10-20-2009, 06:34 PM
#321
1955 22' Safari
Great Lake State
Ran a few wires tonight and using rubber grommet as shown in the picture to keep the wires from the sharp edges. Would trempro work just as good as the rubber grommets. The rubber grommets are expensive.
10-20-2009, 08:23 PM
#322
1976 25' Tradewind
, Maine to Arizona
Metal Covered Wire
Metal covering would be more resistant to chafing but heavy, expensive and cumbersome.
Rodentia nibbling in and among wall areas are a hazard.
I like the rubber grommets, maybe alternative sourcing is an option.
"Talk is cheap, Airstreams are expensive," Wally Byam.
25' Tradewind
'18 Promaster 1500 High Roof
10-21-2009, 05:02 AM
#323
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Cape Coral
You definetely want to use rubber grommets. Having a wire short out inside the wall is not a good thing. You might consider McMaster Carr. You can get a bag of 25 for $10 or $11 rather than the unit price at the nearest big box store. While you are shopping, I found a step drill to be very useful.
10-22-2009, 04:31 AM
#324
1955 22' Safari
Great Lake State
What size did you use for the 12 gauage romex.......thanks vey much
10-22-2009, 05:09 AM
#325
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Cape Coral
I used a combination of 5/8 ID and 3/4 ID. The smaller for one run, the larger for those places where I ran 2 or 3 through the same hole.
10-22-2009, 08:28 AM
#326
1956 22' Flying Cloud
Dallas
Any thoughts on how many grommets would be needed for a complete rewire (of a 56 22 foot Flying Cloud)?
Hank
10-22-2009, 08:43 AM
#327
1971 21' Globetrotter
Arvada
Another though would be NOT running the AC wire with the DC wire together on the same runs, or tied together. keep them separated. This will minimize the "Noise" in the DC runs. Also do not ground the AC and DC on the same grounding studs
Kip
10-22-2009, 04:07 PM
#328
1955 22' Safari
Great Lake State
Hank
I don't have a clue, but I did order 40 from McMaster Carr today.
toastie
10-22-2009, 04:43 PM
#329
1955 22' Safari
Great Lake State
Kip
Will separate the wires......thanks
10-23-2009, 06:16 PM
#330
1955 22' Safari
Great Lake State
All lighting will be LED Puck and LED Rope except for one antique table lamp. The Puck Lights draw only 65mA that's approximately 1/2 the power of a single incandescent automotive type bulb.
10-24-2009, 09:56 AM
#331
Arvada
Toastie
Where did you get the puck lights at, and if you don't mind how much $$$$ for each?
Kip
10-24-2009, 10:09 AM
#332
1955 22' Safari
Great Lake State
Toastie
Kip
Kip
Bought them at 12V Warm White LED Puck Light
toastie
10-24-2009, 01:18 PM
#333
1955 22' Safari
Great Lake State
This is my wiring plan, all comments are welcome.
Wire 5 will be for the main
Wire 4 to the 20 amp, will be only for air conditioner
Wire 3 to the 15 amp, will be only for Intellipower; will be pluged into a GFI receptacle.
Wire 2 to 15 amp GFCI will be only for microwave and refrigerator.
Wire 1 to 20 amp GFCI will be all exterior and interior receptacles and switches.
10-24-2009, 08:50 PM
#334
1962 22' Safari
2016 30' Classic
Southeast
, Michigan
I wouldn't put all interior and exterior receptacles and switches on one circuit breaker. If you should happen to have a short on that circuit, you would lose all usable power in the trailer. Plus all on one it would be easier to overload and trip the breaker accidentally. I'd prefer two 15A circuit breakers staggered around the trailer so you would still have some power if you lost one circuit. Make them both 20A's if you are concerned about plugging in some large load like a 200W inverter.
Unless you are planning to include a 1500W microwave, you may not need to dedicate a circuit breaker to it and could share it with some receptacles and switches to keep from having to go to a 6 breaker box.
And regarding the microwave circuit breaker, I assume the fridge you would be sharing with it would be a 2-way (LP and AC only) with the 12V feed low current only for the circuit board. If you intend a 3-way that could be run entirely off 12V, you'd want to add a switch so that only the fridge or only the microwave could be powered at one time to keep you from blowing the circuit breaker when both were on simultaneously.
Joe
WBCCI/VAC #702 & #6768
10-25-2009, 05:15 AM
#335
1955 22' Safari
Great Lake State
Joe
Our fridge is a 3-way and we haven't picked out a microwave yet but
need to plan for a 1500W. Looks like I need to separate the fridge from
the microwave. If I replace the 15 amp GFCI with (2) 15 amp breakers, one
for the fridge and one for the microwave and have them plug into a gfi receptacle
Toastie
10-25-2009, 11:03 AM
#336
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake
Originally Posted by toastie
...Our fridge is a 3-way and we haven't picked out a microwave yet but need to plan for a 1500W. Looks like I need to separate the fridge from the microwave...
When's the last time you checked the 115V power needs of the fridge? Last time I looked at my 30-yr old model in the Overlander it was 125 watts, or about 1 amp. I don't think you need to put it on a separate circuit. Your microwave, even if a big one, is probably less than 1200 Watts. Theoretically, a 15-amp breaker can supply 1700+ Watts.
I think three 115V circuits are sufficent--one for the A/C and the other two to split circuits, just in case you have a breaker failure that you can't repair immediately or if you use multiple ceramic heaters in the winter. You're hard pressed in an Airstream to use enough 115V power to blow a breaker, unless you've rooted yourself permanently into a park and are using power tools with abandon. The common exception, of course, is the dreaded 1500W hair dryer, so your bath outlet needs to be on the other circuit from the microwave. If you're using more than one ceramic heater, you need to split them, too.
Zep
10-25-2009, 11:17 AM
#337
1955 22' Safari
Great Lake State
Zep
Zep
Also thinking about going with a electric hot water take rated at 2000W, if I move the fridge back to the microwave breaker then I can have a breaker just for the hot water.
toastie
10-25-2009, 11:42 AM
#338
2007 25' International CCD FB
Holladay
, Utah
Thanks Barry, I told the one neighbor that is my beer cooler..........
Its a beer cooler????? And to think I've been peeing in mine. Where do you keep your cigars?
10-25-2009, 02:48 PM
#339
2002 25' Safari
Dewey
The GFI for the converter may not be such a good idea. There have been other threads about this in the past.
http://www.airforums.com/forums/f449...gfi-43187.html
Richard
10-25-2009, 09:04 PM
#340
1962 22' Safari
2016 30' Classic
Southeast
, Michigan
Yeah, it was too late late night. I was mixing 12VDC and 115VAC. A 3-way fridge probably pulls something like 12A on 12VDC. You are right that it would be more on the order of 1A on 115VAC, but don't quote me on the exact values. Sorry for the confusion.
I still stand by the idea of not putting all outlets and switches (lights) on a single circuit, though.
Joe
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
