Old 06-12-2008, 04:14 PM   #1
Uberphotos's Avatar
1968 22' Safari
Kalamazoo , Michigan
Smelly floor...help
Okay, so I ended up dropping the belly pan off my 1968 Safari due to a bunch of mouse "stuff" that caused my trailer to really stink..I took out all the insulation, washed down the belly pan and cleaned it all out.
My question is this...after about 40 years (probably only the last 10 of which the mice took over), the wood has taken on the oder of the mouse "stuff". Does anyone have a way or a product that I can spay on the wood from underneath the trailer to help remove the smell?
'68 Safari Land Yacht, Double
Check out my blog... http://ssairstream.blogspot.com/
Uberphotos is offline   Reply With Quote
Old 06-12-2008, 04:18 PM   #2
Well Preserved
overlander63's Avatar
Colfax , North Carolina
There are a couple, one is an enzyme that eats the odor-causing bacteria. I haven't had any experience with (nor do I want it) trying to get it to eat 10 year old mouse pee.
Another option is spraying regular bleach onto the wood. If you do this, wear some kind of breathing mask, as uric acid and chlorine combine to create a toxic gas, much as bleach and ammonia do.
Some days, it's just not worth chewing through the restraints.
Old 06-12-2008, 04:27 PM   #3
Irmo , South Carolina
You can buy a very good enzyme product at most pet supply stores. Just ask a manager which is the best. You will need to plan on spraying it very well and then waiting a few weeks, and then treating it again. Keep in mind that the smell will get worse - not better - during the few weeks it takes the enzymes to eat the urine et al.
Overlander63's advice about toxic fumes is best heeded. That combo can be very deadly - very quickly - especially with large amounts of chemicals in a poorly ventilated space. It can knock you out before you know what hit you! The second downside of bleach is that it can weaken the fibrous content of the wood... don't want to encourage future repairs...
sariahjoy is offline   Reply With Quote
Old 06-12-2008, 04:34 PM   #4
touched
62overlander's Avatar
1948 22' Liner
Catonsville , Maryland
or you can get rid of the stuff holding the pee. Remove the old insulation and replace the floor that sure has rot....
Frank Yensan The Airstreamer's Club USA-1 "we're dead serious about having fun"
http://annalumanum.blogspot.com/http://frankstrailerworksblog.blogspot.com/
www.frankstrailerworks.com
62overlander is offline   Reply With Quote
Old 06-12-2008, 04:38 PM   #5
Uberphotos's Avatar
1968 22' Safari
Great suggestions...keep them coming and check out my blog and you can get a view of the "mud" on my belly pan.
62overlander, I have already removed the insulation and surprisingly there is no floor rot that I can see from below.
Old 06-12-2008, 04:42 PM   #6
InsideOut's Avatar
1956 22' Safari
Edgewater , Colorado
Images: 94
I hate to be the bearer of bad news, but...
My guess is that if there is mouse pee in the floor insulation, it's also in the wall insulation. Mice don't just confine themselves to the belly pan...if you have had mice, you have to assume they were everywhere. Bummer.
On a side note...my sister lives in Kalamazoo ~ and BTW, welcome to the forums...nice looking trailer!
Shari
RMVAC | WBCCI DenCO Unit | Tin Can Tourists | Sisters on the Fly | BIRDY - our '56 Safari
Old 06-12-2008, 04:45 PM   #7
Uberphotos's Avatar
1968 22' Safari
I am currently in a state of denial about having to get the insulation out of the walls...cool about your sister, it's a small world!
Old 06-12-2008, 04:52 PM   #8
HowieE's Avatar
Princeton , New Jersey
Images: 12
You mentioned that the floor did not show any signs of rot. However while you have the pan down work your way around the outside edge of the trailer, as close to the C channel as you can, with and ice pick. The pick will pickup problem that you may not see and as long as you can it's a great time to check.
WBCCI 12156 AIR 3144 WDCU TAC NJ6
2004 Excursion 4x4
1991 34 ft. Excella +150,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
My Kayak mysite.verizon.net/vze54tx9/kayak/
HowieE is online now   Reply With Quote
Old 06-12-2008, 05:35 PM   #9
Uberphotos's Avatar
1968 22' Safari
HowiE...I will do that...thanks
Old 06-13-2008, 07:59 AM   #10
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
My '73 had Norway Rats once upon a time AND mice right up to my purchase, removing pan and floor insulation did not stop the rat 'musk' fog until I Kilz stain-blocker painted the entire floor underside except a 6-inch perimeter at edges and painted the spars, frame and outriggers.
What I need to communicate (without grossing you out) is the forced air ducts act as mouse super-highways. The galvanized steel ducts seem to preserve the trails left by incontinent mice; my ductwork had dung dunes built up. There are places you can inspect duct interiors - I suggest you check them out ASAP...
I am committing to pulling entire interior liners - its a mouse habitrail condominium!!
Wabbiteer is online now   Reply With Quote
Old 06-13-2008, 10:22 AM   #11
Uberphotos's Avatar
1968 22' Safari
Wabbiteer...did you disinfect the underside of the floor or just put the Kilz on?
I guess I have to check the ductwork now...thanks a lot
Old 06-13-2008, 12:35 PM   #12
Wabbiteer's Avatar
1972 29' Ambassador
Note there is controversy in painting either sides of the plywood floor - the upper got two coats of oil porch paint to help stop mouse & formaldehyde odor and the underside got the stainblocker. I left a border around the circumference to allow some wick area for drying when minor leaks reached the sheet edge.
I counted on encapsulating whatever present with two coats of exterior grade stain-blocker - the spars and parts of the inside frame rails got Rustoleum Flat Black spray paint as the original asphalt based paint was in good shape; everything outside of the main ladder frames got POR-15'd. The worst smell section was from water tank forward and that frame iron was in the best shape.
Disinfecting versus odor-killing enzymes... I happily blotted the remaining bare plywood with diluted bathroom mildew remover (strong chlorine bleach) and it air dried for a few weeks before I put foil-foam-foil insulation up. The enzymes are worth their weight when you have no possible disease vector like family pets and I use them, but nothing beats good old bleach in my book, well, except where I pulled the back bath area floor and replaced it....
Old 06-13-2008, 03:03 PM   #13
Uberphotos's Avatar
1968 22' Safari
Here is my plan...
Old 06-13-2008, 08:35 PM   #14
Renee
Felix'64's Avatar
1964 24' Tradewind
Portage , Michigan
Images: 16
Eeeewwwwww!!!!!
So sorry about your problems! Can we take the tour after the smell is gone?
"20 years from now you will be more disappointed by the things you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."
Operation "Save Rudy" Strike Team (honorary member)
Felix'64 is offline   Reply With Quote
floor soon? air66stream Repairing/Replacing Floor &/or Frame 7 11-02-2007 09:01 PM
My new floor The Flintstones Floor Finishes 16 09-01-2007 08:03 PM
Smelly AS altamont Waste Systems, Tanks & Totes 13 08-24-2007 11:32 AM
Planning how to refloor a 66 Sovereign: currently, smelly carpet & pad over linoleum Becky Repairing/Replacing Floor &/or Frame 13 09-05-2005 03:34 PM
New Floor - Before, during and after TroutStream Floor Finishes 10 07-23-2004 06:26 PM
