if this is a shell off without more pics. From what it looks like you can replace the last 4 ft of plywood. Elevator bolts are expensive. Last 2-3 ft of frame will need replacing or serious beefing up. Interior walls pulled out to put elevator bolts in c channel.
'57 Overlander | '56 Flying Cloud | '51 Spartanette
NJtoNC is offline   Reply With Quote
Old 04-01-2014, 07:44 PM   #16
webspinner's Avatar
Menlo Park , California
We fixed back end (bathroom) and near the front door floor rot without pulling the shell. We also fixed the rear end separation. Actually, my husband did all that except I helped with the final coats of penetrating epoxy that we put over the entire subfloor when we were done. It sure won't rot now.
There are some pictures and details in our blog (see sig line) but I was out of town when he did most of the work and he was too busy to take pictures.
Barbie
Our travel and renovation blog: http://tinpickle.blogspot.com/
webspinner is offline   Reply With Quote
Gaucho upholstery yardage estimates trearick Upholstery, Blinds, Walls & Interior Finishes 12 09-24-2012 11:18 AM
Labor to replace flooring ||| Wide range of estimates JakeSpoon Floor Finishes 1 07-06-2010 10:11 PM
Sneaky, leaky, rivet ! Robbie R. Ribs, Skins & Rivets 2 10-06-2009 07:25 PM
Consumption Estimates campadk Electrical - Systems, Generators, Batteries & Solar 8 02-03-2007 09:54 AM
Estimates from Jackson Center? Kistler Commercial Listings 18 12-15-2003 01:14 PM
