06-13-2010, 05:38 PM
#481
1955 22' Safari
Great Lake State
Gave the vent a good compounding today, wish I could find another.........
toastie
06-13-2010, 08:31 PM
#482
2003 22' International CCD
Kiln
, Mississippi
You have an illness that is yet to be documented. It may become infectious to others. I'm going out to my trailer to clean something............
Michael & Tina with Layla and Preston BZ The family has grown. 2003 22' INTERNATIONAL CCD
06-15-2010, 04:15 PM
#483
1955 22' Safari
Great Lake State
My AC came today, it a Frigidaire Window-Mounted Slider / Casement Air Conditioner Model: FAK085R7V 14-3/16" W x 20-1/4" H x 24-1/2" D, 8,000 btu, Amps (Cool): 7.2. My plan is to turn it into a central air unit, if it doesn't work, I'm out $329.00 and no AC, putting on roof top air is not a option.
toastie
06-15-2010, 05:32 PM
#484
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha
, Wisconsin
Originally Posted by toastie
Frigidaire Window-Mounted Slider / Casement Air Conditioner... My plan is to turn it into a central air unit
Are you planning to set it up to work like a slide-out? (projecting from the side of the trailer when parked and flush when traveling)
...or flush with a plenum for ventilating the compressor?
One nice thing about this unit is that you should be able to power it with one 2000 watt generator.
I can't wait to see how you work it out.
06-15-2010, 05:58 PM
#485
Port Hadlock
toastie
Don't remember it looking that good the last time I saw it.
-steve
06-16-2010, 07:55 PM
#486
1955 22' Safari
Great Lake State
Here's a picture showing the front of AC with panel off. There's a fans in the unit that draws the warm air from inside the trailer over the evaporator coils than out as cold air. The evaporator coils have 132.25 sq. inches of area and the cold air going out is 45.0 sq. inches. I plan to run the cold air thru 3 tubes, 1 to the back 1 in the middle and 1 in the front of trailer. Each tube being 4" dia with 12.6 sq. inches, 3 x 12.6 sq inches = 37.8 sq inches.
toastie
06-19-2010, 08:07 AM
#488
Jupiter
The roof mounted A/C has one big advantage - the hot air rises (plus displaced by heavier cool air upwards) to meet the intake...
If you could have a 'thick' partition (hollow) bring the hottest air up near the ceiling into the unit I believe you would really have a good start!
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
06-19-2010, 09:37 AM
#489
1955 22' Safari
Great Lake State
Wabbiteer
Was planning on using the center FanTastic fan from http://www.vintagetrailersupply.com/Fan_Tastic_Fan_p/vts-414.htm
to take the hot air out, or a very small fan inside to mix the hot
and cold together, like a ceiling paddle in a home.
toastie
06-19-2010, 10:24 AM
#490
1955 22' Safari
Great Lake State
Started putting seals to the door today and what a pain, the pain is finding seals that will work to a door that will not go back the way it was. Plan to attach a seal to the door as show in the pictures then another seal to the door frame, then another seal to the outter flange of door, and if that works will seal the inner door. These type of doors are very cool, but have leaks written all over them.
toastie
06-20-2010, 01:42 PM
#491
1955 22' Safari
Great Lake State
The door new seal is installed between the interior skin and the outer skin, and then riveted in place using conventional bucked rivets.
http://www.vintagetrailersupply.com/..._p/vts-136.htm
toastie
06-21-2010, 05:03 PM
#492
1955 22' Safari
Great Lake State
Removed old vent today and installed my new Panel-Ray vent........thanks steve
toastie
06-24-2010, 07:03 PM
#493
1955 22' Safari
Great Lake State
Found this water vented fill for 1-1/2" hose, angled neck, chrome plated bronze cap 3 1/4" dia, black plastic body stainless steel bead chain manufactured by Perko. $17.00 with free delivery.
toastie
06-25-2010, 10:45 AM
#494
A 7th year newby
1968 24' Tradewind
Indianapolis
, Indiana
Your painted floor
I've been considering painting my floor to tie together new nyloboard in the back and the rest of the plywood. It looks great! And, looks very encouraging.
Excellent work and thread details.
Anne
Painted the floor and will finish putting the rest of the interior panels up, polish to mirror finish, then a second coat of paint.
toastie
Anne
Indianapolis, IN
TAC IN-7
1968 Airstream Trade Wind
2005 Chevy K1500 crew, reg. bed, 4WD, gas
06-25-2010, 06:34 PM
#495
1955 22' Safari
Great Lake State
Anne
Thanks IndyAnne, the paint is there for added protection, we are going with wood or a linoleum for the finish.
toastie
06-25-2010, 06:38 PM
#496
1955 22' Safari
Great Lake State
Installed J-shaped moulding to wheel wells today.
07-10-2010, 07:21 PM
#497
1954 18' Wanderer
Clarkston
, Michigan
This is looking great!
with the cold output at the ceiling it will naturally mix with the hot air as it falls. there is not a need for an auxiliary fan.
07-11-2010, 09:37 AM
#498
1955 22' Safari
Great Lake State
Thanks very much 1954cruiser. The AC unit is going to sit like the below picture. Going to build duct work for the outside incoming air (the side louvers) and run the ducts through the belly pan to outside and same for the hot air going out. Then build a door for the hot side that tilts away from the incoming cool outside air........like yours.
toastie
07-24-2010, 02:41 PM
#499
1955 22' Safari
Great Lake State
Changed my AC design today, and today was a good day to work on the AC being that it is 90 deg's. I did a test run with the AC trying it between the beds and I was amazed how cool the inside got in a short time, could feel the cool air all the way to the front, and to the ceiling. Will run the warm air behind the license plate. Will build duct work for the outside incoming air (the side louvers) and run the ducts through the
belly pan to outside fresh air.
toastie
07-25-2010, 02:21 AM
#500
2005 22' Safari
Hyde Park Place
, Ohio
Cutting away the louvres on the sides of the case (where outside air is drawn in) will go a long way to reducing the white noise made by the unit when running. The louvres create a lot of turbulence.
Also, coating the inside of the chamber enclosing it with sound absorbing material (like the fiber mats for car hoods, for example) will reduce the noise further.
This will give you a much more comfortable sleeping environment - unless you like white noise when you're sleeping.
TX-16
